Old Dec 31, 2008, 09:52 AM
pajo1981 is offline
Find More Posts by pajo1981
Kildare, Ireland
Joined Jul 2008
How heavy are your FPV easystars?
Weight?
What kinda gear are ye carrying?
Any comments on performance?
Trying to get a handle on the payload carrying capacity of the ez.
Attempted to fly a fully loaded ez with a 3AH 3cell LIPO a few months back- needless to say she flw like a brick LOL...
pajo1981 is offline Find More Posts by pajo1981
Old Dec 31, 2008, 10:21 AM
dankers is offline
Find More Posts by dankers
OpenPilot
dankers's Avatar
Melbourne, Australia
Joined Apr 2004
There is an old saying, an Easystar is too heavy to fly, only when it takes two people to lift it.
Mine was 1.2kg, hated it, mushy and wobbly. Also, add some strapping tape to the wings as they can break if it is too heavy.
dankers is offline Find More Posts by dankers
Old Dec 31, 2008, 10:47 AM
CATPart is offline
Find More Posts by CATPart
CATPart's Avatar
Joined Mar 2008
vova started a thread a while back on this subject, search AUW (all up weight) you may find it.
CATPart is offline Find More Posts by CATPart
Old Dec 31, 2008, 01:19 PM
rob10000 is offline
Find More Posts by rob10000
rob10000's Avatar
Mine came out at 723 grams ready to fly with the following gear...
TP Prolite 3S2000 and 2S800 to run the camera and transmitter.
Castle Creations 7 channel RX
Castle Creation Phoenix 25
200mw 2.4 TX, KX-131
AXI 2208/26
pan and tilt servos
HS-81 on rudder and elevator.
Here's a picture from when I built in in 2006..
lighter flies better!!!
rob10000 is offline Find More Posts by rob10000
Old Jan 01, 2009, 09:04 PM
nickpettit is offline
Find More Posts by nickpettit
Joined Jul 2007
My easystar flies well and weighs a tonne. 90gram eflite six series brushless motor, 45 amp Castle Creations speed control, 300 gram 4000maH battery, the aiptek 1080p HD camera, 800maH battery for range video 1W transmitter, etc. The easystar has a huge payload with all this can easily take off from the ground. Just reinforce everything on the fuselage and nose with straping tape and use a 1 metre carbon fiber wing spar versus the fiberglass one provided through the wings. I ran this fiberglass wing spar through the fuselage. Down the side of the nose and cockpit I glued and straped carbon fiber strips. Make sure the Centre of Gravity is in the right place when fully laden.
nickpettit is offline Find More Posts by nickpettit
Old Jan 13, 2014, 12:49 AM
SageHillsPilott is offline
Find More Posts by SageHillsPilott
United States, SD, Reva
Joined Apr 2013
Mine weighs about a pound and a half, maybe two pounds, not shure, it's got a seven by five prop, it's hauling around a FPV camera in a cast iron case, a 400milliwatt transmitter, a arkbird autopilot, lots of hot glue and epoxy, and balances out perfectly on a 3Kah lipo battery (3,000mah 3s) and I get 30 minutes on the stock motor.
SageHillsPilott is offline Find More Posts by SageHillsPilott
Old Jan 13, 2014, 01:22 AM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
30 minutes is not hard with 3300mah, but I found it was the launching that went to crap at such heavy weight - IIRC mine was about 1.2Kg. I had park480 1320kv 8x4 prop. I have heard of guys running as much as 10kmah or even a lot more on an Easystar type. I would have to throw it off a 100 ft cliff to launch it with such weight.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Jan 13, 2014, 11:22 AM
rob38 is offline
Find More Posts by rob38
rob38's Avatar
Noord Holland
Joined Oct 2007
hi
my easy start is 998 grams
dragon link
trace 4 osd
cam
4 amp 3s lipo
inverted v ant
2,4 vtx boscam
SW clover
4 servo,s
rob
rob38 is offline Find More Posts by rob38
Old Jan 18, 2014, 09:40 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Very heavy
And sometimes nice and lite
2200 4 cell works great
And that is lite
Ez 45 min run time
But not fast but ez 6 km away and back
6800 3 cell is heavy but fly long time
And ez fast 10 km away and back fast
I prefer lite ez with 2200 4 cell
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Discussion How heavy are your blades ??? Or can they be ? Cooker Micro Helis 2 Jan 09, 2007 09:26 AM
How big / heavy are your Axi 2826 powered planes? BoneDoc Power Systems 14 Feb 03, 2005 12:51 PM
How long are your Slow Stick Axles? jimsp Parkflyers 1 Mar 20, 2003 12:22 AM
How hot are your batteries? ben1000 Foamies (Kits) 2 Aug 22, 2002 07:06 PM
How heavy is your battery pack for TM? rick2048 Scratchbuilt Indoor and Micro Models 0 Jul 28, 2002 09:58 PM
