Old Jan 15, 2009, 01:15 PM
sargentw is offline
Find More Posts by sargentw
"SARGE"
sargentw's Avatar
Fairfax Station, (Northern) Virginia
Joined Jun 2003
Originally Posted by FIXXIN2FLY
Hey Sarge
Did you get on the backorder list? Also assuming youre putting it on your ez, what esc are you gonna complete the setup with?
It was on the backordered list (not too long) and it just shipped. I already have a Mega 16/15/4 in the EZ.
The Medusa will replace the 3100kv Aveox 27/13/3 installed in a Unicorn Wing. http://www.rcgroups.com/forums/showthread.php?t=177048
The Mega 16/15/4 is the most popular motor in the Unicorn and why it was my BL choice in the EZ* build thread. The Medusa V2 has similar if not better specs.
I'll be using a PHX-35 or eFlite 40 esc, 25c 3s battery.
Sarge
sargentw is offline Find More Posts by sargentw
Old Jan 15, 2009, 01:23 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
Originally Posted by Robrr
Thanks for that, have you flown with them taped on the inside? would it make any dif. do you think, at the moment I have them running down either side of the fuse. do you think I would still get full range like this.
I've flown with them inside, however, routing them outside just gets them away from all the cockpit activity. You will get full range either way. With Futaba the receiver is constantly switching back and forth to the antenna wire with the strongest received signal.
Sarge
Old Jan 15, 2009, 01:25 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Originally Posted by sargentw
It was on the backordered list (not too long) and it just shipped. I already have a Mega 15/14/4 in the EZ.
The Mega 16/15/4 is the most popular motor in the Unicorn the Medusa V2 has similar if not better specs.
Sarge
Sweeeet! My ez's currently carry the HiMax 2815-2000 w/T-Bird 36 3s 2100. How does the Mega compare to the HiMax?
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Jan 15, 2009, 01:47 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
I can't really say anything for sure because I've never tried one. I have a nice running Himax 2812-0850 outrunner on a Mountain Models Panic 3d plane. However, I do know that the Mega 16/15/4 was the choice for 100' s of Unicorn wing flyers because of long flight times, reduced heat, no thrown magnets, and it would handle 10/12 cell packs and 3/4s lipo packs using 6x4 and 7x4 props.
Sarge
Old Jan 15, 2009, 02:01 PM
dirtman is offline
Find More Posts by dirtman
Lost it again!!!!!
dirtman's Avatar
United States, CA, Menifee
Joined Aug 2007
I was just looking at the specs on the mega 16-15-4, it only has a 25a max?
It is close to the same specs as the Turnigy 2835 2200kv
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
with a 6x4 it pulls just over 18a on 3s. I know the mega will be a better motor in the long run, but is it realy worth 3x as much?
the himax is a good motor. What kind of amps does it pull with a 6x4 16-17a?
The 2000kv @ 25a would realy scream with a 7" (or maybe even a 8") to get it up to +20a. Hard to fit that on an ez*
I have a 6x5.5 I need to try on my 2835, like to get it over 20a too.
dirtman is offline Find More Posts by dirtman
Old Jan 15, 2009, 02:29 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
Those are conservative Mega Manufacturer specs; it will handle much more. Is a Mega worth it? Depending on what you are doing it maybe worth 4x as much.
The motor to be looking at now might be the Medusa, plenty of pep and power at only 70g; same weight as the Neu 1105.
Old Jan 15, 2009, 02:37 PM
mataub is offline
Find More Posts by mataub
mataub's Avatar
UK south
Joined Dec 2007
paint job
As a complete beginner.....have only flown the EZ* once, live in London, limited spaces to fly in......if I want to paint it the EZ, what paint can I use? I've got the multiplex primer, but what sort of paint to go over the top of this primer? Answers from fellow UK pilots welcome as I need to source the paint here in London.
Cheers,
Steve.
mataub is offline Find More Posts by mataub
Old Jan 15, 2009, 02:59 PM
monkey32 is offline
Find More Posts by monkey32
...insert witty text here...
monkey32's Avatar
UK
Joined Jun 2007
Cheers,
Steve.
Hi Steve, welcome to the forum!
I've used the Tamiya spray paint (for polycarbonate rc car body shells) on elapor with good results. I think the elapor was primed with prymol. Lots of colours to choose from in the Tamiya range but make sure its the one for polycarbonate, as that paint can flex and doesnt attack the elapor.
this link may help:
http://www.modelsport.co.uk/?CallFun...ufacturerID=53
monkey32 is offline Find More Posts by monkey32
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
There inlies my problem with the HiMax. Would like to run a little bigger prop as Im turning 21000 rpm now and dont feel Im getting the full benefit of the motor on the ez
Old Jan 15, 2009, 03:06 PM
dirtman is offline
Lost it again!!!!!
dirtman's Avatar
Joined Aug 2007
next on my list is a bizzard Wanted to run that micro dans 2535kv with a 7x5. looks to be close to 40a (on paper). 38g motor!
The dang blizzard was designed for the slope, so sticking a motor in it needs tail weight. a 38g motor pulling 400w should lessen the weight on the tail.
I would put one on the ez*, but I think it would rip the thing apart. 200-250w is fine for a stock ez* I would go for a striker or funjet if I wanted to go faster
Old Jan 15, 2009, 03:13 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
Hey fellas, did you see that US Airways Airbus ditch it in the Hudson River a few minutes ago. They supposedly hit a flock of geese leaving La Guardia airport bound for Charlotte NC and the pilot did an awesome job of putting it down in the Hudson River. On the news right now
Old Jan 15, 2009, 03:34 PM
dirtman is offline
Lost it again!!!!!
dirtman's Avatar
Joined Aug 2007
Yea, give it up for the pilot to get that down in one piece. is the right wing still on?
Looks like everybody got out
Old Jan 15, 2009, 06:09 PM
WTurbiasz is offline
Find More Posts by WTurbiasz
Tree Flyer
WTurbiasz's Avatar
Albany NY
Joined Feb 2005
Its very odd that it went down because they lost an engine if that is in fact what happened and there wasnt more involved. An Airbus just like a 737 is more then capable of flight with just one engine. Odd. Look forward to the details as they emerge and thank god everyone made it out safe.
Tek
WTurbiasz is offline Find More Posts by WTurbiasz
Old Jan 15, 2009, 06:28 PM
dirtman is offline
Lost it again!!!!!
dirtman's Avatar
Joined Aug 2007
Hey Tek,
Have you tried to call the Fire department and say your pet is stuck up in a tree?
Did it move again? Maybe another airbus can make a low pass for you and blow it out
Old Jan 15, 2009, 06:43 PM
IH8VTEC is offline
Find More Posts by IH8VTEC
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Tek
Says 2 engines quit.
http://www.timesonline.co.uk/tol/new...cle5526723.ece
IH8VTEC is offline Find More Posts by IH8VTEC
Question Multiplex Easy Star brucie1dog Beginner Training Area (Aircraft-Electric) 12 Dec 01, 2009 09:32 PM
Multiplex Easy Star Built on time! Speed E Freak Foamies (Kits) 10 Sep 01, 2009 11:30 AM
Discussion Multiplex EasyStar 2007 A discussion of anything Easy Star and sometimes more alexeames Foamies (Kits) 10990 Dec 31, 2007 06:12 PM
Discussion Multiplex Easy Star 2006 - A discussion of anything Easy Star and sometimes more Grassy Knoll Foamies (Kits) 6833 Dec 31, 2006 10:45 PM
Discussion Multiplex Easy Star Thread #21 - what more can I say?? Gort@69 Foamies (Kits) 2015 Dec 31, 2005 10:33 PM
