Old Mar 05, 2003, 06:27 AM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
minimum wing area for edf-50
hello people,
i'm designing a jet for an edf-50, does anyone know of a minimum wing area for this particular fan unit.
Robbie d is offline Find More Posts by Robbie d
Old Mar 05, 2003, 10:16 AM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Robbie,
IMHO, wing loading is more important, as you are using a fan unit that has a higher thrust than effux veloc. as compared to units that are designed to propel higher wing loads and speed.
The power package should be less in wieght, or equal to the models weight with radio gear.
Steve
St. Martin is offline Find More Posts by St. Martin
Old Mar 05, 2003, 12:18 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
As proven by the Fan-Tastic Models Mig and Sabre, the "sweet spot" is about 150-160 square inches of wing area and an all up weight of about 7-7.5 oz for a single EDF 50.
Given that the EDF 50 is something of a low power unit, you really must fly on the wing and not the motor...
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Mar 05, 2003, 01:58 PM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
Hey thought I would mention this since there is intrest in more performance.. something I tried that worked well as a upgrade .. I took a Dare Design's KP 440 Electric fan unit.. and replaced the rotor with the 3blade gws rotor.. I had to reduce the dia of the blades to 44mm .. the 4.8v 180size motor with its carbon brushes and metal endbell proved to provide a mix of duration and extra power the lighter gws rotor was clearly the winner for reduceing the amps of the larger motor . Another plus was the prop was reduced in dia allowing it to produce higher top end speeds during level flight. I am going to buy the new rotor from gws that has more blades should be the choice for all out power. This motor screams on 5 cell nicads or 6cell nimh cells , less cells less weight.. you cant go over these limits this motor is a monster like the amp eating 300 size 6v motor it gobbles amps up at about 60% the rate of the 300 .. sorry dont have no hard data on that statement just going off the hip.... 150N's will fly this plane but not for long you must use 170n 270n 350n or 370nmh to 720nmh work very well for duration . and if you have some lilpoly cells your going tobe king with this fan set up on any of your current successfull jets now flying with the gws fan. here is a pic enjoy.
AIR MOVER is offline Find More Posts by AIR MOVER
Old Mar 05, 2003, 03:58 PM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Thrust for Modified KP-44?
I have a KP-44 for the Aerographics Hawker Hunter kit. What kind of thrust were you getting on the modified KP-44 unit with 5 nicads? I would like to see if I could put a micro-RC system in the Hawker, but have also enlarged all the drawings and patterns for a 3" sized unit.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Mar 05, 2003, 06:53 PM
Robbie d is offline
Crazy Cessna Owner
Robbie d's Avatar
Joined May 2001
thanks for your help guys.
Unfortunately the kp-44 is more expensive here than the edf-50 so i don't think a conversion is on the cards.
using the smaller ducting however should make engines look more of a scale size
Old Mar 05, 2003, 10:31 PM
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
I dont have a digi scale to set up thrust test hower i do own a spring scale for postage up to 2pounds .. I will set something up and test it out for you . over 3oz on 5 nicads im sure. I would like to just buy the 180size 4.8v motors and make my own shroud and try some other dia rotors and blade counts. will keep you posted on my findings ....
Old Mar 05, 2003, 10:59 PM
P_J_Glor is offline
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
3 oz would be a nice improvement
The stock edf 50's are rated at about 2.3 to 2.5 ounces on 7.2 volts, 3 amps, so 3 oz, particularly on a twin would be a nice increase.
SR-71 for EDF 50 (Closer than we might think) Thomas B Electric Ducted Fan Jet Talk 187 Feb 22, 2011 11:56 PM
Scale microjets for EDF 50: What aircraft do YOU want to see kitted? Thomas B Electric Ducted Fan Jet Talk 167 Sep 14, 2009 06:08 AM
MiG-15 for EDF 50: more North Texas molded foam magic! Thomas B Electric Ducted Fan Jet Talk 60 Feb 04, 2002 08:29 PM
New molded MiG-15 for EDF 50: Thomas B Parkflyers 17 Dec 29, 2001 11:34 AM
MiG-15 for EDF 50: micro EDF action! Thomas B Parkflyers 2 Dec 27, 2001 09:27 AM
