Old Dec 31, 2008, 02:34 AM
Joined Jul 2008
79" E Gliders: St ASW 28 ..&.. DG 1000
Summary
ST ASW 28, wing load 24.7 g/dm2, photos
79" 4ch, 1000-1300 mah 2s lipo bl, 18oz, 10x6 prop
ST DG 1000, wing load 33.3 g/dm2, photos
79" 5ch, 1300 mah 3s lipo bl, 26oz, 7x5 prop, rms
100% Scale Schleicher's new ASW 28 $80,340
49', 518 lbs, useful load pilot & chute 254 lbs max
Certified for cloud flying and semi-acrobatics.
Mr_Cash is offline Find More Posts by Mr_Cash
Old Jan 06, 2009, 02:40 AM
Joined Jul 2008
An option for PNP/ARF 5ch DG-1000 or 4ch ASW28;
2.4ghz 6ch transmitter & 6ch receiver: $42 + $18 ship.
Old Jan 09, 2009, 04:46 AM
Joined Jul 2008
ST ASW 28 Maiden Flight video.
Australia summer, January 9, 2009,
... ocean slope, loops, inverted flight.
Old Jan 10, 2009, 12:33 AM
Joined Jul 2008
ST DG 1000 similar,
the 100% scale 18 m “Turbo” LS8-sT made by DG.
Retractable 2 cyl. 2 stroke engine, 17 liter tank, 10 produced.
Old Feb 03, 2009, 12:33 AM
Joined Jul 2008
Summary Questions:
I.
If you could get either of the below within $25 or so, of each other (likely will be more, but assume only $25 difference for now). which would you choose?
II.
The St DG1000 is nice for its foam, 79" wing, ailerons, scale design of a sharp looking real glider, and its
1) bigger likely longer running and more powerful 3s battery,
2) high mounted prop being less vulnerable in crashes,
3) retractable motor as something new and different
The ST ASW28 is nice for its foam, 79" wing, ailerons, scale design of a sharp looking real glider, and its
1) lighter wing load (see stats above, ... should this mean better thermal power off gliding?),
2) lower price.
Questions:
a) Since the ST ASW28 has a lighter wing load,
does this generally mean it should glide better, and thermal better, and have longer "power off flight times" than the heavier wing loaded ST DG1000?
b) Since the heavier ST DG1000 has a more powerful 3s lipo (and possibly more powerful motor to handle the 3s), should it have a notably faster "Climb to Power off High Altitude Point", ... even though its heavier than the ST ASW28?
III.
The ST ASW28, if purchased from hobby city, comes with a 1300 mah 2s lipo type battery, ... instead of the 1000 mah 2s lipo battery if bought from Australia.
The 1300 mah may give a little extra run time, but, the 1300 mah 2s would also be heavier than 1000 mah 2s.
Would the 1300 mah extra wt., be enough heavier wing loading, that it would give a noticeable adverse affect on the ASW28 thermal, glide, and/or power off flight time capabilities, vs. the 1000 mah battery?
Old May 11, 2009, 06:53 AM
Big Nuts 181's Avatar
Joined Jul 2004
what a great model I wonder if the up n go unit could be retro fitted to the CMP Ventus or perhaps a larger model??
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Discussion asw 28 dg 1000 paul044 Scale Sailplanes 0 Jan 10, 2008 06:14 PM
Discussion Hobby Lobby CRASH Sale 1/9/08: ASW-28 and DG-1000 PDX Slope Pilot Slope 7 Jan 10, 2008 08:38 AM
Sold Let Model ASW 28 3m Fuselage Only - brand new Commplexxo Aircraft - Sailplanes (FS/W) 1 Aug 24, 2007 04:13 AM
Discussion New ASW-28-18 s2000 Scale Sailplanes 7 Mar 05, 2007 12:11 AM
