Old Nov 10, 2011, 04:29 PM
wyo69cowboy is online now
Find More Posts by wyo69cowboy
USA, WY, Cody
He beat me to it! Answered while I was typing lol
wyo69cowboy is online now Find More Posts by wyo69cowboy
Old Nov 10, 2011, 04:37 PM
p0stal is offline
Find More Posts by p0stal
ProBro Eric in Jax
p0stal's Avatar
United States, FL
Joined Mar 2006
Originally Posted by spastic View Post
We should have more any day now, just waiting for the truck
Any surprises in the truck headed to VH spaz?
p0stal is offline Find More Posts by p0stal
Old Nov 10, 2011, 04:40 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Are you getting motors too, I see they are out as well...
kirby
kepople is offline Find More Posts by kepople
Old Nov 10, 2011, 08:25 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
would an omega 72 g motor from 3dhs be to big for this?, I have on in the parts bin
3drcparts is offline Find More Posts by 3drcparts
Old Nov 10, 2011, 09:24 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Might be a touch big. Hard to move the battery back far enough to get good cg cuz the wing gets in the way. I'm using a 450 size motor.
Note: the 72g does not include mount and hardware so it really weights closer to closer to 85 or 90g.
KE Spin is offline Find More Posts by KE Spin
Old Nov 10, 2011, 09:34 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
true, just planing for the build..........once they are back in stock
Old Nov 10, 2011, 09:40 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
My 450 weights about 72g including hardware and I had to cut another hole in the fuselage to move the velcro to hold the battery back against the wing. Any farther and you would have to mount the battery under the wing. For reference I'm using 40c 1600mah Sky lipos.
Old Nov 10, 2011, 09:48 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
how about this,
http://www.headsuprc.com/servlet/the...ushless/Detail
with 1300 gens ace 3s and a 30 amp esc
Old Nov 10, 2011, 09:59 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Puts you in a smaller prop. The 450 size will get into a 11 x 3.8 that I'm using and likeing alot. I'm getting flight times over 11mins.
If you can get some 1500mah that might be ideal. 1300mah will do the trick but shorten flight time a bit.
Old Nov 10, 2011, 10:48 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
so what is the correct number, 2215/25 is a 400, what is a 450?
Old Nov 10, 2011, 10:56 PM
p0stal is offline
ProBro Eric in Jax
p0stal's Avatar
United States, FL
Joined Mar 2006
I've been using a e-flite 450 swinging a 11x3.8 always been happy with this setup.
Old Nov 10, 2011, 11:12 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Ditto..thats the one!!
The numbering systems between manufacturers are not always uniform but the Eflite 450 or one of similar power and weight would be great.
Try not to rely on the 22-15 type numbers so much. Use the weight and power specs and note the prop that is recommended for the motor you choose.
A general rule on on prop length is wing span divided by 4 so a 9" prop could work but if you can use a longer prop then do it as it allows more airflow over the surfaces for 3d and makes hovering a little easier.
Old Nov 10, 2011, 11:43 PM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
KE - what servos are you using?
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Nov 10, 2011, 11:44 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Metal Gear Towerpro's. They are listed as 9g but weigh closer to 13g.
Old Nov 10, 2011, 11:52 PM
Epoxy & CA Investor
Joined May 2010
thanks. how well do you think these would work?
http://www.hobbypartz.com/9gexidimeges.html
http://www.valuehobby.com/radio-syst...oge-servo.html
