Los Angeles, CA
Joined Jun 2004
Poly Resins are dinosaurs. Forget about them. The catalysts (MEK) are more hazardous, the resin smells horrible, and are not as stable in the sunlight. (I might have that last one backwards)
What they are for- is for fiberglass mat. Epoxy resins will not disolve the glues that hold the mat together, and will not allow it wet and relax to the complicated shapes that you use mat for. No one on these forums uses glass mat. I don't doubt that ARF manufacturers would use polyester resins to cut cost. Remember that those folk are also (probably) in industrial areas with the facilities to deal with this trash. Then again, they may just be poisoning themselves... |
Maryland
Joined Sep 2004
Epoxy resins can create alergies to epoxy, which can limit your later use of them. Just because there isn't an odor, doesn't mean they are perfectly safe.
Avoid skin contact and use in a well ventilated area for both types of resin. ESPECIALLY with poly, wear safety goggles when handling the catalyst. A single tiny drop in your eye could cause lose of vision in that eye. MEKP is VERY reactive to body tissue. |
Les |
| Thread Tools | |
| Discussion Epoxy resin vs polyu | dusty IV | Composites Fabrication | 8 | Jan 27, 2008 01:56 AM |
| Help! epoxy mates to polyester resin? | DrFragnasty | Scale Sailplanes | 28 | Nov 16, 2007 06:12 AM |
| Discussion mixing epoxy resins | txcarbon | Composites Fabrication | 3 | Oct 07, 2007 05:09 PM |
| Discussion Resins Epoxy and Polyester | Stikmkr | Slope | 7 | Jul 28, 2006 07:47 AM |
