This thread is privately moderated by z80, who may elect to delete unwanted replies.
Old Aug 22, 2011, 09:34 PM
iBANK is offline
Find More Posts by iBANK
iBANK's Avatar
United States, IN, Dayton
Joined Jan 2009
Pardon the stupid question: Are the control surfaces included in measurements?
iBANK is offline Find More Posts by iBANK
Old Aug 22, 2011, 09:59 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Absolutely!
Curtis
Montana
Curtis Suter is online now Find More Posts by Curtis Suter
Old Aug 23, 2011, 09:05 PM
ombudsman is online now
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
So are you saying that the elevons would be considered part and parcel with the chord of the wing at the tip? Even though the elevons usually don't go full span? Isn't that going to cause the calculator to overstate the wing area? And isn't it going to cause the calculator to move the CG back too far?
ombudsman is online now Find More Posts by ombudsman
Old Aug 23, 2011, 10:15 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
This is just a simplistic geometry calculator. Since it only dose one trapezoid you can't accurately model the usual cut up trailing edge. Control surfaces are part of the wing and affect the aerodynamic center whether they are deflected or not. By leaving the elevons out of the stability calculation you have created a model that is slightly less stable than the real plane will be so, although leaving the elevons out of the calculation is technically wrong, the error that is introduced is conservative and therefor acceptable. Kinda
--Norm
nmasters is online now Find More Posts by nmasters
Old Aug 23, 2011, 10:18 PM
Oklahoma
Joined Sep 2010
--Norm
Thanks. I'm considerably out of my depth here.
Dave
Old Aug 23, 2011, 10:32 PM
TjW is offline
TjW
Find More Posts by TjW
TjW
USA, CA, Riverside
Joined Mar 2006
No. The elevons are part of the wing, and help generate lift. The fact that they change the camber locally to change the lift distribution left and right, or fore and aft, doesn't keep them from being part of the wing.
TjW is offline Find More Posts by TjW
Old Sep 18, 2011, 02:24 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
Thats great! I was looking for this thread!
I am building a kind of Lees Assassin wing, with a different profile and now, Im just waiting for the servos arrives from Hobbycity. The battery, a 3s 1.3 I already have, and my worries are about finding the correct CG.
My wing is 40" wing span and 9" = root
Im using a Emax CF2812 with a 7x6 and 3S 1.3
Can I use this program, correct? Any Ideas?
Thank you all,
Luis
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Oct 10, 2011, 08:03 AM
creapyd is online now
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
I'm in the process of building my first wing:
50" wingspan $ store foam board with a 13" cord, 12" sweep & 7" tip:
http://fwcg.3dzone.dk/?wing_span=50&...ow_mac_lines=0
I'm wonder how much reflex to put into the elevons to begin with. I know there should be some, but what's the rule of thumb here?
creapyd is online now Find More Posts by creapyd
Old Oct 10, 2011, 09:45 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I usually use as starting point the bottom of the elevon in line with the bottom of the wing and then two clicks of trim up.
Up&Away is offline Find More Posts by Up&Away
Old Oct 25, 2011, 06:20 PM
inel is offline
Find More Posts by inel
Joined Sep 2011
wing image disappear
Originally Posted by z80 View Post
I wrote a little CG calculator for flying wings. If you have a HTML 5 browser supporting the canvas object you will get a little image of the wing too.
Bug reports and suggestions are very welcome.
When I was using ie7 I can see the wing image and it's working for me for the last 2 years, but now i'm using ie8 and the wing image is disappear, some help please.
inel is offline Find More Posts by inel
Old Oct 30, 2011, 01:39 PM
Prefectionist
Joined Mar 2007
Just a quick question, can this do COG for forward swept wings?
Old Nov 22, 2011, 09:40 PM
sdbruder is offline
Find More Posts by sdbruder
sdbruder's Avatar
Brasil, PR, Curitiba
Joined Oct 2009
Originally Posted by adamtlk View Post
I discovered, the hard way, that for good low speed handling and performance a rough finish is better than a smooth, glossy one!
So rather eluctantly, I ripped off the nice glossy cover, and lo-and -behold, I had my old wing again! Searching literature on wind tunnel tests at low Re Numbers, I discovered that this was in fact a well established fact for some airfoils tested with different surface roughnesses.
But CG-calculator is a good starting point anyway.
What about your nice glossy cover with some turbulator love?
sdbruder is offline Find More Posts by sdbruder
Old Dec 07, 2011, 01:29 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
blatant AD but useful information:
If your wing is more complex than z80's calculator can handle, give http://wingcgcalc.bruder.com.br/ a try.
Old Dec 12, 2011, 10:43 AM
dr_serious is offline
Find More Posts by dr_serious
Joined Dec 2011
The calculator uses this wing.
Is this really the best wing for a flying wing? I would think this wing is more usefull:
can someone explain me why you guys chose for the first wing?
thx
EDIT:
I made a wing in autocad:
i would like to order this one but i dont have any idea it will be good...
the weight of the plane will be 2.6kg and 62".
(all the values are in cm but you have to /100 and x3)
dr_serious is offline Find More Posts by dr_serious
Old Dec 12, 2011, 02:55 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Its a matter of taste, actually.
your first wing (straight leading edge) is more used in 3D models. That wing have no sweep and the tip chord is smaller than the root chord.
Your second wing have some sweep (exactly sweep =rootchord - tipchord).
Your third wing have tipchord smaller than root chord and greater sweep.
My calculator cant draw exactly your third wing, but a aproximation of it because of the tip chord not aligned with the Y axis of your drawing.
flying wing cg ?'s mscj Foamies (Kits) 1 Mar 03, 2003 09:53 PM
Flying wing CG with shortened span MSB Foamies (Kits) 2 Jul 28, 2002 07:23 PM
Flying Wing CG Choppa Nutta Power Systems 8 Apr 17, 2002 11:45 AM
Flying Wing CG Paul Susbauer Parkflyers 2 Jan 29, 2002 01:31 PM
Flying wing CG Anders Power Systems 4 Oct 05, 2001 04:39 AM
