Old Mar 04, 2013, 03:10 AM
bbz is offline
bbz
Find More Posts by bbz
bbz
bbz's Avatar
Australia, QLD, Aroona
You can glue the wings together and the spar in but leave the spar cover unglued and just tape it on. That i will give you access to the servo wire should you need to do anything with it.
I cut the spar cover at the point the servo wire comes out and left the inside bit removable.
bbz is offline Find More Posts by bbz
Old Mar 04, 2013, 03:22 AM
Stuka_99 is offline
Find More Posts by Stuka_99
Callsign: Zulu
Stuka_99's Avatar
Somewhere in the skies!
Joined Feb 2011
One trick if you want to glue them in is to use servo extenders. Cut the recess in the wing (the cover of the pushrod sits in) in half or depending on the length of your extenders and double the servo wires to make them fit in. This way, you can glue the wings and change your servos whenever the need arises by simply taking the tape off the recess and taking it off. I did it on mine. Glue half of the recess and tape the other one, obviously the one that you will use as a trap door!
Stuka_99 is offline Find More Posts by Stuka_99
Old Mar 04, 2013, 08:36 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
AXN Hybrid build and Maiden flight
As promised here is a quick build log on film and the maiden ... all a bit rushed .. It is a little heavy and not as fast as a stock AXN (probably all the hot glue and tape) However it flies nice an docile and didn't even feel like tip-stalling. I had 3 flights with it that day and managed a 20 min flight with thermals ... the other 2 were 12 minutes and 15 mins ... the batteries came in at about 3.78/9 per cell. This may be a candidate for an upgrade motor nad one of sotogs mounts ... or if someone in Melbourne has $20
AXN hybrid (6 min 31 sec)
mutha is offline Find More Posts by mutha
Old Mar 05, 2013, 04:23 PM
Gravet is offline
Find More Posts by Gravet
Joined Feb 2013
Is HK the best (cheapest) place to find the AXN (bare-boned)? They actually don't offer it in the bare-bone setup at a US warehouse which puts the price up to $58 for the plane and motor (no electronics). Has anyone from the US put together a parts list like BBZ did in post 12415 that would be the cheapest options for someone living in the US?
Gravet is offline Find More Posts by Gravet
Old Mar 05, 2013, 09:32 PM
bbz is offline
bbz
bbz
bbz's Avatar
You should be able to use my list and click "This product available from a warehouse near you!"at the bottom of the listings, The only thing that was not available locally in Australia was the motor. One thing i should have ordered but didnt was some 3.5mm or higher banana plugs for the esc to motor connection because the D2826-6 motor comes with male plugs but no females.
Old Mar 05, 2013, 10:02 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I think I need to upgrade my AXN to a 4s setup. It's feeling really slow lately, even with the full wingtips cut off. I already have a 4s 2200 and 45 amp trust esc and I'm waiting for the 2200kv NTM to come back in stock.
Sotog, how long until the CNC mount is released?
gooby is offline Find More Posts by gooby
Old Mar 05, 2013, 10:30 PM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
You will enjoy this setup very much. Not sure 45amp ESC will be enough. It easily will pull 48-50 amps. I use a 60 amp ESC.
hendrnk is online now Find More Posts by hendrnk
Old Mar 05, 2013, 10:57 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
With a 6x4 it will definitely go over 45 amps, but according to hobbyking a 5x5 should only be 35A. I have the same esc (Turnigy Trust) in another plane that draws close to the max but it still runs cool. I think I should be ok by using a 5x5, but I will have to wait and see.
Old Mar 05, 2013, 11:28 PM
Joined Apr 2012
In use a 6x5 to take advantage of the motor. It's goes like a rocket.
Old Mar 05, 2013, 11:33 PM
Swammy1979 is offline
Find More Posts by Swammy1979
Crashmaster
Swammy1979's Avatar
United States, CA, Lakewood
Joined Jul 2012
Why even tempt fate? If you care about your plane, then you should use a higher esc. Go for a 70 amp esc and then fly away to your heart's content without worry of burning it out. You'll be able to swing whatever prop you please (within reason).
Swammy1979 is offline Find More Posts by Swammy1979
Old Mar 05, 2013, 11:54 PM
Joined Apr 2012
This is a nice ESC, very thin & light and works fine.
http://www.hobbyking.com/hobbyking/s...dProduct=24717
Old Mar 06, 2013, 12:39 AM
tbob18 is offline
Find More Posts by tbob18
Joined Aug 2012
That looks pretty nice. Would the NTM 2700kv be a good match for that, or is that a little overkill?
tbob18 is offline Find More Posts by tbob18
Old Mar 06, 2013, 09:19 AM
Joined Apr 2012
I have used that motor as well on the AXN and ESC with no problem. Depending on the prop used the motor can pull 45+ amps so it not really an overkill. Its seems lighter & thinner than most ESC of less capacity. So why not.!
I will be using it on my 70mm EDF AXN that I'm building now.
Old Mar 06, 2013, 07:27 PM
tbob18 is offline
Joined Aug 2012
Yeah I guess it is better to overestimate a bit when it comes to the ESC.
I was thinking about using it with that NTM and 6x4 prop with a Zippy 40c 2200mah 3s battery. From what I understand, It should give similar thrust as a 4s on the 2200kv NTM but last a little longer on a charge.
Old Mar 06, 2013, 11:57 PM
sotog is offline
Find More Posts by sotog
sotog's Avatar
United States, CA, Santa Barbara
Joined Nov 2009
Hi gooby,
Right now we have them scheduled to run mid next week. It is actually next on our list, so as soon as our current job is finished I will get right on them.
Sorry I couldn't get them out this week. I really wanted too.
I'll post some pictures of the final product when they are ready to ship.
Terry
sotog is offline Find More Posts by sotog
Site Sponsor
