This thread is privately moderated by CaseySP, who may elect to delete unwanted replies.
Old Jan 01, 2009, 05:57 AM
CaseySP is offline
Find More Posts by CaseySP
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Alfa P47 Crash and Repair Part 2
Well, as I said in part 1, there was a twist to the tale. The P47 hit the dust again, this time it was my fault from a dud hand launch, leading to a torque roll into the ground. The nose was broken (but not as bad as last time), firewall destroyed, the cowel broken and flattened, the port (left) wing broke off and the port (left) tailplane was cracked at the fuselage and the top and bottom had separated at the trailing edge (perversely this proved to be a bonus).
I put it aside for a number of months while I flew my Alfa Corsair and MiG15, and worked on the GWS FW190 making it look more like an Alfa and less like a GWS.
Repairs were carried out much as before. The wing spar was doubled with a cut down ice-block stick, the wing skins doubled with 3mm depron along the breaks and the push rod straightened and re-fitted.
The tailplane was fixed by inserting a carbon rod through the opened up trailing edge to act as a spar, the elevator re-glued to the spruce joiner, and finally the trailing edge was resealed.
The cowel was fixed by taping up the inside, CA, and light weight filler. The outside was then covered in a layer of silkspan and WBPU. The fuselage was patched with depron, cracks filled with lightweight filler and given a good sand.
Finally, a new balsa battery tray was made up to replace the original ply one which was damaged after the crash. The new one is a copy of the one fitted to the Alfa MiG15. And of course a bungee hook is now fitted so this never happens again
After a successful (re)maiden the patched areas were repainted and new decals made to replace those lost in the crash and repair process.
CaseySP is offline Find More Posts by CaseySP
Old Jan 01, 2009, 02:18 PM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Better man than me. I woulda just bought a new one.
Dora Nine is offline Find More Posts by Dora Nine
Old Jan 01, 2009, 05:21 PM
CaseySP is offline
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Yea Dora, I guess in a way I sort of did with the new Corsair and MiG. But after a few months I decided to pull it out and give it another go.
My next step is to re-paint the Corsair in New Zealand colours, so I need something to fly while it's being refurbished . Something like this...
Old Jan 01, 2009, 06:30 PM
Stuart Warne is online now
Find More Posts by Stuart Warne
Durafly Brand Manager
Stuart Warne's Avatar
Hong Kong, Hong Kong Island, Central And Western District
Joined May 2001
Good job casey, got to keep them flying. Look forward to seeing the Corsair when done. Be sure to post you work in the Alfa thread.
All the best,
Stuart
Stuart Warne is online now Find More Posts by Stuart Warne
Site Sponsor
Old Jan 01, 2009, 10:58 PM
CaseySP is offline
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Thanks Stuart - will do. Flew the P47 this morning. The old MP Jet "Big Blue" (28/7 - 35D) wouldn't pull the skin off a rice pudding and the plane just limped around the sky. Could barely loop and any sort of climbing greater then 15 degrees was out of the question.
Seems to have a bad bearing noise, possibly from the crash. I pulled the motor apart and am trying to clean them out (they seem to be double shielded type - not sealed, so whatever is in there may hopefully come out). I can source some new ones locally if necessary, but for little more then twice the cost of the bearings I could get the same motor as I have fitted to the Corsair. This gives the Corsair unlimited vertical and loops as large as you like. What to do....?
Discussion Alfa P47 Crash then repair CaseySP Crash Discussion 10 Feb 26, 2008 05:08 AM
Alfa FW 190a-8 Part 2 Michael Heer Parkflyers 163 Jul 19, 2006 09:14 AM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 02:00 AM
MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) MicroRotors Electric Heli Talk 10 Jul 27, 2001 03:19 PM
