Old Mar 28, 2009, 08:34 AM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
The radio is all hooked up. Remember back when I installed the KB doublers the wrong way? I had to make a little piece so the rudder arm woyuld contact the horn switch.
CG Bob is offline Find More Posts by CG Bob
Old Mar 28, 2009, 08:40 AM
420TEE is online now
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
Same set-up as my Lyman. The horn only works at full rudder deflection so you can't toot it while motoring around at speed. Not very useful.
420TEE is online now Find More Posts by 420TEE
Old Mar 28, 2009, 01:17 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
427TEE-I agree that the system for the horn installation is not a blow your horn while under way setup, but it does serve the purpose that it was meant for, which was a way to blow the horn from the simplest two channel radio installation. If you have a three channel or more radio, you can operate the horn at any time while running with the use of another servo. As for blowing the horn, even in my real boat, it is done when leaving the dock, backing down , or coming along side another boat, to let them know I am there, all of which times I am in neutral when I blow my horn. Just some food for thought.
frankg is offline Find More Posts by frankg
Old Mar 28, 2009, 01:35 PM
Joined May 2006
You're in neutral when approaching another vessel? Interesting technique.
Old Mar 30, 2009, 03:06 PM
CG Bob is offline
KC8WPF
CG Bob's Avatar
Joined Sep 2004
Getting closer to finishing the model. I have the cockpit sides and dash board installed, as well as the shelf in the rear cockpit. The engine room hatches have been installed; I need to poloish the aluminum trim and install it. The metal hinge frames for the front windshield have been installed; I have a slight problem with the rear windshield hine brackets - one is a little longer.
Old Mar 31, 2009, 08:52 AM
Keyzersooze is offline
Find More Posts by Keyzersooze
Keyzersooze's Avatar
Joined Mar 2009
I have read your buildlog religeously, great build, fantastic finish and lots of invaluable tips and lessons to be learnt for Ś novice like me!
I will no doubt check in this log for inspiration and help during my own build.
Thanks!
Keyzer
Keyzersooze is offline Find More Posts by Keyzersooze
Old Apr 02, 2009, 09:56 AM
CG Bob is offline
KC8WPF
CG Bob's Avatar
Joined Sep 2004
I got the engine hatches trimmed out yesterday, The kit provides aluminum strips that needtobe polished and taped tothe engine hatches. The hatch handles are made from aluminum rod, turned aluminum acorns for the end, stainless steel cotter pins, and pop rivets. The pop rivet pulling stem (or nail) is removed, and the actual rivet part is used as the standoff.
Old Apr 02, 2009, 01:42 PM
keith S is online now
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
I like the pop rivit idea fr the stand offs. Model is looking very good.
keith S is online now Find More Posts by keith S
Old Apr 05, 2009, 06:38 PM
CG Bob is offline
KC8WPF
CG Bob's Avatar
Joined Sep 2004
I took the model to Toledo on Friday. MACK Products had a new pair of rear windshield hinge frames waiting for me. We compared notes about the model; I'd buy and build another one. I finally got the rear windshield installed Friday night; and some of the final little trim details completed Saturday night. Now I have to wait for the weather to break so I can go to the lake and test this little gem.
Old Apr 05, 2009, 07:00 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Looks great!
Kmot is online now Find More Posts by Kmot
Old Apr 05, 2009, 07:19 PM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Very Nice.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Apr 06, 2009, 12:35 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
I like it!!!
MILLERTIME is offline Find More Posts by MILLERTIME
New Product 1930 DODGE 21'6" SPLIT-COCKPIT RUNABOUT frankg Scale Boats 54 Nov 01, 2010 05:00 AM
Gallery Chris-Craft Triple Cockpit Runabout oldtribefan Scale Boats 86 Oct 02, 2008 01:27 AM
For Sale Crystal Channel 21 - $6 caseym Aircraft - General - Radio Equipment (FS/W) 1 Feb 18, 2008 07:31 PM
