Old Dec 28, 2008, 04:44 AM
thundertiger76 is offline
Find More Posts by thundertiger76
thundertiger76's Avatar
UK Devon
Joined Apr 2008
Question
Cm Pro Discus HELP
Hi, Can any one tell me how to convert my CM Pro Discus CS glider in to a electric powered one.
Where should i cut the nose off and how do i calculate this, do i need to think about side and/or down thrust ?
Also do i need a geared motor, what size ect...
thundertiger76 is offline Find More Posts by thundertiger76
Old Dec 28, 2008, 08:15 AM
Jurgen is offline
Find More Posts by Jurgen
Europe - Belgium
Joined Mar 2005
Do not "calculate" too much, it's more tinkering with fun.
Motor choice:
- if you want brushless motors: an outrunner will be cheapest solution, you have a big fuselage so large diameter is no problem.
- if you want brushed motor: a gear is best
Size of cut: see what kind of spinner you have and cut nose accordingly.
See this link for a good motor -prop recommendation:
http://www.bw-design.be/Airplanes/Gliders/DISCUS_CS.htm
Down and side trust: forget about side trust, down trust is also not that important with this kind of plane. I would make the spinner fit the streamline of the fuselage perfectly for nice optic. If plane tend to rise when motor on, just program your transmitter with a touch of 'down' that comes in automatically when motor in ON.
Success, Jurgen.
Jurgen is offline Find More Posts by Jurgen
Old Dec 28, 2008, 09:32 AM
UK Devon
Joined Apr 2008
Cm Pro Discus
Thanks buddy for the reply.
How do i know if im cutting the nose off square, do i just do it by eye or measure back from the point of the nose.
Old Dec 28, 2008, 09:47 AM
Wylie Shaw is offline
Find More Posts by Wylie Shaw
Clearlake, CA. USA
Joined Jun 2000
Hole
Mate cutting a hole in da nose..... Choose the size spinner you need and purchase it.... now take the spinner and trace around the spinner on a piece of paper and cut the hole out of the paper (light card stock here) or measure the outside diameter of the spinner and make a circle in some card stock approx 1 mm to small and stick the nose of the fusealage throught the hole trace around the hole, and cut, and sand to fit the spinner that you are using. cutting the hole a little smaller allows you to adjust for size.
Best Regards,
Wylie Shaw
Wylie Shaw is offline Find More Posts by Wylie Shaw
Old Dec 28, 2008, 04:24 PM
UK Devon
Joined Apr 2008
Cm Pro Discus
Once again thanks for the replies.
I know what your saying with the paper/card thing, but how do you know its square to the incidents of the wing ?
Cheers Craig.
Old Dec 30, 2008, 12:37 AM
Jurgen is offline
Europe - Belgium
Joined Mar 2005
If you really want the motor axis to be in line (or whatever angle you want) with wing angle, then you can measure it with the Robart incidense meter (or more expensive electronic stuff). If you are interested in good tuning better buy:
http://www.radiocarbonart.com/Pages/perftunemain.html
Regards, Jurgen.
Old Dec 30, 2008, 05:06 AM
UK Devon
Joined Apr 2008
Thanks guys, every one have been a great help.
Old Dec 31, 2008, 04:24 AM
mikedsilva is offline
Find More Posts by mikedsilva
mikedsilva
Brisbane, Australia
Joined Apr 2005
http://www.flying-dream.com/Airplane/Discus.html
might be easier
mikedsilva is offline Find More Posts by mikedsilva
Discussion Cm Pro Discus Cs thundertiger76 Sailplane Talk 1 Dec 28, 2008 02:26 AM
Yippee! CM Pro Contact info Smoggyboy Fuel Plane Talk 2 Dec 06, 2004 06:37 PM
cm pro models MrPropJet Fuel Warbirds 2 Jun 20, 2004 10:00 AM
GSP/CM Pro extra 72" dale691 Scale Kit/Scratch Built 0 May 16, 2004 08:08 PM
CM Pro Bird Dog Peter Young Fuel Plane Talk 2 Nov 20, 2002 12:39 AM
