Old Oct 22, 2010, 06:04 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Originally Posted by captaingeek View Post
thanks! here she is in action http://www.youtube.com/watch?v=Zmlz1BBB4UE
CG: that is awesome
pitchp is offline Find More Posts by pitchp
Old Oct 22, 2010, 11:59 AM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
thanks! sorry for the crap quality. it is a HD video cam but it was dark out. i figured out that this crap turnigy superbrain 40A keeps overheating and shutting down on me. Tried using the governor mode but Im not sure how that's supposed to work.
its supposed to be raining all weekend ..
I think im going to have to install the windows on my fuse and see how it does in the rain
If I could just figure out how to get this ESC right. It keeps shutting down on me and im no where near 40A.
captaingeek is offline Find More Posts by captaingeek
Old Oct 22, 2010, 12:44 PM
USA, CA, Novato
Joined Jul 2008
anyone else fly in the rain?
Old Oct 22, 2010, 01:18 PM
hugovanleeuwen is offline
Find More Posts by hugovanleeuwen
Joined Jan 2007
My Turnigy Superbrain 40A does the same. I now installed an extra UBEC so my receiver will always get power.
The Turnigy Superbrain already shuts down at 50 degrees. And my current is only 17 A.
It was very bouncy in governor mode, so I switched that off.
hugovanleeuwen is offline Find More Posts by hugovanleeuwen
Old Oct 22, 2010, 01:29 PM
USA, CA, Novato
Joined Jul 2008
yep im running a external bec as well. avoid this esc if your flying heli.
Old Oct 22, 2010, 01:34 PM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
Is it brown out ? if so a cheap bec will fix it quick smart
Magic k2 is offline Find More Posts by Magic k2
Old Oct 22, 2010, 02:51 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
I wonder if it has a current limiting option that can be disabled or turned down? I know the Phoenix ESC have a cutoff that works similar to this, but it can be adjusted for when you're flying a helicopter.
Barak1001 is offline Find More Posts by Barak1001
Old Oct 22, 2010, 03:04 PM
USA, CA, Novato
Joined Jul 2008
It does maybe you guys can help me make sense of the instructions...
here's the specs, I wonder if these are at sub zero temps!
Spec.
Constant Current: 40A **** <- LIES!!!!
Burst Current: 50A *** yea right
Battery: 2-3S Lipoly
BEC: 5V/2A Linear
Here's the manual. Its pretty short and fairly well writtend. Settings details at end.
http://www.hobbyking.com/hobbyking/s...40A_online.pdf
Current Limiting
NOTE: Default setting is recommended. If you change the setting, damage to the controller as a result of over
current will be not covered by the manufacturer’s warranty.
Brake Type
Option 1: Very Sensitivity
Low over-current threshold, will rapidly shut-down.
Option 2:Standard(default)
Moderate over-current threshold, will shut down after a slight delay.
Recommended for inrunner motors.
Option 3:Insensitivity
High over-current threshold, will shut down after a slight delay.
Recommended for outrunner motors. Only experienced modelers
should use this programming feature
Option 4: disabled
Current limiting detection disabled. Only experienced modelers
should use this programming feature.
Old Oct 22, 2010, 03:06 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
You need to change it to insensitive or to disabled, which is what they recommend for choppers on the Phoenix ESC as well.
Old Oct 22, 2010, 03:07 PM
USA, CA, Novato
Joined Jul 2008
THANKS! am thinking of installing a bigger heatsink as well...
Old Oct 22, 2010, 03:13 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
Do you have the USB link for it or a programming card? The standard programming card won't work with it, you have to have the one for the superbrain.
Old Oct 22, 2010, 03:14 PM
USA, CA, Novato
Joined Jul 2008
you can program it with the tx
Old Oct 22, 2010, 03:15 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
You can, but it easier to do it with a card. I've never flown the superbrain, I've always flown the plush models. Had pretty good luck with them.
Old Oct 22, 2010, 03:30 PM
i812 is online now
Find More Posts by i812
i812's Avatar
Joined Aug 2009
As Magic posted, if the problem is RX Brownout, then the problem with that 40A/2A ESC may not be with the 40A ESC portion, but the 2A BEC portion.
I think for the 450, many recommend 3A or higher BEC, depending on how fast the Servo's are.
Here are some cheap HK 40A/3+A ESC's:
(I haven't tried any, since I haven't put the kit together yet)
Mystery 40A/4A Speed Controller (Blue Series)
TURNIGY Plush 40A/3A Speed Controller
i812 is online now Find More Posts by i812
Old Oct 22, 2010, 03:44 PM
USA, CA, Novato
Joined Jul 2008
i dont know know if thats directed at me or what but im running a seperate bec.
Zagi-Flash5x-EPA have to be same for aileron and elevators Balin Foamies (Kits) 2 Sep 10, 2001 08:04 PM
Will CP 1300 cells be ok for this? Steve H. Power Systems 15 Jul 17, 2001 09:01 AM
Home for a 450 Turbo dezflyer Electric Plane Talk 6 May 31, 2001 01:04 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
Soarstar what mods. need to be done for a succesful flight? JEWINE Foamies (Kits) 10 May 06, 2001 08:36 PM
