This thread is privately moderated by z80, who may elect to delete unwanted replies.
Old Feb 05, 2010, 02:25 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Hey Guys, just in case you are interested, here is a Flying Wings desing Cotest
http://www.rcgroups.com/forums/showt...1#post14265221
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Feb 11, 2010, 07:28 PM
tinuviel is offline
Find More Posts by tinuviel
Muslimah
tinuviel's Avatar
Joined Feb 2010
Beginner
Hi
I'm just a beginner modeler. Just wondering if the shape of the airfoil has anything to do with c.g? I'm trying to design a flying wing with a reflex airfoil. Flying it at low Re of about 200000 would give a crazy distribution of cm vs alpha and I don't know how to trim it or find my perfect static margin and c.g.
When I plug my wing parameters into the c.g calculator, i seem to get my c.g located at the % chord corresponding to the % that I chose in the program. Is that really correct for this case?
tinuviel is offline Find More Posts by tinuviel
Old Feb 12, 2010, 09:28 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Hey Tun
well to start with your own desings can be exiting but it can be also frustrating, even more when you deal with flying wings. If you are going for a sweep wing (type zagi) then things are bit easier. I have seem that profile affects the real location of your CG, which you will see is always a bit different from what a PC program predicted, those programs only give you an indication where it can be but only by flying your wing you will figure it out. Besides not having stabilizators make the wings more sensitive to CG and control throws.
I fly mainly PLank wings, and I try to start with a forward CG and the move it backwards little by littel till I feel that Im confortable with the wing's flight. Once I build a plank with a friend first his then mine, after succesfully flying his we build mine but we deceided to use a different profile, same wing planform everything was the same, even the CG, in the mainden flight I could barley control my wing, clear sing of a too back CG, after landing and movignt he CG coupple of mm forward every thing went OK.
I dont want to discourage you, but is always good to build many many already proofed desings, and when you have good experience flying you can make imporvements over those desings or go for your own, I learned that in the hard way, with many crashed own desings.
I wish you the best EZ and you can participate on this desing contes
http://www.rcgroups.com/forums/showthread.php?t=1184799
Old Jan 08, 2011, 12:29 AM
Mictronics is offline
Find More Posts by Mictronics
Joined Dec 2009
Mictronics is offline Find More Posts by Mictronics
Last edited by Mictronics; Jul 01, 2012 at 02:43 PM. Reason: Tired of RCG - Quality can be found at FVLAB
Old Jan 20, 2011, 03:17 PM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
is there a bug,
because when i use the wing calculater it no longer shows the wing demisions. just gives the stats..
57sailplane is offline Find More Posts by 57sailplane
Old Jan 21, 2011, 01:14 AM
Joined Dec 2009
Old Jan 23, 2011, 10:23 AM View Post
Westrope
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Apr 01, 2011, 11:06 PM
rotagen is online now
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Has anyone actually used the calculated spot on one of these CG calculators and had it work in real life? Every wing I try them on puts the CG too far back. Sometimes they "almost fly" but are wickedly unstable.
rotagen is online now Find More Posts by rotagen
Old Apr 01, 2011, 11:40 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Maybe you would like this better
nmasters is offline Find More Posts by nmasters
Old Jun 10, 2011, 07:26 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I've used this one. It gives a comfortable flight envelope. Usually, for more "intense" flying you can move the CG further back, but the starting point is good.
Up&Away is offline Find More Posts by Up&Away
Old Jun 14, 2011, 10:10 AM
sean.belardo is offline
Find More Posts by sean.belardo
sean.belardo's Avatar
United States, DE, Newark
Joined Mar 2010
Multi Sweep wings
Dear RC groups,
I've been searching for months for an EQUATION and/or a graphical method of finding the MAC and MAC location for a multi-swept wing.
PLEASE HELP, this has been bugging me for the longest time. lol
-Regards,
Sean
sean.belardo is offline Find More Posts by sean.belardo
Old Jun 14, 2011, 12:20 PM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Originally Posted by sean.belardo View Post
Dear RC groups,
-Regards,
Sean
The graphical method for a multi-panel wing involves cutting the wing up into an appropriate number of trapezoids and find the center of each trapezoid then using the MAC of two adjacent trapezoids make an intermediate trapezoid and find the center of that. Repeat as many times as necessary. It can get pretty tedious!
this program handles complex planforms with up to 5 panels
--Norm
Old Aug 09, 2011, 03:20 AM
DeltaMan is offline
Find More Posts by DeltaMan
Believes in Foamies
DeltaMan's Avatar
Greece/Thessaly/Trikala
Joined Apr 2005
This programm has Literally solved Many of my issues.
Congratulations to the designer and his will to freely share it with us...
I was just wondering if something like a rectangular center section could be incorporated in the Equations, just like the attached picture, which will be as easy as it is now to calculate and view...
Thanks in Advance,
DM
DeltaMan is offline Find More Posts by DeltaMan
Old Aug 09, 2011, 11:46 AM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Did you look at the link in the message #72?
Old Aug 22, 2011, 03:50 PM
Vitamin_J is offline
Find More Posts by Vitamin_J
Denver, CO
Joined Dec 2004
Thanks for this awesome tool! Maidened my scratchbuilt wing this weekend.
Scratchbuilt Lotek50 Maiden Flight (0 min 52 sec)
Look how well it flies before I mess it up with my thumbs!
Vitamin_J is offline Find More Posts by Vitamin_J
flying wing cg ?'s mscj Foamies (Kits) 1 Mar 03, 2003 09:53 PM
Flying wing CG with shortened span MSB Foamies (Kits) 2 Jul 28, 2002 07:23 PM
Flying Wing CG Choppa Nutta Power Systems 8 Apr 17, 2002 11:45 AM
Flying Wing CG Paul Susbauer Parkflyers 2 Jan 29, 2002 01:31 PM
Flying wing CG Anders Power Systems 4 Oct 05, 2001 04:39 AM
