Old Oct 22, 2010, 11:07 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
jagsta: that's what you need, similar to RS's setup. You get the best of both worlds. High HS, and very good flight time. Nice
pitchp is offline Find More Posts by pitchp
Old Oct 23, 2010, 12:19 AM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
from today
md 500 edit (5 min 1 sec)
captaingeek is offline Find More Posts by captaingeek
Old Oct 23, 2010, 01:02 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
CG man that is awesome stuff right there!!!
just check your tracking
also what video camera are you using. I need one to film my rigs
Old Oct 23, 2010, 02:23 AM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
Looks like you've ironed out the ESC issues.
Barak1001 is offline Find More Posts by Barak1001
Old Oct 23, 2010, 02:39 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Hey CG, do you have trouble seeing that against the background of dark green foliage. Camo fuse seems like a crazy idea to me. (probably just my old eyes)
Harrow is offline Find More Posts by Harrow
Old Oct 23, 2010, 06:09 AM
jagsta is offline
Find More Posts by jagsta
Bradford, UK
Joined Sep 2010
Yeah this is what i'm thinking, plus, I can run either 3s or 4s to get a low (sport/hovering) headspeed or a higher one for 3d with the same pinion on the motor.
Has anyone tried the turnigy 2215 on 4s? It says it supports it on HK. The 1800mAh packs are a little bit more expensive than the 2200 3s but for better power, lower current (and therefore temp) it seems worth it.
I should get around 2600 on 3s, 3400 on 4s with an 11T on that motor I think.
jagsta is offline Find More Posts by jagsta
Old Oct 23, 2010, 11:46 AM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
i would not run a 3500+ kv motor on 4S. I do it on a pusher jet and it sounds like it will fall apart. But on the heli? Run the numbers thru the calculator..
1800ma 4S 11t 3500kv = 3880 rpm. I wouldn't. It's really easy to switch motors.. get one that's 2700 kv, use velcro instead of zip ties and leave a pinion on each motor. swap it out in 5 minutes.
rocketscience is offline Find More Posts by rocketscience
Old Oct 23, 2010, 11:58 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
might as well just get another kit. no need for swapping
Im busy with my third attempt at a night rig..... hope i wont crash it this time.
sp00fman is offline Find More Posts by sp00fman
Old Oct 23, 2010, 04:27 PM
hugovanleeuwen is offline
Find More Posts by hugovanleeuwen
Joined Jan 2007
Originally Posted by mountainsax View Post
Anyone tried this Turnigy ESC? I'm thinking of buying either this one or the plush 40A.
Ethan
It looks like a copy of an older version of a Hyperion ESC. Watch out! It has a limited speed. The maximum speed is not enough for an 450 heli. Only if your a beginner and you want a headspeed of 2600 RPM, it will be usable.
hugovanleeuwen is offline Find More Posts by hugovanleeuwen
Old Oct 23, 2010, 04:41 PM
Joined Jan 2007
anyone here using this? http://www.rcdude.com/servlet/the-11...l-Servo/Detail
short review about this servo as a cyclic servo?
also it mentions that i can choose to have metal gears as oppossed to carbon poly? which one is the best out of the two?
many thanks
I'm using a HP-DS09GMD as a tail servo on my GAUI Hurricane 200. In combination with a Logictech LTG 2100T gyro, it is the best servo ever.
I don't know how it will be as a cyclic servo on a 450. It is quite expensive and this forum is about going cheap. Way not HTX900 or MD933.
Old Oct 23, 2010, 05:07 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
hugo: I'm planning to use it on my smaller birds(cyclics+tail).
http://www.rcgroups.com/forums/showthread.php?t=1120372
as for my 450s I'll be getting the DS11-gcbs(cyclics+tail)
as for the hxts i currently use them, and the md933 just come back in stock today in HK! that will run out fast.
Old Oct 23, 2010, 05:10 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
RS: i'm lost there, what do you use the velcro for?
Old Oct 23, 2010, 06:19 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
To hold the motor wires against the side of the frame so they aren't flopping around in flight.
Old Oct 23, 2010, 06:20 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
what's wrong with zip ties?
Old Oct 23, 2010, 06:21 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
He was saying use velcro instead of zip ties so you don't have to cut the zip ties and put new ones on every time you change out the motor.
Get it now?
Zagi-Flash5x-EPA have to be same for aileron and elevators Balin Foamies (Kits) 2 Sep 10, 2001 08:04 PM
Will CP 1300 cells be ok for this? Steve H. Power Systems 15 Jul 17, 2001 09:01 AM
Home for a 450 Turbo dezflyer Electric Plane Talk 6 May 31, 2001 01:04 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
Soarstar what mods. need to be done for a succesful flight? JEWINE Foamies (Kits) 10 May 06, 2001 08:36 PM
