Old Dec 25, 2008, 12:37 PM
neavissa is offline
Find More Posts by neavissa
Santa brought me a Futaba 3VCS 2.4GHz...now what?!
hi there,
i got for Christmas the Futaba 3vcs which uses the same 2.4GHz as the 3PK. the main question now is: what now?! what is the best way upgrade my other cars?
i have 3 cars. nitro muggy, RC10B4 and E-maxx. i would like to install the 2.4GHZ in the nitro car. what should i do about the other cars? get 2 more receivers or get a FM module? the thing that worries me the most is that i read somewhere that the futaba fasst will only work with futaba servos or at least only with digital servos...
what do you guy think is the best way to upgrade?
thanks and merry Christmas
G
neavissa is offline Find More Posts by neavissa
Old Dec 25, 2008, 02:27 PM
Finnspeed is offline
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
Originally Posted by neavissa
hi there,
G
Don't worry, that's not true. The FASST systems will work with practically any servos.
My recommendation would be:
- for expensive models/cars use FASST receivers
- for the cheap stuff, use a FM module and FM receivers if you have many of those
Finnspeed is offline Find More Posts by Finnspeed
Old Dec 25, 2008, 06:54 PM
neavissa is offline
thanks, that's good new...i was thinking about the same thing...getting an FM module and keep everything the way it is and use the receiver that came with it, in my nitro muggy...
thanks
G
Old Dec 26, 2008, 12:42 AM
Silent-AV8R is online now
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
United States, CA, Ladera Ranch
Joined Aug 2004
Futaba FASST radios have two transmission modes, PPM and HRS.
In PPM mode you can use analog and digital servos, mix and match to your heart's desire.
In HRS mode you MUST use digital servos or you will get funny movement of the servo and will burn it up.
Brand of servo is not important. Type of servo is.
You do have to use the Futaba receivers. No other brand of receiver will work with that transmitter. The 603FS and 603FF are the two receivers for your radio.
The FF has a single external antennas. The FS has an external antenna and a second, internal antenna mounted on the PC board. Some say they notice a difference in range, etc. I have not made the same observation.
Silent-AV8R is online now Find More Posts by Silent-AV8R
Article Futaba 6EX 2.4GHz Full Range 6 Channel System Review pda4you Radios 85 Dec 12, 2014 04:49 AM
Discussion Futaba FASST 2.4GHz - Actual Field Results hilgert Radios 453 Jun 03, 2008 10:37 PM
Discussion Futaba announces 2.4GHz for Parkflyers... Rudy Vienna Radios 106 Mar 26, 2007 07:09 AM
Question Santa brought me a GWS Dragonfly....now what do I do? machmanchuck Micro Helis 6 Dec 26, 2006 10:50 AM
Santa brought me an Accord from NESAIL what next! Fast-Forward Sport Planes 14 Jan 04, 2002 07:33 PM
