Old Oct 25, 2010, 07:03 PM
i812 is online now
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Wow, are we looking at the same graph? post 17226?
If so, what I see representing what appears to be the horizontal axis legend is:
Time (s)
0..... 24.6 ..... 49.3 .... (etc)
Plenty (about 25?) of zig-zag (line data points) between 0 and 24.6
Maybe I mis-stated the word "tick". I'm considering a 'tick" as the smallest time division, meaning the difference in time between each neighboring data point. When I read the above post about there only being 15 ticks, I noticed we must have a difference in vocabulary. I was referring to that as a "major" time division. Sorry for the confusion (if any), I'm not a professor. I don't know the proper names, and assumed my wording was clear enough by the way I structured my sentences.
And yes, 54 and 80*C seems high for non-heat type of electrical equipment. But I'm a newbie, and haven't even fired up a 450 ESC, let alone measure their temperatures.
Thanks for sharing
i812 is online now Find More Posts by i812
Old Oct 25, 2010, 07:11 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
The ticks I was referring to are the graph lines.
The points on the graph look to be recorded once a second.
Edit:
Point I was making was that there will most likely always be 15 graph lines or "ticks" as they were referred to. I've since went and looked at several graphs online from various superbrains and apparently the theory was correct, always 15 graph lines no matter what the flight time, so the interval between the graph lines will vary from flight to flight.
Hope that clarifies things.
Barak1001 is offline Find More Posts by Barak1001
Old Oct 25, 2010, 07:28 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
Never thought the graph was going to cause so much debate and analysis! I'do like to see your graph rg....
for those that st really interesed I can post the data file and you can install the reader and do further analysis on it.
It makes me want go back down to a 11 t pinion... And install that heat sink.
Might do that next time I open up the fuse.
captaingeek is offline Find More Posts by captaingeek
Old Oct 25, 2010, 07:34 PM
i812 is online now
i812's Avatar
Joined Aug 2009
Edit:
Yes vocabulary issues. Easy to resolve with prior agreements of definitions.
I don't consider locations of Graph Lines too important. To me, the step size (what I was calling a "tick") between data points is critical. In this case, the 1 second interval between data samples maybe a very important consideration if someone was trying to find a smaller spike that could cause a RX to glitch.
Anyway, it is not my problem (if there is even a problem). I'm happy to have gotten exposed to the SuperBrain graph, and high temperature characteristics.
Old Oct 25, 2010, 07:51 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
hey guys , i know i posted that the hk401gyro was crap but now i need to eat those words because the one on the 250 is working flawlessly . so i guess its a good cheap gyro but buy a couple because you may have a few duds before one works . so in reality 2 gyros were bad and 1 works great , so it cost me say 40.00 a working gyro . on a different note ,has anyone tryed the new turngy gyro out ?
http://www.hobbyking.com/hobbyking/s...dProduct=11958
jombo is offline Find More Posts by jombo
Old Oct 25, 2010, 08:12 PM
RG2000 is offline
Find More Posts by RG2000
RG2000's Avatar
Australia, SA, Adelaide
Joined Jul 2007
Captingeek here you go, 11t rocks for flight time ~8-9 minutes soft flying.
Also zoomed in to show people the resolution
FYI the sample rate is on the top right in samples/sec (it says pm for some reason?)
This can be set at up to 30 per second at the expense of recording time...
RG2000 is offline Find More Posts by RG2000
Old Oct 25, 2010, 08:41 PM
USA, CA, Novato
Joined Jul 2008
nice thanks for that. here's one i did tonight with some crazey pitch pumps. ambient temps tonight are a lot cooler.
Old Oct 25, 2010, 08:44 PM
USA, CA, Novato
Joined Jul 2008
mainly just show and tell, not really trying to solve a problem. was just kidding about the professor comment.
Old Oct 26, 2010, 12:50 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Probably not much air movement inside that fuse. You could try to put on one of the small fans used on PC motherboard chipsets.
I have a Superbrain, but no success so far in getting connection to the PC. I'm trying with a HXT USB key though.
Fred
flarssen is offline Find More Posts by flarssen
Old Oct 26, 2010, 02:04 AM
RG2000 is offline
RG2000's Avatar
Joined Jul 2007
Fred
What com port is the key set to? Look in device manager. It must be 0-9 or you'll never get it to connect
Old Oct 26, 2010, 05:28 AM
Wade1 is offline
Find More Posts by Wade1
Australia
Joined Jul 2008
Lads, been trying to hunt down a vibration/twitch that I have been getting. When the main blades are off, I spool the heli up and there is no vibration/twitch at all. With the blades on, the tail vibrates quite a bit before the heli takes off and then it has a random on and off twitch like vibration.
I have balanced the blades twice and they seem ok. could there be something else wrong with these blades causing this ?
Wade1 is offline Find More Posts by Wade1
Old Oct 26, 2010, 05:41 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
are they tracking? have you tried other blades?
pitchp is offline Find More Posts by pitchp
Old Oct 26, 2010, 07:17 AM
Wade1 is offline
Australia
Joined Jul 2008
yep they are tracking ok and have changed blades. still does it.
I have got my gyro set to 60% in HH mode. At this percentage, the wag seems pretty fast and at around 56% its still there but kinda softer and slower.
does this sound like a vibration problem ?
Old Oct 26, 2010, 07:34 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
put her on rate mode 30%, does she wiggle her tail
Old Oct 26, 2010, 08:05 AM
Wade1 is offline
Australia
Joined Jul 2008
at 30% in rate mode the tail wags like mad. But as in...gyro not set up wagging.
when I bump it up to 40% in rate the wag/twitch is hardly there. Might see a TINY bit of movement in the tail every now and then but no where near as much as it is in HH mode.
what does this determine ?
Zagi-Flash5x-EPA have to be same for aileron and elevators Balin Foamies (Kits) 2 Sep 10, 2001 08:04 PM
Will CP 1300 cells be ok for this? Steve H. Power Systems 15 Jul 17, 2001 09:01 AM
Home for a 450 Turbo dezflyer Electric Plane Talk 6 May 31, 2001 01:04 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
Soarstar what mods. need to be done for a succesful flight? JEWINE Foamies (Kits) 10 May 06, 2001 08:36 PM
