Old Sep 18, 2010, 11:10 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Originally Posted by sandos View Post
What would cause massive amounts of wag in rate mode, but not HH mode?
Weird, I have the exact opposite problem. Wagging in HH, but not in Rate. Although for me the wag is only when I pick up speed in a dive, such as in the downline run after a stall turn.
Harrow is offline Find More Posts by Harrow
Old Sep 19, 2010, 06:05 AM
rikybob is offline
Find More Posts by rikybob
AMA# BR549
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
There may be something that you haven't considered.
Have you tried the duckweight?
b
rikybob is offline Find More Posts by rikybob
Old Sep 19, 2010, 07:10 AM
vinay2070 is offline
Find More Posts by vinay2070
vinay2070's Avatar
India, KA, Bangalore
Joined Sep 2009
Check the vibrations where the gyro is mounted.
vinay2070 is offline Find More Posts by vinay2070
Old Sep 19, 2010, 11:08 AM
sandos is offline
Find More Posts by sandos
Sweden
Joined Jan 2010
b
Uh, what is that? Same thing as, or related to chinese weight mod? I do have "extra long" screws through the blades, I thought it should atleast even it out a bit.
sandos is offline Find More Posts by sandos
Old Sep 19, 2010, 11:19 AM
rikybob is offline
AMA# BR549
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
Check Friday the 1st. I love that old bit from the Three Stooges.
Sorry!
b
(Crickets)
oh well
Old Sep 20, 2010, 05:03 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Hmm, is it possible to have TOO much foam. I put three layers. And why only in HH. ??
Old Sep 20, 2010, 05:50 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Yeah you can have to much . Play around with it and see if that helps
losifanatic is offline Find More Posts by losifanatic
Old Sep 21, 2010, 04:40 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
im working on a scale md500 http://www.hobbyking.com/hobbycity/s...dProduct=10111 build. has anyone else done this build? running a turnigy typhoon 3550 motor. im going to adjust the throttle and pitch curves for scale flying.
captaingeek is offline Find More Posts by captaingeek
Old Sep 22, 2010, 02:46 AM
Wade1 is offline
Find More Posts by Wade1
Australia
Joined Jul 2008
is there such thing as hands off hover for 450 sized helis ?
Wade1 is offline Find More Posts by Wade1
Old Sep 22, 2010, 02:53 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
it can and it has been done, on a still day, with the right set up.
pitchp is offline Find More Posts by pitchp
Old Sep 22, 2010, 03:01 AM
sandos is offline
Sweden
Joined Jan 2010
It would likely help with a flybarless system, but it will not give unlimited stability. Otoh, neither does any other size helicopter without a stabilization system? Its just a matter of timescale, a 700 might be a more stable than a 450, but still not inherently stable.
Old Sep 22, 2010, 04:10 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Well I have the 4#3b, and the 4g3, and I have finally modified both of them that they almost hover like my bmcx. almost 8 seconds with out stick input. Now they are both small birds, with suicidal tendencies. Now that I have modified them, it's as if they are on prozac.
Oh and wade1 it will take months to dial in such a bird. I'm assuming you just started in the hobby? Everything must be set precisely. But doing that can be meticulous, but it pays off though. You get more time learning how to fly, rather than trying to get your bird to do what it's supposed to do..
Old Sep 22, 2010, 04:15 AM
sandos is offline
Sweden
Joined Jan 2010
I've managed maybe 5 seconds tops on my 450, but that was actually before I had a swash leveler
Old Sep 22, 2010, 04:37 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
That's really good for an HK 450. Is that the plastic version? Did you modify any thing? atm I'm trying to get my hk250 to behave it's tail. The gyro is really cheap and nasty, it's got this twitching condition. Hey is it me or do you think I have a bent feathering shaft on my hk450 plastic version? It's one of the very first one that came out.
Old Sep 22, 2010, 04:38 AM
Wade1 is offline
Australia
Joined Jul 2008
I am fairly new to 450s and having trouble holding a steady hover. I am always having to hold elevator stick down a bit and a bit of right cyclic. but whe cog seems pretty good when I hold it by the fly bar.
Also, what would cause the tail to slightly jerk a bit ? just randomly the tail looks like it jerks a small amount. nothing major. could gusts of wind cause this ?
Zagi-Flash5x-EPA have to be same for aileron and elevators Balin Foamies (Kits) 2 Sep 10, 2001 08:04 PM
Will CP 1300 cells be ok for this? Steve H. Power Systems 15 Jul 17, 2001 09:01 AM
Home for a 450 Turbo dezflyer Electric Plane Talk 6 May 31, 2001 01:04 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
Soarstar what mods. need to be done for a succesful flight? JEWINE Foamies (Kits) 10 May 06, 2001 08:36 PM
