Old Mar 04, 2003, 11:05 AM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
Which Li-Poly pack for a Tiger Moth ?
Considering the purchase of a Li Poly pack for my stock GWS Tiger Moth. Right now I'm using a 7x300 GP Nimh pack. What are you folks using in your Moths, and where to purchase them ?
Al
Al P is offline Find More Posts by Al P
Old Mar 04, 2003, 11:24 AM
LJH is online now
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Al,
Hmm...seem to be spending time in all the same places . My brother and I are both having great success with 2S 1020 Kokams, for under $20.00 you can build yourself a pack that will give 60 min flight times, and lose a little weight. My brother is flying his in his TM and I have them in my SR Bantam Bipe. I got mine from Troy at www.b-p-p.com He is a nice guy and offers great service.
Cheers again,
Jim
LJH is online now Find More Posts by LJH
Old Mar 04, 2003, 11:32 AM
Al P is offline
Iowa
Joined Aug 2000
Hi Jim, and thanks again !
Yeah.....it's snowing and blowing out. I have to go outside eventually, but putting it off. Thanks for the suggestions, and I agree about Troy. I checked his website earlier and unfortunately he has lost a family member. Sorry to hear that Troy. I'll check back with you at a later date.
Best to all
Al
Old Mar 04, 2003, 12:19 PM
anixs is offline
Find More Posts by anixs
Edmonton, AB, Canada
Joined Oct 2002
I'm using a 830mAh pack from http://www.lightflightrc.com -- it fits in the Tiger Moth's battery compartment with no need to hack foam or make CG adjustments. And, I can easily fly for 45+ minutes on it. Battery is less than $20.
You'll get more runtime from the Kokams, but you have alter your plane to use them.
anixs is offline Find More Posts by anixs
Old Mar 04, 2003, 02:45 PM
tenover is offline
Find More Posts by tenover
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Thanks for the tip anixs....I just ordered one of the 830 li-ions from them. You're really getting 45 minute flight times? With what kind of throttle management? I bought a similar pack at the MWE a few weeks ago and charged it, then bench ran it and now I'm getting short 3-5 minute "burst" runs, then have to land, then do it again,etc....I've since changed the motor out for a new one, so I'm hoping a new pack will solve my problems. Did you charge it before you ran it the first time or does it come charged?
tenover is offline Find More Posts by tenover
Old Mar 04, 2003, 02:51 PM
Al P is offline
Iowa
Joined Aug 2000
Thanks for the tip anixs, but the 830 appears to be Li-ion not Li poly. I am trying to stay away from the li-ion and the dangers associated with them. I understand the li-poly packs are much safer.
Al
Old Mar 05, 2003, 05:43 PM
anixs is offline
Joined Oct 2002
tenover,
I usually fly the moth at full throttle. A friend and I went to the field armed with two 830 packs, and we left 2 hours later (all of that time spent flying). The packs come precharged. I love them! We were flying -5 C weather, I'm not sure if that had anything to do with it.
Unfortunately that specific pack is not useful in anything bigger than an IPS-A motor running a 9x7 or 10x4.8 prop. That means it's perfect for the moth.
Al,
Good point -- they are LiIon. No problems so far, however.
Which Li-Poly pack for the Hummingbird Flyboy70 Micro Helis 32 Apr 22, 2004 08:36 PM
Flight Pack! for Tiger Moth UWBob Parkflyers 2 Oct 17, 2002 09:25 PM
Zener Diode to Drop 3xQ830 li-Ion Voltage for Tiger Moth AndrewsJr Power Systems 2 Feb 24, 2002 10:04 PM
Best battery pack for Tiger moth? spinnetti Parkflyers 35 Feb 13, 2002 02:28 PM
Anybody know who sells the special Pico Pack for the Tiger Moth? mrebman Parkflyers 2 Jul 25, 2001 11:25 PM
