Old Dec 27, 2008, 11:50 AM
pcasamento is offline
Find More Posts by pcasamento
Joined Dec 2007
Rechargeable Batteries for Remote
Most remote controls use eight (8) AA batteries. What is the best option for rechargeable batteries and chargers. Do they make a charger that can do all eight batteries at a time? Are any batteries better than others. Where is the best place to buy the batteries and charger? Appreciate your help...
pcasamento is offline Find More Posts by pcasamento
Old Dec 27, 2008, 12:39 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
yes you can get wall chargers that can do 8 cells, your remote transmitter may have a jack in the side. as for battery brand, I use sanyo,
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Dec 27, 2008, 07:48 PM
ragss is offline
Find More Posts by ragss
Joined May 2008
Wow can you open up a can of worms asking about chargers. I use a smart charger and get good life out of my batteries. But their is a ton of different "smart chargers" out there. Most are pretty good to very good. They are not overkill if you look at the price of batteries and the additional life they get out of the batteries especially if your using nicad batteries.
Oh by the way I use duracell 2650mah. They are nimh. I got 8 of them in a pack from Wallyworld for $19.00 with a cheap charger!
ragss is offline Find More Posts by ragss
Old Dec 27, 2008, 09:06 PM
ozzie-crawl is offline
Find More Posts by ozzie-crawl
Joined Aug 2008
i personally think if you are going to buy a charger buy one that does nicads rite threw to lipos as you never know when you mite need it
just my 2c scott
ozzie-crawl is offline Find More Posts by ozzie-crawl
Old Dec 27, 2008, 09:31 PM
ragss is offline
Joined May 2008
Good point Ozzie-Crawl but I think all the smart chargers these days will handle lipo's. Their may be a few old ones around but for the most part they will handle any battery.
I'd like to know how they put all that magic in that little box. All I do is hook up whatever battery I need charged and put the temperature sensor on the battery. It takes a second and knows what kind of battery or batteries they are and starts charging them. The only thing I have to do manual is tell it slow charge or quick charge and wether or not to discharge the battery first.
Old Dec 28, 2008, 08:03 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I use & suggest you get NiMh battery for your TX, I am using 2600mah AA NiMh in my TX and they seem to last for weeks on end. NiMh are also knowed to not have such a (MEMORY) and can be recharge even if they are not fully discharged. AND you will be glad that you didnt get LIPO for your TX the next time you forget to turn it off, like I sometimes DO. Electronic store like RADIO SHACK, THE SOURCE, you can get plastic tray ( battery holder ) that will hold your 8AA, or if you can solder, you can solder on a charging tab on your TX or what I think is easiest is IF YOUR TX as a 8AA battery pack holder like some PISTOL GRIP TX, you can just remove it from the TX and use wires with clips to hook up on the +- of the pack to charge it.
AS for a CHARGER, get a multi-type charger. YOU will be glad that you have it when you get better bigger battery AKA LIPO
EXEMPLE OF MULTI CHARGER
http://www.duratrax.com/caraccys/dtxp4230.html
freechip is offline Find More Posts by freechip
Old Dec 28, 2008, 11:47 AM
pkboo is offline
Find More Posts by pkboo
Is life for real?
pkboo's Avatar
Almere The Netherlands
Joined Sep 2006
Vouching Freechips advice! I use GP's 2700 and they do seem to last on ends, yet if not sure no problem on the recharge and I have had them forever And not all chargers handle LiPo but get one that does, it's the way it's (going maybe not immediately but.....!). If you treat your LiPo's right they will meet you on the same level! Boo
pkboo is offline Find More Posts by pkboo
Old Dec 28, 2008, 07:21 PM
Joined Dec 2007
Thank You For All Of Your Responses... I Will Certainly Take It All Into Consideration, Before Making A Decision.
Discussion Battery Charger for "AA" Rechargeable Batteries mondo1948 Batteries and Chargers 5 Mar 13, 2008 12:52 PM
Discussion Straight Answer for Rechargeable Batteries Eddie Z Batteries and Chargers 1 Aug 21, 2007 03:02 AM
Li-ion and NiMH Batteries for Astro Brushless 010 msuder Electric Plane Talk 8 Aug 06, 2001 12:17 AM
UK flight batteries for LiteStik Clive Henry Jones Parkflyers 3 Jun 12, 2001 09:14 AM
