Old Jan 02, 2009, 10:24 AM
EQMOD's Avatar
Joined Mar 2008
4 Channel Indoor Stunts with a PicooZ - More stunts
Its realy fun testing the limits of a 10 gram 4Ch helicopter in your house. And here she is with a couple of videos on some of the stunts;
Ground Hovering - A real test of the cyclics;
PicooZ: 4 Channel (4CH) 2.4Ghz Gyro-ed tail : Full Elevator - Aileron Cyclics: Ground Hovering (0 min 56 sec)
Single Loop Pass - Attempt 1
Indoor 4 Channel PicooZ Stunts : Single Loop Pass - Attempt 1 (0 min 22 sec)
Single Loop Pass - Attempt 2
Indoor 4 Channel PicooZ Stunts : Single Loop Pass - Attempt 2 (0 min 20 sec)
Double Loop Pass
Indoor 4 Channel PicooZ Stunts : Double Loop Pass (0 min 35 sec)
Triple Loop Pass
Indoor 4 Channel PicooZ Stunts : Triple Loop Pass (0 min 40 sec)
Double "in-line" Loop Pass - Attempt 1
Indoor 4 Channel PicooZ Stunts : Double in-line Loop Pass - Attempt 1 (0 min 26 sec)
Double "in-line" Loop Pass - Attempt 2
Indoor 4 Channel PicooZ Stunts : Double in-line Loop Pass - Attempt 2 (0 min 22 sec)
EQMOD is offline Find More Posts by EQMOD
Old Jan 02, 2009, 10:28 AM
Joined Nov 2008
I think you should see if you can get one of the toy companies interested...
cstratton is offline Find More Posts by cstratton
Old Jan 02, 2009, 10:51 AM
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
A truly indoor 4 channel FP heli.
Bill
Air Vaca is offline Find More Posts by Air Vaca
Old Jan 02, 2009, 12:34 PM
United States, OH, Columbus
Joined Oct 2002
If the toy companies were smart, they would already be monitoring these forums. If I were the CEO, I would have my engineers on a plane to see EQMOD and see how much a it would cost to have him as our exclusive "consultant / engineer".
Excellent work. I am still utterly amazed at the level of cleverness and ingenuity on the part of members of this forum.
Pete
Buckeye95 is offline Find More Posts by Buckeye95
Old Jan 02, 2009, 01:12 PM
Efficiency Freak!
Toanawanda NY
Joined Nov 2006
I agree!
Here is my favorite version, and I think a commercial version of yours like it would be killer. I have had these for more than a year and a half now and they have never broken. The frames are awesome. They have main shaft bushings as well that could be replaced with bearings. I think a lighter canopy is in order though.
The white one is the one that used to have two 70mah lipos on it and I was able to get 19 minute flight times out of it. I just replaced the lipos with new 70mah lipos, only one for each now. The white ones main and tail motor needs to be replaced now though as I used it allot and it had to work pretty hard to lift the two lipos compared just one.
Anyway, I just wanted to put this out there and see if other people like the style of this model as well, maybe as a target for development?
Other things that I have "modded" on these is only: Cutting and sharpening the main blades' leading edge for the most efficiency and lift, heating and spreading out the landing gear, cut out the top and bottom of the canopy for weight savings and so air and thrust can flow through, removed the "extra" tail boom supports, and curved and angled the "G" sticker on the tail so it is a "help" to the tail motor by turning some of the main rotors trust into CW rotational force on the tail that is ~proportional the the thrust from the rotor (it helps tail kick on throttle bursts).
EQMOD, I would like to send you some parts. I have lots of them.
I would like to help in anyway I can. PM me your info.
TTYL,
Jay
GITech is offline Find More Posts by GITech
Old Jan 02, 2009, 05:01 PM
EQMOD's Avatar
Joined Mar 2008
Hey, thanks guys
I was intrigued on the blade trimming mod, was there a significant improvement in lift ?
Old Jan 02, 2009, 05:14 PM
Excellence is Expected
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
that's cool. That is the way that little guy should fly.
MakMov is offline Find More Posts by MakMov
Old Jan 02, 2009, 09:05 PM
EQMOD's Avatar
Joined Mar 2008
Right now i attempting to make it more light.
Old Jan 03, 2009, 04:35 AM
EQMOD's Avatar
Joined Mar 2008
here is a more challenging task, passing through a 'smaller' opening;
Smaller Loop - Single Pass Attempt 1
PicooZ : 4 Channel Indoor Stunts - Small Loop - Single Pass, attempt 1 (0 min 24 sec)
Smaller Loop - Single Pass Attempt 2
PicooZ : 4 Channel Indoor Stunts - Small Loop - Single Pass, attempt 2 (0 min 36 sec)
Smaller Loop Double pass
PicooZ : 4 Channel Indoor Stunts - Small Loop - Double Pass (0 min 43 sec)
Old Jan 03, 2009, 02:57 PM
Efficiency Freak!
Toanawanda NY
Joined Nov 2006
Originally Posted by EQMOD
Hey, thanks guys
Yes, lift and climb rate. I trim off (most of) the leading edge that hangs over. You know what I mean? 1 or 2mm at most. I haven't had to do it in a while but I could do one and post pics later.
You live in the philipenes?! wow, well it wouldn't be to far for a company like walkera to send someone to you.
Walkera...are you watching?
John, tell them they should look at this...if EQMOD wants that, that is.
Jay
Old Jan 04, 2009, 05:50 AM
EQMOD's Avatar
Joined Mar 2008
ok, here is the final leg of the sub micro 4 channel stunts. The heli is getting over exposed already on youtube . But i did finally add a "body" into to it.
This time its a test of the aileron response, that is flying "sideways" plus a little spot landing at the end;
Sideways through the loop and back;
4 Channel PicooZ : Aileron response, Sideways flight test through the loop (0 min 27 sec)
And then through a smaller loop while still flying sideways;
4 Channel PicooZ : Aileron Response, Sideways flight test through a smaller loop (0 min 28 sec)
And a quick "spot landing" on a small platform;
4 Channel PicooZ : Spot Landing through a small platform (0 min 16 sec)
Old Jan 04, 2009, 09:47 AM
Joined Apr 2008
Good job. Simply amazing.
sfsilicon is offline Find More Posts by sfsilicon
Old Jan 04, 2009, 12:34 PM
Efficiency Freak!
Toanawanda NY
Joined Nov 2006
Yes, awesome!
Old Jan 04, 2009, 12:51 PM
Joined Jan 2009
Very impressive
DrRoc is offline Find More Posts by DrRoc
Old Jan 04, 2009, 05:29 PM
Gimbaled
superdave42's Avatar
morgan hill california
Joined May 2004
pretty cool man, good job
superdave42 is offline Find More Posts by superdave42
Latest blog entry: Some of my Multicopter designs
New Product WASP v RTF 4 channel indoor helicopter - German CE goingmajor Vendor Talk 1 Jul 27, 2006 11:24 PM
Off Site X-Plane 4 Channel RTF Plane with Camera X-Plane 4 Channel RTF Plane with Camera Solcat Aircraft - Electric - Airplanes (FS/W) 0 May 19, 2006 08:12 PM
Alert Hook up Futuba Skysport 4 Channel Buddy Box, with RealFlight Simulator shawnsp400 Fuel Plane Talk 1 Jan 06, 2004 10:37 AM
6'4" indoor flyer with less than 1 oz per sq foot loading MichaelConnally Indoor and Micro Models 30 Aug 08, 2003 04:53 AM
Futaba MCR-4A 4 channel AM Receiver with built in ESC Jason M Aircraft - Electric - Airplanes (FS/W) 1 Jan 07, 2002 04:02 PM
