Go Back   RC Groups > Aircraft - Electric - Airplanes > Electric Plane Talk
Old Jun 09, 2001, 02:00 PM   #1
Zagi 'MK II' has MAJOR range problems. Advice?
I took Zagi ‘MARK II’ in her new livery for her first flight today. She was a *dog* to fly, pitching up repeatedly, but not consistently with the gusts of wind. I eventually managed to wrestle her to the ground. We were baffled – tail weight? Nose weight? etc. Finally someone said ‘Have you tried a range check?’ D’oh – the one time I forget!!
Anyway, I collapsed the tx antenna, put it on the ground and walked away from it whilst holding the plane, motor off. Not 10 feet away, the servos start to chatter and 10-15 feet away, they go wild. I’ve tried eight combinations – two transmitters, using channel 68 and 69, and doing a range check at home and at the club (some 15 miles apart). They all have the same result. That should rule out the tx, the xtals and the location (no background interference). So what could it be? Either:
1) I covered the Zagi with silver Oracover/Profilm/Ultracote. If it were metallised (I don’t know) it would cause problems as the aerial runs under the covering.
2) The aerial goes in a rectangular loop (as per the instructions). Unfortunately this causes it to go directly under the motor and perpendicular to the metal control rods.
Any suggestions on what I can do? It looks like I’ll have to strip off the covering. Nooooo!
Thanks in advance,
Ben C
Ben C is offline Find More Posts by Ben C   Reply With Quote
Old Jun 09, 2001, 02:10 PM   #2
PS. I use a Hitec 555 which served me fine in the old zagi.
Old Jun 09, 2001, 03:40 PM   #3
I just separated the layers of the Oracover, and yes, there is a metallic layer which I have tested with a voltmeter. Guess what? It conducts electricity. It is metal foil.
I can now congratulate myself on flying a plane with an almost perfectly sheilded receiver. Let this be a warning to everyone out there thinking of using silver/chrome ultracote!
Ben C
[This message has been edited by Ben C (edited 06-09-2001).]
Old Jun 09, 2001, 03:42 PM   #4
Use a different TX with the antenna hanging outside the plane.
hoppy
hoppy is offline Find More Posts by hoppy   Reply With Quote
Old Jun 09, 2001, 07:03 PM   #5
Get One Up!
Gold Member
leccyflyer's Avatar
Ben
The chrome Profilm has been blamed for interference problems in the past. You probably hit the nail right on the head and unfortunately lifting the aerial outside of the covering might not help if the bottom of your Zagi is covered with the chrome film as well the aerial might well still be shielded by the film.
Looks like you might well have to strip off the covering.
Brian
leccyflyer is offline Find More Posts by leccyflyer   Reply With Quote
RFFS-100: Some major range problems. Love some help =] Bschulz Indoor and Micro Models 5 Mar 08, 2005 11:43 PM
Range check advice - BEC cutoff and short range!!! JensJakob Electric Plane Talk 3 Aug 07, 2001 04:56 PM
CockpitMM range problems - channel 84, UK Moogee Power Systems 1 Jul 02, 2001 04:24 AM
Range problems with new set up AW Power Systems 2 Jun 15, 2001 08:57 AM
Radio range problems Steve Blampied Electric Plane Talk 14 Jun 06, 2001 09:24 AM
Bored? Want to fight?
Join the RCGroups clan!
