Old Nov 07, 2012, 04:00 PM
sss34 is offline
Find More Posts by sss34
Joined Jun 2012
No, I still love my brand new AXN. Even that I have not flown it but its the same as my first plane at which I'm a pro at flying.
sss34 is offline Find More Posts by sss34
Old Nov 07, 2012, 04:09 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
If its setup correctly, it floats like a baby and screams like a whor_.
hendrnk is offline Find More Posts by hendrnk
Old Nov 08, 2012, 08:23 AM
dunc1055 is offline
Find More Posts by dunc1055
Joined Oct 2012
prop saver
As I'm using a collet type prop adaptor can I unscrew the two little screws on the property saver as they are not needed.
Also any advise on balancing the prop if even needed. Thanks
dunc1055 is offline Find More Posts by dunc1055
Old Nov 08, 2012, 10:24 AM
hendrnk is offline
Joined Apr 2012
If you can get the prop saver off then take it off. I couldn't.
For balancing a prop I use a Great Planes prop balance.
Old Nov 08, 2012, 10:37 AM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
I don't have that motor, but I think someone said those two screws also serve to hold the bell of the motor in place. Might be possible to replace them with set screws.
victapilot is offline Find More Posts by victapilot
Old Nov 08, 2012, 10:55 AM
Cathay Stray is offline
Find More Posts by Cathay Stray
Flying Zayin
Cathay Stray's Avatar
China, Guangdong, Guangzhou
Joined May 2012
For fun and education purposes, maybe. Otherwise absolutely no need to even think about it. This bird uses small lightweight props (by the way, I began with throwing out the stock 5" and replacing it with 6*5, the change was dramatic); balancing such small props is of course sort of praiseworthy perfectionism but practically hardly ever needed.
My AXN one Saturday managed to both swim in a pond and hang on a tree, then continued ineventfully flying next day morning till dusk and it wasn't until next weekend that I noticed one side of the prop was about 3-4 mm shorter than another (tree, yesssss!) - I replaced the prop, checked the motor and forgot about it till you reminded me!
This is NOT to say that we may be so stupidly negligent as I was. But if we accidentally are, the AXN will very probably keep on forgiving us for time long enough to notice the problem.
Modern plastic props, even those proudly made in China, are pretty symmetrical and unless you're flying a 3d competition on a 2.5 m airplane it's probably not worth bothering.
Many might disagree but I haven't heard of a single trouble with planes of AXN size caused by prop dis-balance.
Cathay Stray is offline Find More Posts by Cathay Stray
Old Nov 08, 2012, 11:15 AM
ColSonders is offline
Find More Posts by ColSonders
United Kingdom, England, Consett
Joined Feb 2012
I thought the real reason to balance a prop on this plane is to eliminate vibration, thereby reducing the noise produced.....so basically it's just a procedure to reduce the noise of the prop in the air.
I guess reducing vibrations would also be beneficial to FPV flying too.
ColSonders is offline Find More Posts by ColSonders
Old Nov 08, 2012, 11:25 AM
victapilot's Avatar
Joined Feb 2009
Yes, and I've got 1000rpm more from a balanced prop. But it depends on how bad it is to begin with. I got some 5x5's from R2 that were quite out of balance, but fixed with a little tape.
To fine tune I use a vibrometer app on my android. You can measure the vibration - always good to have data
Old Nov 08, 2012, 10:12 PM
Beanz is offline
Find More Posts by Beanz
Joined Sep 2012
sss34- I just read your old post where you say that it's often too windy to fly in England.
Although I now live in Oz, I spent my first 25 years in England and flew r/c gliders for about 10 of those years. I'd describe my skill level for the first couple of years (and now) as average.
I flew in all manner of winds, mostly slope soaring. I even flew in winds where it was hard to stand up! This was purely because I was quite literally ADDICTED to sloping rather than for any altruistic reasons. Yes I had a few crashes in the high winds but I also had (less severe) crashes in gentle winds.
What I found, was by stretching my abilities by NOT allowing the wind strength to limit my flying, I learnt a whole lot faster and my skill level rose until I could cope with just about anything and everything that could happen whilst flying (and this was before we had electric motors that could pull the plane out of a tight spot).
Unfortunately, once I emigrated to New Zealand, I was too busy trying to hold onto a new more demanding job so my r/c flying went out the window.
I never returned to the sport properly for 20 years and by then, my skill level had fallen back by a lot!
But I've kept going and once again things are improving.
So what I am trying to say is, don't let yourself be put off when it's blowing a bit. Even now I fly the AXN on days when other r/c mates are packing their gear up and going home. Whilst I DON'T recommend pushing yourself too hard, I would say SLOWLY push that envelope because your skill level and confidence will grow exponentially.
Oh and, enjoy England for me eh? Damn I miss that country!
Beanz is offline Find More Posts by Beanz
Old Nov 09, 2012, 12:00 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Originally Posted by Beanz View Post
<snip>
Most people do miss it ... it's too windy, rainy and winging for most
(being Australian I am obligated to hang it on Pommies )
I did live in England for 2 years ...
I remember visiting the Isle of Skye and reading a book in the Tourist Shop. On the blurb of the book it said; "You haven't seen Skye until you have seen it's magnificence in the wind and rain". I saw Skye!!
Seriously - England (U.K.) is a beautiful place (so long as you are not poor living in a dead industrial town). And I can understand why people miss it. I would dearly like to go back some day.
mutha is offline Find More Posts by mutha
Old Nov 09, 2012, 04:07 AM
skellator is online now
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
fpv maiden tomorrow (hopefully) need to configure the storm before actually maiden
skellator is online now Find More Posts by skellator
Old Nov 12, 2012, 02:38 AM
Firepower is online now
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
How did it go? Did you like the camera position? I like to see a lot of ground to see where I am going. My next camera will be on the nose but a small one.
Or is the FPV gear taking a while to configure.
Firepower is online now Find More Posts by Firepower
Old Nov 12, 2012, 04:05 AM
9W2DLR
Joined Nov 2011
when awesome, but my axn fly really bad these days hard to get it to fly straight, also have some issues with the plane always want to turn left with out stick input with or without throttle,
still trying to find the cog of the axn keep wanting to pitch up and dive cant really glide that well anymore, i might have a serious cae of tail warp or maybe my horizontal stabilizer is warped
waiting for my nylon hinge to arrive the epo hinge cant be trusted anymore
camera position moved to the nose as you said see as much ground as possible but maybe getting a pan tilt later on , I'll post a another picture with a new setup
Old Nov 12, 2012, 04:47 AM
9W2DLR
Joined Nov 2011
added landing gear, flitetest style
Description:
Description:
Description:
vtx moved to the back
Description:
new camera placement
Description:
Old Nov 12, 2012, 06:17 AM
Firepower
Firepower's Avatar
Joined Mar 2010
I have plastic hinges but have never used them on foam planes. Guess they work but I just use firer glass tape or Blenderm tape if I want a more invisible job. Guess I do not like spending time on hinges and just use tape but I use spray contact cement first so that it sticks good.
I see you have already used some tape on the ailerons but I usually do it the full length of the aileron and top and bottom.
http://products3.3m.com/catalog/au/e...er/output_html
The turning left bit could be a lot of things but I usually use opposite trim on the ailerons to fix this temporarily until I find the fault which you probably did. Can even be a warp in a wing. Also if a wheel is turned a bit I guess the extra drag on one side could help turn the plane.
With the plane pitching up and down that can be the tail plane at the wrong angle but also can be many other things.
With all the problems of my Floater falling out of the sky I now always make the c of g at the front of the wing spar cover and I'll have no problems.
A mate did a good job of a pan camera. He cut a hole in the middle of the canopy for a servo and glued it in. Most of the servo was under the canopy from memory. Then mounted/glued the camera on the servo arm.
Good to see your pictures as always get ideas from different installations.
I guess there was a reason to move the video TX.
Sounds like you'll get it going perfectly soon but a great start.
