Old Mar 06, 2003, 09:42 AM
stuartaw is offline
Find More Posts by stuartaw
Berks, England
Joined Jun 2001
Limited Motor Run - how limited?
I'm using a Hacker B50-7s, geared on 10 cells, to pull around 65 amps. (This is analogous to an Aveox F10LMR) Cooling is mediocre. Hopefully someone can help me avoid blowing up some expensive gear - this is the first motor I've had that cannot be run at or near full power continuously. For these sorts of drive-trains what sort of time can the motor run for before damage sets in?
Stuart
stuartaw is offline Find More Posts by stuartaw
Old Mar 06, 2003, 01:40 PM
JDubman is offline
Find More Posts by JDubman
Joined Dec 2002
I'm running a B50 7S, 10 zapped cp2400, and a 18x10 prop. I'm pulling around 85amps. Motor run time is between 20-30seconds with absolutly no cooling. The motor is never hot after landing but the batteries sure are. Your motor is fine if your only pulling 65 amps through it at less than 30 second runs.
JDubman is offline Find More Posts by JDubman
Old Mar 06, 2003, 04:55 PM
stuartaw is offline
Berks, England
Joined Jun 2001
Thanks for that. I'm hoping it will have enough power that 30 seconds is way more than I actually need to use.
Stuart
Old Mar 06, 2003, 05:24 PM
LJH is offline
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Stuart,
In my Laser-E with a F12LMR 15X15 RFM and 10XCP2400 Zapped and it pulls right around 65Amps I have to run the motor for maybe 7-8 seconds and it is getting pretty darm small. These things ar cool .
Cheers,
Jim
LJH is offline Find More Posts by LJH
Old Mar 07, 2003, 11:41 PM
rroback is offline
Find More Posts by rroback
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
In my silent dream 2.5 I've been running a konti 500/27 with a gearbox 1 to 5.2 spinning a 14 x 9.5 on 8 2400mah cells. Not pushing it hard but no cooling, and I've never even thought to add any, never even flet motor but batteries are slightly warm afterward. I'm moving up to 8 cells ( 1700cp) and a 16 x 13 prop. Do you think I need to add cooling or is it ok for some climbing then some thermaling?
rroback is offline Find More Posts by rroback
For Sale Q-10 Limited Motor Run RonB Aircraft - Sailplanes (FS/W) 2 Apr 04, 2007 12:27 AM
Article Icare's Magellan-E Limited Motor Run (LMR) Sailplane Review frankswd Electric Sailplanes 5 Dec 26, 2006 10:51 PM
Limited Motor run computer program downeym Electric Sailplanes 10 Apr 19, 2005 04:26 PM
Speed 400 Limited Motor Run Glider? vol-haut Electric Sailplanes 29 Nov 07, 2004 11:34 AM
Design input for 3D limited production run airplane KonstantKrash Parkflyers 1 Feb 28, 2003 12:05 PM
