Old Oct 21, 2010, 06:28 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
My manual states that you dont need all that on a 450 size heli. Only the 3mm pad. I am 1/2 tempted to try both pads and the plate though just to see if it makes a difference
losifanatic is offline Find More Posts by losifanatic
Old Oct 21, 2010, 07:24 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
Originally Posted by gtfreeflyer View Post
Which LiPo are you using that has zero voltage drop under load, and maintains a full charge after spool up and lift off? I want one of those!
No one said it was exact. I actually took off 15% due to the efficiency of the motor being in question, pretty sure that's good enough. Also no one said it would stay that way from lift off to landing.
Even if you do the math at 11.1v his head speed is greater than 3000 rpm and it's no wonder that his flight times are so short.
Why is it that people on a forum tend to try and nitpick things that should be common sense?
Barak1001 is offline Find More Posts by Barak1001
Old Oct 21, 2010, 09:24 PM
mountainsax is offline
Find More Posts by mountainsax
Fix, Fix, Fly, Fix, Fix, Fly
mountainsax's Avatar
Colorado
Joined Apr 2009
Thanks for the link to the head speed site! I'll give it a shot this weekend. I don't have a cell phone so I'll have to use the laptop...and not hit the computer with the heli!!
mountainsax is offline Find More Posts by mountainsax
Old Oct 21, 2010, 09:28 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
could you help me calculate my HS? i have this motor:
http://www.hobbycity.com/hobbycity/s...idProduct=8138
captaingeek is offline Find More Posts by captaingeek
Old Oct 21, 2010, 09:31 PM
USA, CA, Novato
Joined Jul 2008
ohh with a 14 t pinion
Old Oct 21, 2010, 09:43 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
I gave the formula for it last page. Not that hard to do.
Old Oct 21, 2010, 10:11 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
I went the full hog...3mm foam - steel plate - 1mm foam - gyro. Works fine, but having said that, probably would have worked just as well with only the 3mm like the manual says, and would have saved 8 grams.
Harrow is offline Find More Posts by Harrow
Old Oct 21, 2010, 10:12 PM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Well, after putting it off for weeks, this morning I finally joined the "flip" club. Got them going forward, backwards and sideways on both the HK450 and Walkera HM-1#A, plus a few loops for good measure. And to make it even better, brought them both home in one piece. I'm stoked!!
No video unfortunately, but definitely next week.
Old Oct 21, 2010, 10:31 PM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
headspeed calc 1
headspeed calc 2
Presets for trex 450 on both
rocketscience is offline Find More Posts by rocketscience
Old Oct 21, 2010, 10:54 PM
USA, CA, Novato
Joined Jul 2008
thanks! here she is in action
trex 450 gt pro md 500 hughes scale heli (3 min 17 sec)
Old Oct 21, 2010, 11:38 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
According to Heli Headspeed you're running about 3850 rpm. I just used the mic to check it while the video was playing.
Edit:
Just ran it through again and it's showing 2200 head speed. Apparently the audio isn't clear enough for it to be accurate?
Edit 2:
Apparently 2200 is what it actually is. I moved the mic closer to the speaker and ran it through again. That's if the program is actually accurate (I haven't got a visual tach to use to locally to test the accuracy of the program).
Old Oct 21, 2010, 11:45 PM
USA, CA, Novato
Joined Jul 2008
whoppers didn't mean to go that high!! Guss I have to treat it apart again rip get to the motor
Old Oct 21, 2010, 11:46 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
Look up again, apparently the readings were off because of how I had the mic. Your headspeed is pretty stable at 2200 rpm when you're hovering (If this program is accurate anyway).
Old Oct 22, 2010, 04:07 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Captaingeek, I would recommend spending $10 at Hobby King and getting yourself an optical tacho. No more guess work.
http://www.hobbyking.com/hobbyking/s...dProduct=10783
Old Oct 22, 2010, 05:45 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
CG man:
With 2200mah 3s lipo?
Calculated HS @ 100 % throttle:2818
But that's not what you'd be running you would be running this
Calculated HS @ 85 % throttle: 2395
Now give and take the resistance from the blades, the load, and you're not using a governor, etc etc... hence you're actual HS at the time of the vid is 2200, and that's fine. 2100-2200 perfect for scale
Also do your calculations first before you buy the heli stuff
pitchp is offline Find More Posts by pitchp
Zagi-Flash5x-EPA have to be same for aileron and elevators Balin Foamies (Kits) 2 Sep 10, 2001 08:04 PM
Will CP 1300 cells be ok for this? Steve H. Power Systems 15 Jul 17, 2001 09:01 AM
Home for a 450 Turbo dezflyer Electric Plane Talk 6 May 31, 2001 01:04 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
Soarstar what mods. need to be done for a succesful flight? JEWINE Foamies (Kits) 10 May 06, 2001 08:36 PM
