Old Dec 08, 2012, 06:09 PM
paul2pilot is offline
Find More Posts by paul2pilot
paul2pilot's Avatar
Huntington Beach, CA
Joined Jan 2011
I am surprised anyone would feel the need to upgrade to a bigger motor and battery. I just tried this silly little 3 blade propeller and it fits perfectly:
http://www.hobbyking.com/hobbyking/s...dProduct=23966
and I used this colet adapter:
http://www.hobbyking.com/hobbyking/s...dProduct=19593
I am using a tired old 3S battery (20C) and the new prop has about 2mm clearance with the fuselage. This thing is much quiter now and it is insanely fast. It pulls about 28 amps when the battery is fresh, but that drops down pretty fast at full throttle with this battery. I toss it, literally piont it stright vertical and it climbs continuously until it's nearly out of sight. If I fly it around at full throttle, I am afraid it might rip the wings off. Now you can really feel the plane push nose down when you throttle it up. With that much power pushing above the Center of Gravity, you can really feel that effect now. That was one heck of a $5 investment.
paul2pilot is offline Find More Posts by paul2pilot
Old Dec 09, 2012, 01:05 AM
kennyhoc3 is offline
Find More Posts by kennyhoc3
kennyhoc3's Avatar
USA, ID, Boise
Joined Nov 2010
Yeah I guess I am just not that advanced of a pilot to need anything over 70mph lol I am sure one day I will! I huck it into the air as well and it takes off perfectly. I'm using a master airscrew 6x4 3blade and its sharp (cut my finger lol) and way quieter then the stock prop.
kennyhoc3 is offline Find More Posts by kennyhoc3
Old Dec 09, 2012, 01:24 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Mine is way more noisier than stock Sounds like a small jet!. Building another one with a upgraded 2700 KV motor with cut down wings. Will not fly as slow but should have a faster top speed.
hendrnk is offline Find More Posts by hendrnk
Old Dec 09, 2012, 02:24 AM
kennyhoc3's Avatar
USA, ID, Boise
Joined Nov 2010
I wonder how well they glide after cutting the tips off. sounds like fun haha
Old Dec 10, 2012, 12:21 AM
quacka is offline
Find More Posts by quacka
I have just bought the PNF kit for this. The wing servo on one side of the wing is not factory aligned correctly. On neutral position the flaps is a bit up compare to the other side.
Is there a good way to remove the servo for adjustment?
Also I am not sure how to put the props on, it comes with so many of them little black adapters. Which one do I use and how far does it need to go towards the end of the motor rod?
quacka is offline Find More Posts by quacka
Old Dec 10, 2012, 12:33 AM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
The servos are held in with double back foam tape. You can carefully pry up one side and then pull them out. Remove the foam tape and get them setup the way you want, then hot glue them in. I did this on both of my AXNs so that I could adjust the arms.
I use a bullet type prop adapter on mine, I believe that the shaft is 3 mm so this adapter should work.
http://www.headsuprc.com/servlet/the...r-3.0mm/Detail
Find the ring that fits snugly on the prop adapter and super glue it into the prop hole.
BGR is offline Find More Posts by BGR
Old Dec 10, 2012, 04:19 AM
quacka is offline
Thanks BGR. I will try to remove it in the weekend.
So the prop saver and plastic rings that comes with the kit is no good?
Old Dec 10, 2012, 04:22 AM
kennyhoc3's Avatar
USA, ID, Boise
Joined Nov 2010
Mine flew off within a few minutes of flying So I put the 3mm prop adapter on
Here is where I bought mine you get 2 for the price of one http://www.ebay.com/itm/200851108178...84.m1497.l2649
Old Dec 10, 2012, 03:32 PM
Motorbikebruno is online now
Find More Posts by Motorbikebruno
Crash Expert
United States, MN, Circle Pines
Joined Oct 2012
My brother and I just put this on ours
http://www.hobbyking.com/hobbyking/s...dProduct=28117
and the prop adapter
http://www.hobbyking.com/hobbyking/s...dProduct=24527
We had one flight on the stock setup, then 4+ of the magnets got loose. We didn't lose any of them, but I'm not going to trust the stock motor with my FPV stuff on it. Did about 4-5 minutes of flight and only lost .1V per cell on a 3S 2200mAh battery and 60amp Esc. Might be overkill, but we had the 60 amp esc laying around. Also using a Master Airscrew "Electric Only" 2 blade prop 6x3. Goes like nobody's business, but still floats as it should. No problem doing loops etc. Hope to get some vids up soon, as this is our first FPV, we are making it because he is legally blind. He can see about 6ft from him depending upon lighting conditions...but he can see a TV just fine if he sits up close. He should be able to fly it if all goes well.
I do have a question though...it just snowed 15 inches or so here. I was thinking we could take it out for a few more test flights with added weight to simulate the camera etc. If I cover the two holes up front, I should be able to land in the snow without any problems right? (on top of it I hope )
Motorbikebruno is online now Find More Posts by Motorbikebruno
Old Dec 10, 2012, 06:20 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Covering the vents is good, should be cool enough anyway. Make sure to shake out any snow, including around the wing servos. And get video!
victapilot is offline Find More Posts by victapilot
Old Dec 10, 2012, 08:59 PM
js32257 is offline
Find More Posts by js32257
js32257's Avatar
Joined Dec 2011
I cut about 7" off each wing tip (just before it starts to curve upward) and it's still very floaty but now I can do aileron rolls...maybe 2 in one second.
js32257 is offline Find More Posts by js32257
Old Dec 10, 2012, 09:35 PM
eckace1 is online now
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Looks like you hooked it up to a wattmeter so could you give us the other specs like watts and voltage?
eckace1 is online now Find More Posts by eckace1
Old Dec 11, 2012, 12:13 AM
paul2pilot's Avatar
Joined Jan 2011
I am using a stock 3S battery, so by definition, it's 12.6 volts when fully charged. Peak wattage will vary depending on the C-rating of your battery. In my case, the voltage drops down to about 10.5 volts when running wide open, so that's about 290 watts (28 amps times 10.5 volts). The wattage drops quickly at wide open throttle. I woudl say it was down to about 230 watts within 30 to 40 seconds. Again, these figures will vary depending on the C-rating of the battery. If you use a 40C battery, your voltage won't drop nearly as much and you will end up cranking more watts (possibly enough to overheat? Not sure.).
Old Dec 11, 2012, 01:23 AM
hendrnk is offline
Joined Apr 2012
That engine should easily pull 40-50amps with the right battery / propeller combination.
Old Dec 11, 2012, 10:18 AM
Crash Expert
Joined Oct 2012
Will do. Hope to sneak it out soon, the wind has been up as the storm passed through.
