Joined Apr 2012
http://www.alofthobbies.com/new-stuf...ing-films.html |
Australia, QLD, Beaudesert
Joined Jul 2008
bbz, Hi, normally no need to cover wing at all, BUT, if you read back a few posts, you will see I have cut the w/s back down, and altered the wing profile, and I need to smooth the foam back a bit, as I need the speed!!
Neal PS I would like something I can spray on perhaps, I would like to keep the weight down |
Joined Jul 2008
bbz if yoou look at the l/e of the wing, it is rounded at the front just simply the shape, So I filed and sanded all along the wing and reshaped the profile, the wing is now a bit flatter to make it a lot sharper ie more aerodynamic. More speed!!
With the larger motor and prop I have now ordered, this plane will go like poop off a shovel, so shortening wings cutting dow tailplane and stab/rudder, cleaning up l/e, should help Neal |
I'm looking forward to getting this new design finished. Should really solve some of the problems with the stock mount and make it simple to swap out motors. Just finished running a batch of our new Super Sky Surfer adjustable mount. I'll have that one up in the classifieds later tonight. Terry |
I just got my first AXN, I bought the bare bones kit and ordered gear separately.
Gear i got is as follows:With some added weight(50g) for the missing motor my AUW comes to 665g + maybe 5g of glue and tape. Does anyone know what sort of thrust my power system should put out? looking for at least a 1:1 thrust:weight. Has anyone had much success with extending the control surfaces? I am a reasonably experienced flyer and want to have a bit more aerobatic ability. I will eventually clip the wing tips, but want to leave them for now. Seeing as i have to wait to fly i have time to bling it up a bit. Ive removed the stickers and plan on painting it. Removing the stickers was easy enough. Using a hair dryer stopped the stickers from pulling up any material from the foam. I made up a template to design a scheme. I plan on spraying with cheapo enamel paints, which have worked for me before on depron. Ive attached a clean template for anyone to use in png and adobe illustrator(zipped) formats. |
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
Here are a few drawings of the new AXN Floater Jet Adjustable Aluminum Mount.
This will allow to easily mount most any 28mm outrunner motors as well as the stock motor. You can run the 28mm outrunner motors in 3 positions: Stock for up to a 6" prop +.45" for up to a 7" prop +.9" for up to an 8" prop The new aluminum base piece has 4 threaded M2 holes that line up with the stock motor. No more worries of the small nuts behind the plastic piece becoming unglued. For the 28mm motors, you would first attach the motor plate to the back of the new motor, then attach the assembly to the base piece at the desired height with 2 M3 screws. If you drill a small hole into the foam nacelle, in the stock location you can run the 28mm motors that have a bolt on propeller shaft (motor shaft sticking out the back). Or you can run them in the +9" location. To install, you will first need to remove the black plastic mount. I was able to do this fairly easy by lifting up on the top flat piece, and pushing it back while prying the side of the oval section. It popped off with a bit of pressure. Next you would glue the flat base piece onto the foam where the plastic piece was. 5min epoxy works very well. Once dry, it is ready to go. Should have parts ready in about 2 weeks. Terry |
