Old Feb 15, 2013, 10:03 PM
perdification is offline
Find More Posts by perdification
Joined Dec 2012
Originally Posted by mutha View Post
In the mean time if your mount is loose then pull it off an re-glue. It has nuts on the back for the mount screws - you need to get them back on the plastic. Another option is just to put some CA in the holes and screw a self tapping screw into that.
Sorry I didn't explain my question properly. It is the part where the motor screws into the plastic motor mount that is loose, because the thread in the holes for the screws on the motor mount have been stripped and the hole is now enlarged. This makes the motor loose on the motor mount. But you gave me a great idea. I could just fill epoxy into the screw hole on the motor mount, then drill a smaller hole and fit in a self tapping screw. Hope this would work. I don't currently have epoxy though. Would CA work?
perdification is offline Find More Posts by perdification
Old Feb 15, 2013, 10:43 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I flew some night fpv with my clipped wing axn! So much fun flying 70mph only a few feet above grass fields. I think the key to fpv with an AXN is to keep everything lightweight and simple. I'm using the fpv backpack (as described by Xjet) and an AR6115e receiver. No problems with wires everywhere or weight.
It's the perfect setup for me.
gooby is offline Find More Posts by gooby
Old Feb 16, 2013, 05:02 AM
Jake Bullit is online now
Find More Posts by Jake Bullit
Fly,crash,glue,repeat!
Jake Bullit's Avatar
Southport,N.W. England
Joined Nov 2007
Originally Posted by Corran View Post
Hi!
Today I took my first run with
Sorry if you have talked about this before. But do anyone know of a good upgrade engine? My magnets allready trying to escape ^^
That would fit easy.
That's a great view showing the motor and control surfaces:thumbup:
Jake Bullit is online now Find More Posts by Jake Bullit
Old Feb 16, 2013, 05:12 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
Hi!
Today I took my first run with my AXN
http://www.youtube.com/watch?v=ZTnXJonkibg
D2826 2200kv is a good candidate never fail me yet but you will need at least 30aesc for it
skellator is offline Find More Posts by skellator
Old Feb 16, 2013, 05:37 AM
bbz is offline
bbz
Find More Posts by bbz
bbz
bbz's Avatar
Australia, QLD, Aroona
This has probably been addressed but this thread is so huge its hard to find answers.
Im wondering if there is a good alternative motor available from hobbyking that does not have issues with magnets falling out. One that will use the same sort of gear ie: 2200mah 3s and 25a ESC.
aaand never mind, skellator has answered the question above, i should have refreshed.
bbz is offline Find More Posts by bbz
Old Feb 16, 2013, 06:00 AM
9W2DLR
Joined Nov 2011
Originally Posted by bbz View Post
this has probably been addressed but this thread is so huge its hard to find answers.
Im wondering if there is a good alternative motor available from hobbyking that does not have issues with magnets falling out. One that will use the same sort of gear ie: 2200mah 3s and 25a esc.
:d
Description:
Old Feb 16, 2013, 06:02 AM
bbz is offline
bbz
bbz
bbz's Avatar
Originally Posted by skellator View Post
what prop are you using there? 6x4?
Old Feb 16, 2013, 06:10 AM
9W2DLR
Joined Nov 2011
yes TGS 6x4E props
Old Feb 16, 2013, 06:26 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
yes TGS 6x4E props
I had been getting TGS from HK (dont' know if they are what they claim) but I haven't had one that is even close to balanced. I have started using APC props (6x4) because they are a lot closer to balanced from the get go.
mutha is offline Find More Posts by mutha
Old Feb 16, 2013, 06:28 AM
mutha is offline
mutha's Avatar
Joined Jan 2011
I use CA and wait till it is nearly fully set ... then just screw into it ... works for me. [edit] Sorry to be more accurate .. the CA works better because it wiks into the surrounding foam better than Epoxy just drizzle it on in there for a quick fix.
Old Feb 16, 2013, 07:29 AM
Joined Dec 2012
Oh right, thanks for the tip friend. Will do just that!
Old Feb 16, 2013, 07:32 AM
bbz is offline
bbz
bbz
bbz's Avatar
is there anything comparable to the axn in 4 channels for a sim preferably either realflight or phoenix?
Old Feb 16, 2013, 08:01 AM
9W2DLR
Joined Nov 2011
i got all my prop from local hobby shop, i never used apc before only prop i use are tgs and master air screw, yeah there are kinda off balance need to balance them before putting them on then plane
Old Feb 16, 2013, 08:06 AM
bbz is offline
bbz
bbz
bbz's Avatar
I found this Easy Star for realflight, its almost the same, just not as powerful as the axn
Get both these
http://www.knifeedge.com/forums/down...=file&id=13455
http://www.knifeedge.com/forums/down...o=file&id=3110
and use the aileron version.
Old Feb 16, 2013, 08:34 AM
9W2DLR
Joined Nov 2011
Get both these
actually you can just take any 4 channel electric plane and practice with it, as you are training the control of the plane not actually flying characteristics, on Phoenix i train with a flying wing
