Old Aug 10, 2012, 07:28 AM
FlattyFlier is offline
Find More Posts by FlattyFlier
Team LightRC
FlattyFlier's Avatar
Joined Dec 2003
I think me meant reflex when he said spoileron. But I did remember from the hood saying it's ke on this newer version is as near perfect as you can get.
FlattyFlier is offline Find More Posts by FlattyFlier
Old Aug 10, 2012, 07:36 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Yeah, I have a feeling I'm just over thinking this too much and doing something weird. I'll definitely keep at it till I get it right. When it comes to setting up a plane I'm really picky, the good thing about that is I do end up with some really nice flying planes. The reason I work so hard at this is because I hate flying without mixes and once a plane is set up properly the mixes just aren't necessary. If the only way to get a plane to fly to my satisfaction is by mixing, I just get rid of it and move on.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Aug 25, 2012, 11:49 AM
Team LightRC
Joined Dec 2003
a little late on this one but I found the pix of my gear.
I fixed the motor mount and wing this morning and took a short vid before the battery died.
Here's the link once its finished uploading:
Sabre35 woods 8 25 12 (3 min 28 sec)
Old Aug 25, 2012, 04:08 PM
Burke, VA
Joined Sep 2009
Sweet vid, you and them trees are just nuts. Man, I was really hoping you had figured out a new lg setup. Ah well, I'm still looking as well. If I find something I'll be sure to post.
Old Aug 25, 2012, 11:12 PM
Team LightRC
Joined Dec 2003
That's still stock. I'll order the crack legs soon.
Old Aug 26, 2012, 12:16 AM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Jake,
Through the tree....really. (vid 2:07+)
You have moved from Wood Hucker to......
Timber Dodger!
KE Spin is offline Find More Posts by KE Spin
Old Aug 29, 2012, 08:47 AM
roberted5 is offline
Find More Posts by roberted5
Joined Nov 2009
What APC prop for the Sabre 35ES?
I have a 200watt 1150Kv motor.What APC prop does the Sabre like?
roberted5 is offline Find More Posts by roberted5
Old Aug 29, 2012, 10:26 AM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Try a 10 x 4.7 apc slow flyer.
Old Aug 29, 2012, 05:15 PM
Burke, VA
Joined Sep 2009
I'm using a 1060 DD @ a little over 300 watts and it's crazy fun. The slofly is good too though, seems to transition from one maneuver to the next a little smoother but I just love the acceleration and power and efficiency of the DD a little better. Motor runs cooler an d better flight times with the DD.
Old Sep 03, 2012, 02:14 PM
p0stal is offline
Find More Posts by p0stal
ProBro Eric in Jax
p0stal's Avatar
United States, FL
Joined Mar 2006
or
10x3.8
p0stal is offline Find More Posts by p0stal
Old Sep 03, 2012, 10:20 PM
Team LightRC
Joined Dec 2003
Who's gonna make Nash?
Old Sep 15, 2012, 05:50 AM
Slow_Buzz is offline
Find More Posts by Slow_Buzz
United States, MO, Marshall
Joined Sep 2009
Hope you guys don't mind my posting this here. I don't have a Sabre, but am in the process of scratch building a similar flat profile. I've got an older gforce E400 1200 kv laying around that I'm considering using. My Eagletree is giving me numbers that calc out to a kv of 1263. I've tried a couple of prop runs. A GWS 10 x 4.7 SF gave me 10.82v 290w, and 7936rpm right until it yanked the collet adaptor off the end of the motor shaft. Second prop was a GWS 9x5dd. Yielded 10.9v, 237w, and 10,060rpm. I'm wondering if the 10 x 4.7 gonna be too much for this motor to handle long term? Only flying it will tell for sure. If the 9x5dd is not enough possibly a 10 x 6 dd might do the trick?
Dan
Slow_Buzz is offline Find More Posts by Slow_Buzz
Old Sep 15, 2012, 06:05 AM
Burke, VA
Joined Sep 2009
Dan
I would tend to think the 1060 DD would be a good bet, if the 10x4.7 works well as far as motor temp goes then the 1060 will work better. The DD props tend to be more efficient and easier on motors in my experience. Not saying they are always better, just depends on your flying style. For flat out 3D slofly's are better but for a mix of extreme aerobatics and 3D I prefer the DD props. Of course these are just my personal experience, mostly just try them and watch motor temp and fly what works best for you.
Old Sep 15, 2012, 06:11 AM
Joined Sep 2009
Thanks for the quick reply jet. Kinda what I was thinking on the 10 x 6. It's just I don't have one on hand at the moment. I'll probably fly it with the 2 size props I have on hand and see how goes. Not much flying time left in my season. A lot of my fall work takes most of the best flying days away from me.
Dan
Old Sep 15, 2012, 02:25 PM
Wulf_Flieger is offline
Find More Posts by Wulf_Flieger
ProBro Wulf
Wulf_Flieger's Avatar
Joined Oct 2006
Hey who left the damn door open here.
Wulf_Flieger is offline Find More Posts by Wulf_Flieger
