This thread is privately moderated by z80, who may elect to delete unwanted replies.
Old Dec 26, 2008, 05:55 AM
z80 is offline
z80
Find More Posts by z80
z80
Copenhagen, Denmark
Joined Sep 2006
Flying wing CG calculator
I wrote a little CG calculator for flying wings. If you have a HTML 5 browser supporting the canvas object you will get a little image of the wing too.
http://fwcg.3dzone.dk
Bug reports and suggestions are very welcome.
z80 is offline Find More Posts by z80
Old Dec 26, 2008, 08:25 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
z80 ?? Wasn't that an early processor we used back in the CPM days??
Neat calculator. Appears that the area computation is showing a value double what it should be. Also appears that the sweep angle to be specified is the sweep of the wing's quarter chord. If I am correct, you might mention that.
HerkS is offline Find More Posts by HerkS
Old Dec 27, 2008, 02:11 AM
z80 is offline
z80
z80
Copenhagen, Denmark
Joined Sep 2006
Yes, that's right. It was also used in the ZX Spectrum computer from 1982. That was my first computer. I spend some time writing a ZX Spectrum emulator for the PC, so that is where that nick is from.
You're absolutely right -- by mistake i took the span-variable in the script as half the span when in fact it was the full span. So a division by 2 was missing. That is corrected now. Thanks.
The calculators sweep is defined as the distance the tip is offset from the root and not an angle. That is kind of unclear of course. The different values should be displayed visually somehow, so its clear what they mean. Would be cool if the image showed some help based on what input-field has focus.
Thanks for the feedback :-)
Old Dec 27, 2008, 06:12 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
[QUOTE=z80]Yes, that's right. It was also used in the ZX Spectrum computer from 1982. That was my first computer. I spend some time writing a ZX Spectrum emulator for the PC, so that is where that nick is from.
QUOTE]
Nice beginings... My first computer was also a ZX81 Taught my self more on that than on most other after that.. (exept for the c64) The zx81 taught me how to program tight ML code... Poke and save....
OT.
Is there a way to make this work with out having to resort to firefox.. Limmits me from using it at work for sure..
PaulVi is offline Find More Posts by PaulVi
Old Dec 28, 2008, 04:56 AM
z80 is offline
z80
z80
Copenhagen, Denmark
Joined Sep 2006
Another Sinclair machine :-) I spend a lot of time coding machine code as well. Great fun. A very good way to learn the basics using simple machines like that.
Lack of IE support was a problem for sure. I added IE support now using ExplorerCanvas Let me know if it doesnt work.
Old Dec 28, 2008, 12:57 PM
rockyabq is offline
Find More Posts by rockyabq
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Originally Posted by z80
CG calculator
Sweet.
No wonder my Flik flies so poorly.
rockyabq is offline Find More Posts by rockyabq
Old Dec 28, 2008, 01:40 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Nice!
Would it be possible to enter an angle in degrees of the leading edge as an alternative to the Sweep?
Also, a little image describing where to find the required values at a real wing might be helpful for dummies.
Example:
http://www.maltemedia.de/swp/
Julez is offline Find More Posts by Julez
Old Dec 28, 2008, 03:17 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
That did the trick... Nice work
Old Dec 28, 2008, 04:02 PM
z80 is offline
z80
z80
Copenhagen, Denmark
Joined Sep 2006
Excellent suggestions. I implemented both now
Alrighty
Old Dec 28, 2008, 04:26 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Cool!
This looks like my favorite CG calculator now.
But I noticed, that the default 25% MAC value might be a little aft. My practical results seem more like 20%.
How about 3 boxes or something, that can be klicked, and enter predefined values like:
15% - for beginners/ testing new planes
20% - allround
25% - for experts
This might also be helpful for newbies, who have no clue, and affiliate "MAC" with greasy burgers.
Cheers,
julez
Old Dec 28, 2008, 04:58 PM
z80 is offline
z80
z80
Copenhagen, Denmark
Joined Sep 2006
Cool
20% - allround
25% - for experts
Another fine suggestion... Done
Old Jan 26, 2009, 06:07 AM
bolkow is offline
Find More Posts by bolkow
Pilipinas
Joined Mar 2005
Great idea here Z80, very helpful. Now I can more confidently build flying wing foamies of own design without having to resort to trial and error (mostly error) on maiden. Thank you very much.
bolkow is offline Find More Posts by bolkow
Old Jan 27, 2009, 02:40 AM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
very helpful thanks
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Jan 27, 2009, 06:14 AM
Rolland Benson is offline
Find More Posts by Rolland Benson
United States, MI, Parma
Joined Aug 2006
I know this is a wierd request, but I need some help on this one. I have built a forward swept wing and am having trouble calculating where the CG should be. I entered the sweep as a negative number and the calculator did not like that.
If anyone has some ideas on this Thanks in advance.
Rolland Benson is offline Find More Posts by Rolland Benson
Old Jan 30, 2009, 07:12 AM
ddoth is offline
Find More Posts by ddoth
The Hippy
ddoth's Avatar
Australia, WA, Perth
Joined Nov 2008
Not too sure if this would work but put the figures in as if the plane were facing the other way (normal swept wings) and instead of CG being 15% for beginners put in the custom value as 85%.
Point marked and rotate the plane back around, CG will then be 15% as such.
Hopefully making sense.
Goodluck
ddoth is offline Find More Posts by ddoth
flying wing cg ?'s mscj Foamies (Kits) 1 Mar 03, 2003 09:53 PM
Flying wing CG with shortened span MSB Foamies (Kits) 2 Jul 28, 2002 07:23 PM
Flying Wing CG Choppa Nutta Power Systems 8 Apr 17, 2002 11:45 AM
Flying Wing CG Paul Susbauer Parkflyers 2 Jan 29, 2002 01:31 PM
Flying wing CG Anders Power Systems 4 Oct 05, 2001 04:39 AM
