http://www.shipmodels.info/mws_forum...art=15#p255937 But no matter, I smoothed it real good with a palm sander... |
![]() ![]() ![]() I've just looked over at your build thread... thats a MONSTER!... Nice work.. as always..
For a down and dirty thickness sander if you have a drill press you can use those small sanding drums that are made for power drills, set up a fence on your drill press the thickness away from the drum of choice and run your stock through it.
Good for small projects and if you only need to run a few pieces, but it does work and with a little patience you can do a good job. You can also use your drill press and sanding drums as a spindle sander and no it is nowhere near as good as the real thing but if you don't have the money and not going to use it a lot it will work well enough to get your project complete without spending a lot and will give you an excuse/reason to go out and buy the real thing. |
I've done a bit of sanding in a drill press, and I'm happy to have the real sander now! One problem with drill presses is their typical sloppy spindles and/or quills, which allow for sideways slop. This is also one reason why it's hard to mill in a drill press- too much chatter. Also, the chatter can knock the Morse taper chuck loose... which why real mills have drawbars.
I actually tried a large drum sander in my drill press once.
My drill press is bolted down to a workbench. It is meant to drill things that fit on the small table. I was trying to sand the edge of a 54" long piece of Springer hull and I mostly suceeded ini knocking over everything else on the workbench and not doing a very good job on the piece of wood I was trying to sand. The spindle sander I am going to get replaced will be a portable unit I can take outside and place on a workbench where I have unlimited room and freedom of movement to work on the largest pieces of wood I ever actually plan to work on. So yes the drill press idea is okay, but mostly for very small stuff. |
| Thread Tools | |
| Hi all, now i got an ECO8! | Tom Viper | Electric Heli Talk | 3 | Mar 10, 2002 08:04 PM |
| I got an SS Pro for X-mas and now I have a few questions. | RollTide69 | Beginner Training Area (Aircraft-Electric) | 7 | Dec 30, 2001 10:51 PM |
| Anybody else got an MC-24 - and would like to share knowledge | nigel99 | Electric Heli Talk | 0 | Dec 24, 2001 02:32 AM |
| Got an Astro 90....Which Plane??? | jsc | Electric Plane Talk | 4 | Dec 14, 2001 12:06 AM |
| Looks cool and I got an "A" | Troy | Life, The Universe, and Politics | 12 | Jun 22, 2001 01:35 PM |
