Old Dec 28, 2008, 03:27 PM
GradGuy is offline
Find More Posts by GradGuy
Joined Dec 2008
Question
Spektrum receiver with futaba servos
I'm just getting into RC and will be buying my first radio, receiver and servos soon. I don't know much about this stuff yet.
I'm going to be buying a Spektrum DX6i because its tested to work with an endurance PCTx.
Being that I see that Futaba offers a lot more servos. Is there a bottle neck going with Spektrum because of the servos or can I just use any of Futaba servos including the digital ones using a Spektrum receiver AR7000 DSM2 or AR9000 DSM2.
Sorry for the stupid questions... If im asking them.
GradGuy is offline Find More Posts by GradGuy
Old Dec 28, 2008, 03:36 PM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
Futaba servos will work just fine. You will have to trim a little plastic off the connectors to get them to fit - that's all.
teamdavey is offline Find More Posts by teamdavey
Old Dec 28, 2008, 03:38 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
This thread might be of some assistance.
Bill
ebill3 is offline Find More Posts by ebill3
Old Dec 28, 2008, 07:43 PM
Zerts is offline
Find More Posts by Zerts
John,not Zerts.JOHN, NOT Zerts
USA, AZ, Chandler
Joined Nov 2007
I tried Futaba S3114's instead of Hitec HS-55's but the have a jittering problem occasionally...but not bad enough to cause any crash yet. I am going to stick with Hitec in the future.
Zerts is offline Find More Posts by Zerts
Old Dec 28, 2008, 10:40 PM
GradGuy is offline
Joined Dec 2008
Triming tabs
Thanks for the great reply everybody... Trimming the tabs sound like a good plan...
Ok...one more rookie question regarding system power.
I've looked at combo packages that have a motor, controller, and battery pack. This sounds fine "but" and this sounds dumb... does the receiver and servos typically draw there power from one main battery pack or are systems separated by main motor, receiver and then servos.
Thanks again...
Old Dec 28, 2008, 11:43 PM
ebill3 is offline
ebill3's Avatar
Sounds like you are going to use an electric motor for the power plant.
The controller, usually called the ESC (Electronic Speed Control) most often has a circuit called the BEC (Battery Eliminator Circuit). The BEC reduces motor battery voltage to (usually) 5 volts and powers the receiver and servos through the throttle port on the receiver.
But, (don't you love the buts? ) most BECs are inefficient linear regulators and, depending on the battery voltage, can only handle a limited number of servos. Because the excess voltage is dissipated as heat, the higher the battery voltage, the fewer servos allowed. The ESC spec sheets will tell you what they can handle. Most park flyers and small models use the ESC BEC for RX and servo power.
In your OP you indicated you will be using AR7000 and AR9000 RXs which suggests that you are considering larger models with heavy servo current demands. In that case, you probably should use a separate 5 cell NiMh RX battery or a separate switching BEC. Switching BECs are more efficient and can handle greater loads than the BEC typically found on the ESC. An example of a separate BEC is the Dimension Engineering Sport BEC. There are others, of course.
Bill
Old Dec 29, 2008, 10:06 AM
GradGuy is offline
Joined Dec 2008
Thanks ebill3.
Ok I think I understand... "depending on the ESC" I might be able to get 2 servos. With a separate BEC I could use one battery to drive the motor, receiver, and servos? I don't expect to have more than 4 servos. The other way is to use a separate 5 cell NiMh RX battery, which will just power the receiver and servos?
Ok, this is starting to get clear...however, how would you recommend I address the total power system. I'll most likely have 4 servos, one gyro. One FMA Co-Pilot, a video downlink like a black widow and one Blip camera controller.
I know it depends on the draw all these components have... But it's more of a general methodology that I'm looking for. I think I'll have the main battery driving the motor and one battery for the rest of the gear?
Am I correct? Is there a online tool that I can input all the power demands, to kick out the best match for battery model, size and brand?
Thanks again everybody.
Old Dec 29, 2008, 02:17 PM
ebill3 is offline
ebill3's Avatar
Originally Posted by GradGuy
Thanks ebill3.
Yes.
A 2400 mAh 5 cell NiMh battery or Castle Creations BEC.
Your choice. Some opt for the separate battery, others for a BEC. I prefer the separate battery, but there are pros and cons for both.
Not that I am aware of.
Bill
Old Dec 29, 2008, 07:16 PM
GradGuy is offline
Joined Dec 2008
Thanks...
How does one go about calculating / figuring the total power draw to select a battery? I.E. what reading on the equipment do need to know volts, amps... and how do I total their values so it relates to the meaningful demand on a battery?
Old Dec 29, 2008, 08:20 PM
GradGuy is offline
Joined Dec 2008
Thanks...
Old Dec 30, 2008, 07:21 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
The problem is, almost nobody publishes normal and stall current ratings for servos. So you end up having to go with other peoples experiences or buidl your own.
Rxs draw max 500 mA.
Something like an Eagle Tre logger can measure actual current draw during flight.
Pinecone is offline Find More Posts by Pinecone
Discussion JR R770 PCM Receiver with Futaba 9C mmg Electric Heli Talk 5 Apr 24, 2006 07:16 AM
Raptor 30v2 - JR Radio with Futaba servos JoeB99 Fuel Heli Talk 5 Jul 29, 2005 02:00 AM
MPX RX with Futaba servos? RCfun Radios 1 Aug 16, 2004 04:26 AM
Hitec electron rx with Futaba servos? jaywatay Radios 9 Jul 13, 2004 05:58 PM
Hitec Feather Receiver with Futaba? RPL Foamies (Kits) 2 Feb 14, 2002 08:55 AM
