Old Jan 01, 2013, 07:57 PM
nitrofevr is offline
Find More Posts by nitrofevr
nitrofevr's Avatar
Jake, you suck Bro!
nitrofevr is offline Find More Posts by nitrofevr
Old Jan 01, 2013, 08:31 PM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
Right, 21 oz is perfect! Thanks!
Spaz
spastic is offline Find More Posts by spastic
Old Jan 01, 2013, 10:55 PM
FlattyFlier is offline
Find More Posts by FlattyFlier
Team LightRC
FlattyFlier's Avatar
Joined Dec 2003
Originally Posted by nitrofevr View Post
Jake, you suck Bro!
I know
FlattyFlier is offline Find More Posts by FlattyFlier
Old Jan 03, 2013, 03:25 PM
Jimmy Hoffa is offline
Find More Posts by Jimmy Hoffa
Jimmy Hoffa's Avatar
Orlando, FL
Joined Jul 2004
Sabre 35 Bush Plane
Check out these 4" GWS wheels for bush landings (aka: normal grass). They do weigh 8 grams vs 2 grams for the tiny stock wheels. For me the stock wheels only work well on pavement. Just about everything else ends with an endo. The other solution is to just hand catch it in a hover.
Jimmy Hoffa is offline Find More Posts by Jimmy Hoffa
Old Jan 03, 2013, 04:52 PM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
I went with larger wheels also for grass. The plane, actually, seems a little more stable in the air, and will taxi.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Jan 03, 2013, 07:58 PM
nitrofevr's Avatar
I pretty much only use landing gear to keep from breaking props.....
2012 probro video contest round 2 (3 min 11 sec)
Old Jan 03, 2013, 08:26 PM
Team LightRC
Joined Dec 2003
But you still break them
Old Jan 03, 2013, 09:10 PM
nitrofevr's Avatar
I order a couple dozen at a time
Old Jan 04, 2013, 04:47 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I try not to let the lg stop me from breaking props, but I fly like a wuss. I only order a dozen at a crack. Sweet vid, love the low snaps. Man I want to go slap mine around now, maybe this weekend. The forecast looks good, especially Sunday. My Sabre-X needs a good beating as well, I'm anxious to try out the new Xoar 15x6 prop. Feels like some serious pull with it.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jan 10, 2013, 04:33 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
i pretty much only use landing gear to keep from breaking props.....:d
schweet!!!
bildo baggins is offline Find More Posts by bildo baggins
Old Jan 13, 2013, 06:19 PM
claytucker2 is offline
Find More Posts by claytucker2
United States, CA, Redding
Joined Aug 2011
Hey Guys, Last yr sold my sabre 47 w/ saito 82 and gear, gave up on hobby for a while after drive to field was killing me, now getting back into it from scratch to fly at closer field/park.
I don't like expo, no need dual rates and can control throws mechanically with control arms/horns, so I was going all Hobbyking Turnigy: simple transmitter +RX 4X FHSS 2.4ghz, Accucel-6 50W 6A Balancer/Charger, AE-45A Brushless ESC, MG90S, 1300 30c 11.1, then the sabre 35e with the ST.10 apc 11.47, please let me know your opinions...
claytucker2 is offline Find More Posts by claytucker2
Old Jan 13, 2013, 06:26 PM
Burke, VA
Joined Sep 2009
All sounds good to me. If your at lower altitude you might try a 1060 DD prop, I'm pretty close to sea level and it works great for me.
Joined Aug 2011
Had good luck with hobbykings: Turnigy products in the past, most everything above is Turnigy. I am only going to build again if I can keep it under $200, hover well and staying with known quality parts.
Old Jan 13, 2013, 06:28 PM
Joined Aug 2011
thanks but I am just not sure about the $30 transmitter and Rx from Turnigy, sounds too cheap
Old Jan 13, 2013, 07:54 PM
sgomes is online now
Find More Posts by sgomes
Alameda, CA
Joined Dec 2006
I know it may put you over your budget, but I think you would be much better off in the long run getting a used DX7 or even 6i. In my opinion, a good reliable tx that one can count on is key to enjoying the hobby.
And, if you decide you want out of the hobby again, you shouldn't lose much on the resell.
Hope this helps.
Steve
sgomes is online now Find More Posts by sgomes
