Old Nov 18, 2009, 12:32 PM
Lead Wings is offline
Find More Posts by Lead Wings
I enjoy the voices
Lead Wings's Avatar
Perth, Australia
Joined Apr 2007
I found the following really helpful when I started with the HK 450 at the beginning of the year (had virtually no heli expereince before that, just fixed wing experience):
Electric heli Beginners guide - good background on heli concepts etc http://www.swashplate.co.uk/html/ehbg.html
Horizon Hobby Align T-rex 450 SA Builders Guide - matches what you get out of the HK450 box pretty much exactly
http://www.e-fliterc.com/ProdInfo/Fi...ARF_Manual.pdf
Finless Bob Videos - lots of great how to info (need to join helifreak) http://www.helifreak.com/showthread.php?t=11373
Ive also attached a locktighting guide and tools guide from a while back that may be of use
Lead Wings is offline Find More Posts by Lead Wings
Old Nov 18, 2009, 12:56 PM
MrRetro is offline
Find More Posts by MrRetro
MrRetro's Avatar
NYC, NY
Joined Jul 2007
Anyone have any issues/problems with the HK tail shafts with the plastic pulley? They are not very expensive and come 2 to a package, and BOTH shafts have the pulley installed. The similar CopterX and EXI parts come 3 to a pack but only ONE has the pulley (metal) installed. Since I don't usually have any success in removing that pulley to reinstall on another shaft, I look at is as I only get 1 shaft per pack. So are these any good?
MrRetro is offline Find More Posts by MrRetro
Old Nov 18, 2009, 04:06 PM
guitaramp68 is offline
Find More Posts by guitaramp68
guitarflyer
Joined Feb 2009
im using hxt900 servos.should i use the 15.mm lenght from center to ball joint
on the servo horn for hs-65
guitaramp68 is offline Find More Posts by guitaramp68
Old Nov 18, 2009, 04:20 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Be forewarned, the hardware really sucks badly and you will need some REALLY REALLY Good Allen wrenches to work the project.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Nov 18, 2009, 05:06 PM
Foam Planes is offline
Find More Posts by Foam Planes
Denmark
Joined Dec 2007
As I understand most radios have a 5 point or more throttle/pitch curve setting.
My radio only has 3 points. Is 3 points ok for the HK450 or should I buy a new radio?
Iím a total newbie to heliís so bear with me.
Foam Planes is offline Find More Posts by Foam Planes
Old Nov 18, 2009, 05:12 PM
JRexA is offline
Find More Posts by JRexA
Nuuk, Greenland
Joined Oct 2006
I use the GorillaProof(r) wrenches
JRexA is offline Find More Posts by JRexA
Old Nov 18, 2009, 05:26 PM
shizack is offline
Find More Posts by shizack
Piro-maniac
shizack's Avatar
United States, FL, Winter Garden
Joined Feb 2007
5 point curves are nice, though not strictly a necessity. Until you get good at hovering you probably won't feel too much that needs that intermediate point.
Even now all my curves (5-point) are set so that point 2 is equidistant from points 1 and 3 and point 4 is in the middle of points 3 and 5.
It's nice to have the flexibility to tweak if needed, but I haven't "needed" yet.
What radio do you have?
shizack is offline Find More Posts by shizack
Old Nov 18, 2009, 05:50 PM
dze is offline
dze
Find More Posts by dze
dze
on the trex style shaft with an aluminum pully if you support the pully on somthing like a drilled piece of wood, the shaft will drive out fairly easily .. to re-install the pully on another shaft you can use red locktite or ive used jb weld to when installing the pully to a smooth shaft with a cutout relief , and then let it set up overnight. .. if the pully is tight on reinstallation use somthing like a socket that fits over it good and your piece wood again so the shaft tip doesnt get marred and tap it into place nice and slow, and hopefully you have another one to compare it to or remembered to measure how far on it was
dze is offline Find More Posts by dze
Old Nov 18, 2009, 06:17 PM
ewoodcox is online now
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
I bought several align hardware kits, honestly, I like the HK450 screws better, they used Hex heads but the Align had crosspoint screwdriver heads. I used some of both but was impressed with the HK450 hardware. I've heard people complain about this before so not sure if I just got lucky
ewoodcox is online now Find More Posts by ewoodcox
Old Nov 18, 2009, 06:28 PM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
i use a pinion puller to remove and a modified c-clamp to re-press. dze's wood method is probably easier on the aluminum.
sonicj is offline Find More Posts by sonicj
Old Nov 18, 2009, 06:33 PM
loopy1 is offline
Find More Posts by loopy1
Dyslexic crash pro!
Westminster, CO
Joined Jun 2008
MrRetro,
I had to knurl and locktite the pulley to the tail shaft on my original parts. I was able to spin the tail rotor shaft while holding the main rotor still (and also with the tail drive, jack-shaft (a known problem with the earlier kits)). The shafts I've gotten since then have held pretty well.
You shouldn't have that much of a problem changing the metal pulley over on the other shafts (if you choose to go that way). Just support the pulley with a small deep socket and drive the old shaft out, then press the new shaft in. You can even tap the new shaft in with a hammer if you're careful.
I use an arbor press, but not everyone has one. You can use a drill press too if you have access to one.
/Dave
loopy1 is offline Find More Posts by loopy1
Old Nov 18, 2009, 06:57 PM
Hellysmack is offline
Find More Posts by Hellysmack
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Me too
I think it depends a lot on your tools, and making sure hex driver is fully in. I have no problem.
Hellysmack is offline Find More Posts by Hellysmack
Old Nov 18, 2009, 07:12 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I have not had any problems with the stock tail shaft/plastic pulley.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Nov 18, 2009, 07:17 PM
Joined Aug 2009
What is the name brand of your hex head wrenches? I need to purchase a set.
Old Nov 18, 2009, 07:21 PM
ChrisWNY is offline
Find More Posts by ChrisWNY
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
The Dynamite hex drivers are top notch, I have a set of them (1.5mm, 2.0mm, and 2.5mm), shafts are hardened steel and interchangeable in case they ever wear. You can find them on eBay at reduced prices. I use them frequently on all 450 hex head screws. No issues with stripping.
http://www.dynamiterc.com/Products/D...ProdID=DYN2904
ChrisWNY is offline Find More Posts by ChrisWNY
Zagi-Flash5x-EPA have to be same for aileron and elevators Balin Foamies (Kits) 2 Sep 10, 2001 08:04 PM
Will CP 1300 cells be ok for this? Steve H. Power Systems 15 Jul 17, 2001 09:01 AM
Home for a 450 Turbo dezflyer Electric Plane Talk 6 May 31, 2001 01:04 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
Soarstar what mods. need to be done for a succesful flight? JEWINE Foamies (Kits) 10 May 06, 2001 08:36 PM
