Old Oct 02, 2010, 11:10 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Tim B,
You are a mad man. So you're going to have what..nearly 250 watts per pound?
KE Spin is offline Find More Posts by KE Spin
Old Oct 03, 2010, 08:07 AM
Tim B is offline
Find More Posts by Tim B
Pro Bro ozzy
Tim B's Avatar
United States, WY, Cheyenne
Joined Aug 2004
Originally Posted by KE Spin View Post
Tim B,
No, I'll prop down a little.
Tim B is offline Find More Posts by Tim B
Old Oct 03, 2010, 12:34 PM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
Tim B,
thats just about right, no need to prop down his batteries will be the limiting factor
spastic is offline Find More Posts by spastic
Old Oct 03, 2010, 12:50 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Just got back from flying mine at a field where they still burn that stanky stuff. Beautiful day in Ga
bildo baggins is offline Find More Posts by bildo baggins
Old Oct 11, 2010, 10:37 PM
frankfx is offline
Find More Posts by frankfx
San Bruno, CA (SF Bay Area)
Joined Oct 2003
Restock?
Anyone know when the Sabre 35ES will get restocked?
Joe
frankfx is offline Find More Posts by frankfx
Old Oct 12, 2010, 06:03 AM
Tim B is offline
Pro Bro ozzy
Tim B's Avatar
Joined Aug 2004
Joe
NOT soon enough.
If I remember correctly, about 30 to 45 days; If all goes well.
Old Oct 12, 2010, 09:05 AM
frankfx is offline
Joined Oct 2003
Rare commodity...
Originally Posted by Tim B View Post
NOT soon enough.
Is it my imagination or are 30 inch profiles plane very hard a to come by?
Old Oct 12, 2010, 10:11 AM
Tim B is offline
Pro Bro ozzy
Tim B's Avatar
Joined Aug 2004
Frank,
Yep, in balsa it's getting harder and harder.
In general, you have the
Sabre 35 and the Spaz Cap- both from Value Hobby.
Primo 15 and Mojo 25 Kits from Paul Swany at swanyhouse.com
The Skeeter series, free plans from Quicker of this site for scratch builders.
There are others but these are my favorites.
Finished mine up last week and got it up in the air, love the Sabre 35.
Just a straight build, the only change was to the landing gear. I change them into a MOJO 40 style landing gear. The mod on the gear is holding up great.
Tim
Old Oct 12, 2010, 10:20 AM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Hit me with that gear mod link if you would please.
Old Oct 12, 2010, 12:17 PM
Tim B is offline
Pro Bro ozzy
Tim B's Avatar
Joined Aug 2004
Here's a pic. I used a torch to the gear red hot and gave it a little twist to point forward. The legs still go in front of the little wood support peice. Drill a couple of elongated holes and your done.
I also used three of bigger straps about 1/4 of and inch.
Now a little white covering to fix my mistakes.
Hope this helps.
Tim
Old Oct 12, 2010, 12:33 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
I'm gonna have to source some CF gear or something. Lighter setup helps a lot but I still get gear splay and prop strikes on crappy fields no matter how light I drop her in.
Old Oct 12, 2010, 07:12 PM
spastic is offline
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
bend yourself a new set with some good 3/32 wire.. just make the part that goes into the fuse longer so it comes out the other side.. then it holds up.. and soak the ply area with thin ca... and fly it in a harrier and set it down nice and slow or hand catch from a hover
Old Oct 12, 2010, 07:59 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Like it's that easy! We're not all 3D senseis like you Spas man
Old Oct 12, 2010, 10:19 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Precision Aerobatics has a nice little 30" profile
You can always try the Yak from Common Sense RC
Texasrcplanes has a nice little plane called the Reflex
Old Oct 13, 2010, 12:17 AM
frankfx is offline
Joined Oct 2003
Thanks...I ordered the PA Electric Shock..a little expensive but it matched
the gear that I have on hand...
