Old Nov 23, 2012, 09:56 PM
js32257 is offline
Find More Posts by js32257
js32257's Avatar
Joined Dec 2011
Originally Posted by sss34 View Post
hi.
I just got my order form hk with the collect adapter (http://www.hobbyking.com/hobbyking/s...dProduct=16579)
But this does not look right.
Can you please send me a link with an adapter from hobbyking.
I received the prop adapter from the link I gave you earlier that you said looks like the one you ordered.
http://www.hobbyking.com/hobbyking/s...dProduct=19593
It's the right size and works fine.
js32257 is offline Find More Posts by js32257
Old Nov 24, 2012, 09:23 AM
sss34 is offline
Find More Posts by sss34
Joined Jun 2012
I got a different adapter its coming off ebay, hope it is not going to be huge.
I got a 3mm x 25cm carbon rod and I would like to put it into the elevator.
I dont know how to do it apart from cut out a hole and stick it in.
Please help
sss34 is offline Find More Posts by sss34
Old Nov 24, 2012, 10:48 AM
js32257 is offline
js32257's Avatar
Joined Dec 2011
Please help
Just what you said...
Make a straight notch across the horizontal stabilizer (not the elevator) that is deep enough to accept the rod and glue it in. Make sure the notch is deep enough that rod doesn't stick out any higher than the rest of the stabilizer. Cover it w/ tape. Done.
Old Nov 24, 2012, 03:26 PM
rcfly4m3 is offline
Find More Posts by rcfly4m3
Australia, NSW, Sydney
Joined Mar 2012
Hey All, Ive had my AXN for some time now and the foam is not coming back to its original shape after a few hard landing on the nose. Is it worth fixing or should I just buy a new one?
The reason I ask is that I have just blown my esc and now my motor (original) has finally gone so not sure if to fix or just replace
Thanks heaps
rcfly4m3 is offline Find More Posts by rcfly4m3
Old Nov 24, 2012, 03:53 PM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Thanks heaps
It really depends how bad. But I put hot water on the nose many times to put it back in shape after many nose challenged landings.
hendrnk is online now Find More Posts by hendrnk
Old Nov 24, 2012, 05:59 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by victapilot View Post
Try crashing harder!!
The new HXT900's have carbon gears, and are back in stock!
I guess they were having problems with those (darn it). HK switched back to the nylon gears. Read the following:
http://www.hobbyking.com/hobbyking/s...cro_Servo.html
AJ
ajbaker is offline Find More Posts by ajbaker
Old Nov 24, 2012, 06:42 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
AJ
Yes, I saw that. And they say because of customer demand? I have 2 and two more on the way. Too bad, I like the carbon gears, and they are not as noisy as metal gears. The 929s will get more of my $$$.
victapilot is online now Find More Posts by victapilot
Old Nov 24, 2012, 06:59 PM
rcfly4m3 is offline
Joined Mar 2012
Did you use boiling water or just hot? I got boiling and mixed with cold so it was reasonably hot but not boiling.
It's not bad, but bad enough I think to affect the wind flow
Old Nov 24, 2012, 09:57 PM
Joined Apr 2012
It supposed to be just below boiling.
http://www.youtube.com/watch?feature...X_Xowv4#t=379s
Old Nov 25, 2012, 12:46 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Servo preference.
Same here. I use both the HK and the Corona - whichever they have in stock. I just got a batch (20) of the Corona servos. All the specs and the price appear to be the same. I have not run any bence tests on either one though. Do you have any preference? If so, why.
BTW-Due to somewhat less than exceptional flying skills, I have become an expert at changing out the gears in the HXT900's.
AJ
Old Nov 25, 2012, 07:48 AM
victapilot's Avatar
Joined Feb 2009
AJ
I like the digital version for elevator, it gives better holding power at all positions. I use them in a Yak for both elevator and rudder. They make a humming sound, but that's cool
I believe only the top 2 gears are metal, but I never broke any. Agree that extra gear sets are a good investment for the HXT900, but I never needed the bottom two gears.
Old Nov 27, 2012, 08:02 PM
Beanz is offline
Find More Posts by Beanz
Joined Sep 2012
Reading here about problems launching the AXN, I was quite surprised when I joined my local club, to see club members launching from the grass. Admittedly the grass was quite well mowed but even grass that's maybe 60mm high didn't seem to cause any problems.
It's just a case of placing it on a fairly flat area, pointing into wind and opening the taps. I used about three quarters throttle and after a few seconds, the plane was moving fast enough that I gave a bit of 'up' elevator and she was airborne.
Why I'd never done this before, I don't know but it's a lot more fun.
It also helps to have some reinforcing tape on the underside of the fuse from the nose to under the wings to allow the AXN to slide along smoothly.
Of course, many of you guys may already fly this way but either way it's a good tip for those that don't yet.
Beanz is offline Find More Posts by Beanz
Old Nov 27, 2012, 08:24 PM
victapilot's Avatar
Joined Feb 2009
See at the end of this video. Wagging the tail helps break free from the grass. I stopped doing this after ground looping tore off a wing tip.
http://www.rcgroups.com/forums/showp...postcount=2305
Old Nov 28, 2012, 09:22 PM
Beanz is offline
Joined Sep 2012
Thanks victapilot. I tend to have a bit less welly on my launches for the very reason you quote- it's quite easy to have the thing spin around on itself.
Having said that, it really is so much fun launching this way that I now fly most of my planes this way (well those that have props out of the way anyway). Nice video.
Old Nov 29, 2012, 11:49 AM
SOOFLY is offline
Find More Posts by SOOFLY
United States, SC, Greer
Joined Nov 2012
Victapilot - I see you live in SC. I currently live in Greer, SC and I am formerly a member of the WCRC flight club. I was watching that video you posted and I was thinking to my self man that looks just like the WCRC flight field. Is that wear you were flying in that video?
SOOFLY is offline Find More Posts by SOOFLY
