Old Jan 05, 2009, 10:56 AM
johnsocj is offline
Find More Posts by johnsocj
Los Angeles, CA
Joined Jun 2004
Originally Posted by LesUyeda
Surfboards
Les
There's a reason the surfboard folk are called "resin-heads" -Dude, that's like.... Dude. wha-a- ... Dude. Cool.-
johnsocj is offline Find More Posts by johnsocj
Old Jan 05, 2009, 12:07 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Used to use polyester for thermal and slope fuselages. They can be made very strong. But epoxy is stronger. Better strength to weight ratio, less shrinkage and more stable.
True the smell is awful but it is easier to use. Moulds can be made real quick with CSM (chopped strand mat). Still use it for slope stuff where the last ounce of performance isn't neccesary.
S
Shedofdread is offline Find More Posts by Shedofdread
Old Jan 05, 2009, 12:53 PM
guinnb is offline
Find More Posts by guinnb
guinnb's Avatar
Indiana, USA
Joined Apr 2004
To keep the cost down and quality high go with West Systems Epoxy. Here's a good link for it: http://www.aircraftspruce.com/menus/...stsystems.html
You can buy one base resin (105) and get different hardeners to your liking (5 min, 30 min, etc.). The best hardener for lamination work is the 206. Also, get the auto ratio pumps. No guessing on how much of each component to use. I was fortunate and had 3 gallons given to be a couple years ago. It will keep very well if you keep it cool and out of the light.
guinnb is offline Find More Posts by guinnb
Old Jan 05, 2009, 03:31 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
I have never used polyester resin in aircraft applications etc... I have used the nasty stuff to make moulds (because epoxy/urethane moulds would cost alot!). Tooling gel, resin, and glass cloth work well.
I get Westsystems epoxy for $55/L and use that and 10/30min epoxy for everything in an airframe, composite part etc..
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Jan 05, 2009, 06:27 PM
planeman is offline
Find More Posts by planeman
High Exalted Poohbah
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
I've used polyester resin with no problems. You can't apply it over foam as has been mentioned as it melts the foam and you have to be careful of the shape of male molds as it does shrink a tad. Shallow male molds are o.k. but deep male molds are a no-no as the polyester resin will shrink on the mold and lock it tight to the mold. Ask me how I know.
Planeman
planeman is offline Find More Posts by planeman
Old Jan 06, 2009, 06:16 AM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
Cost and smell are the major differences. Somebody has already said: The fiberglass is where the strength comes from, the resin less so. 20 years ago many people used Fiberglass cloth and polyester resin to finish airplanes. The Gougeon Brothers and their West Systems method of finishing have brought epoxy to the forefront, today. One of my first power planes was finished with polyester resin only, no cloth. This method was outlined in RCM's Flight Training Course and it worked fine. My wife was not happy with me; however, simply becase of the very strong smell. I would use epoxy now, using either System Three or West Systems products. Polyester is still used in the boat building industries, due to costs; but, epoxy is making in-roads there also. Remember, Polyester doesn't want to cure over epoxy. The other way around is o.k.
Mode One is offline Find More Posts by Mode One
Old Jan 06, 2009, 07:30 PM
johnsocj is offline
Los Angeles, CA
Joined Jun 2004
It should also be mentioned that the "polyester resins are easier to work with than epoxy resins" mode of thought- while once VERY true, is far far less so today. The main problem epoxy resins had was cure times (and sometimes wouldn't cure) in temps outside their range. They've improved SO MUCH.
West Systems is the classic- also look out for MAS epoxies, kayak homebuilders really love the stuff.
Old Jan 12, 2009, 07:44 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Ding, ding, ding, we have a winner. I have used West Systems and it is super stuff. The auto ratio pumps make it super easy and minimize waste. West Marine also carries West Systems:
http://www.westmarine.com/webapp/wcs...imary%20Search
Also the West Systems is about odorless. If your workshop is in your house the smell of the polyester resin will permeate every square inch of your home and it isn't pleasant. Go with epoxy if only for that reason.
Rickochet is offline Find More Posts by Rickochet
Old Jan 12, 2009, 08:30 AM
kwmtrubrit is online now
Find More Posts by kwmtrubrit
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
What is the typical West Systems product you guys use? I noticed a "G-Flex" that seems like it would be pretty good for planes, but not being that up on epoxy I'm going to bow to the experts. It will be used for GF on wings and CF on spars.
Keith
kwmtrubrit is online now Find More Posts by kwmtrubrit
Old Jan 12, 2009, 09:41 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Keith
I am not familiar with the "G-Flex" but it would appear to be a 2 part epoxy for fastening parts, not a resin to wet out cloth like the 105 resin.
Old Jan 12, 2009, 01:58 PM
Ninjak2k is offline
Find More Posts by Ninjak2k
United States, VA, Warrenton
Joined Apr 2001
In a related question, what types of epoxy are there? Can the West Systems epoxy be used for all applications or it is more for laminating type applications? Can/should it be used for applications that would require more strength like bonding wing tubes and such or would some other 2 part epoxy be better for that application?
~Dan
Ninjak2k is offline Find More Posts by Ninjak2k
Old Jan 12, 2009, 03:43 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
~Dan
Here is a link for West Systems epoxy. Maybe they can answer your questions.
http://www.westsystem.com/ss/
Old Jan 12, 2009, 07:40 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
G-flex is a VERY flexible epoxy. YOu can bend a layup 180 degrees without breaking or cracking. Not for stiffness. And it can be mixed with 105 system to get intermediate characteristics.
And BTW the smell of polyester resin is not the polyester. It is the styrene monomer solvent The styrene thins the mix and also reacts to be part of it.
Pinecone is offline Find More Posts by Pinecone
Old Jan 12, 2009, 07:54 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Whatever it is I don't think you want to do any in your basement workshop.
Discussion Epoxy resin vs polyu dusty IV Composites Fabrication 8 Jan 27, 2008 01:56 AM
Help! epoxy mates to polyester resin? DrFragnasty Scale Sailplanes 28 Nov 16, 2007 06:12 AM
Discussion mixing epoxy resins txcarbon Composites Fabrication 3 Oct 07, 2007 05:09 PM
Discussion Resins Epoxy and Polyester Stikmkr Slope 7 Jul 28, 2006 07:47 AM
