Old Dec 23, 2008, 09:51 PM
jshander is offline
Find More Posts by jshander
Waukesha, WI
Joined Dec 2006
model boat stand tips
When building wooden boat stands I had used self adhesive velcro to cushion the boat against the stand since the self stick rubber foam seems to get sticky with time. Lately I have been using GE RTV silicone caulking. I put wax paper between the boat and the wood stand leaving it to dry for three days before removing the boat and the wax paper. One of the guys in the club says this may eventually start sticking to the bottom of the boat after years like rubber does.
What are the rest of you using between the boat and the wood stands?
Jim Shander
jshander is offline Find More Posts by jshander
Old Dec 23, 2008, 10:01 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
Felt.
See some discussion at
http://www.rcgroups.com/forums/showthread.php?t=953819
patmat2350 is offline Find More Posts by patmat2350
Old Dec 23, 2008, 10:06 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
short haired carpeting
freechip is offline Find More Posts by freechip
drakonis is offline
Find More Posts by drakonis
AMA 743519 Team Heliproz Pilot
drakonis's Avatar
United States, WA, Granite Falls
Joined Mar 2006
i just might have the solution for you. i have a victoria sailboat and i have a really nice painjob on it and i didnt want to ruin it with the black neoprene rubber thats supplied with the kit. so i super glued washcloth to the black rubber. make your strips about an 1" to 1.5" wide and glue one edge first then fold over the glued point and glue the other edge after folding under. so you are kind of making a hoop with the cloth. with both edges glued basicly together then glued to the rupper on the stand. i have used this method for a long time and no damage to the paint not even a mark. and its a soft resting spot for the hull. hope this helps.
drakonis is offline Find More Posts by drakonis
Old Dec 23, 2008, 10:14 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
This has worked for me for years now. Never had an issue.
http://www.rcgroups.com/forums/showp...6&postcount=13
woodybob is offline Find More Posts by woodybob
Old Dec 23, 2008, 10:30 PM
LONGBIKE is offline
Find More Posts by LONGBIKE
If you cant find it Build it!
LONGBIKE's Avatar
NEAR ST. LOUIS ILL. SIDE
Joined Jan 2006
You can go to any craft store and pick up some felt in different colors with a peel and stick backing.
LONGBIKE is offline Find More Posts by LONGBIKE
Old Dec 23, 2008, 11:15 PM
tigerbay is offline
Find More Posts by tigerbay
Joined Sep 2006
The foam exercise mats you can buy cheap in any sports store or supermarket.
I have cut off strips and used this, glued on with contact adhesive.
You can also cut off a wider bit as a mat for your butt when sitting in the wet, or kneeling on when launching in the rain.
tigerbay is offline Find More Posts by tigerbay
Old Dec 24, 2008, 09:50 AM
b willow is offline
Find More Posts by b willow
Joined Jun 2007
If you wipe down your boat as you should try the insulating strips in the window and
door section it comes in different widths and thickness.
Bob
b willow is offline Find More Posts by b willow
Old Dec 24, 2008, 09:59 AM
windwarrior6682 is offline
Find More Posts by windwarrior6682
windwarrior6682's Avatar
Sunny South Florida
Joined Sep 2004
Here is a great Stand/Carrying Box that was published in the Seawind Newletter. This Stand/Carring was design by Roger Skold.
windwarrior6682 is offline Find More Posts by windwarrior6682
Old Dec 24, 2008, 10:42 AM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
I got ahold of some felt left over from covering a pool table. Cut strips and white glued them to the cradle. Works fine so far. No problem with the paint on Athena and the felt stays put no problem. Pete
norgale is offline Find More Posts by norgale
Old Dec 24, 2008, 11:16 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I like using pipe insulation for padding.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Dec 24, 2008, 11:34 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Makes for a cushy perch.
Old Dec 24, 2008, 06:22 PM
jshander is offline
Waukesha, WI
Joined Dec 2006
Thanks everyone for all the great ideas.
Old Dec 25, 2008, 10:43 AM
tc432 is offline
Find More Posts by tc432
United States, NY, Holtsville
Joined Aug 2005
Dont forget the other purpose of a boat stand is that it should be designed to help keep the boat protected from damage in your vehicle when going to and from the lake.
A design that allows the model to easily slide forward and back or jump off the stand when you are carrying the boat or in the car hit a bump,turn or stop short can ruin your boat.I learned this the hard way when trying to avoid hitting a dog. The model slid right off the stand and into the dashboard. Fido survived just fine my boat got smashed. Now I put stoppers on the end to keep models more secure and take more time to pack them in the car to limit their movement.
tc432 is offline Find More Posts by tc432
Yippee! Model Boat Show George Pfeifer Dock Talk 17 Aug 18, 2003 07:53 PM
