Old Dec 29, 2008, 07:11 PM
bhoges17 is offline
Find More Posts by bhoges17
Long Island ,NY
Joined Dec 2008
Can I run two chargers off 12v power supply?
I have an 18amp power supply and wanted to know if I can run two chargers off that. Doing 1 batt an hr is killing me. Thanks
bhoges17 is offline Find More Posts by bhoges17
Old Dec 29, 2008, 07:16 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Yes. I do the same with mine every once in a while, and it only puts out 20 amps. Runs cool, but will charge both batteries with it putting out 13.8v as per my accucel-6 says.
Xpress.. is offline Find More Posts by Xpress..
Darryl Miller is online now
Find More Posts by Darryl Miller
R/C Addict for Life!!
Darryl Miller's Avatar
Sterling/Rock Falls, Illinois, United States
Joined Oct 2001
Ive had as many as 4 chargers off of my 13amp computer power supply. As long as they are not charging big lipos...(ie, 4 and 5 amps or more, ) they did fine.
D
Darryl Miller is online now Find More Posts by Darryl Miller
Old Dec 30, 2008, 05:35 AM
pentaxman is offline
Find More Posts by pentaxman
pentaxman's Avatar
Braintree, Essex, UK
I run 3 chargers on mine with no issues.
Just add up the current pull from each charger.
So if you are charging a 2500mAH pack, a 1200mAH pack and a transmitter pack (2000mAH) then your power supply needs to be capable of producing 2500+1200+2000= 5700mA, allow a little for losses and you are looking at a 6A minimum supply rating (CONTINUOUS).
Hope this helps.
pentaxman is offline Find More Posts by pentaxman
Old Dec 30, 2008, 08:31 AM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
I do it all the time with my 30 amp power supply. As others have said just make sure your charger has the amp rating to handle what your pulling from it. I also made a multitap box with one input from the power supply and 6 outputs to the chargers.
Vintauri is offline Find More Posts by Vintauri
Old Dec 30, 2008, 03:16 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Here you go
http://www.rcgroups.com/forums/attac...mentid=2247192
14 chargers off of 4 power supplies, each putting out 20 amps.
Question Can I Run 2 Chargers Concurrently On A 20 Amp Power Supply? cobull Batteries and Chargers 9 Aug 17, 2007 11:48 AM
Can I run Two Chargers off of (1) 12V regulated power supply? mrebman Batteries and Chargers 4 Feb 28, 2005 04:58 PM
two chargers on a 12v power supply? austinflyer Batteries and Chargers 1 May 03, 2003 09:30 AM
Can I run two chargers off a 12V automotive charger cruzomatic Batteries and Chargers 7 Aug 11, 2002 11:48 AM
Can't run two Hackers off one controller? dom Power Systems 2 Apr 25, 2002 10:13 AM
