You will have to break the AXN to break themEarly stuff might help check the list here http://www.rcgroups.com/forums/showp...postcount=6040 |
New Zealand, Auckland
Joined Dec 2008
I still always fly my Atom, still so much fun :-) Both the bixler & AXN have some dodgy OEM servo's & esc's (not all, some) Get the kit without servo's or esc & buy your own. Bixler will be better for fpv, AXN probhably better made & stronger, faster. Best of all could be the Bixler2 ???, although not as fast. looksee here axn build vids , explains why you dont want the OEM servo or esc http://www.youtube.com/playlist?list...3&feature=plcp bixler vs axn, this guy has both.
In your original post you said you chopped the wing tips on your previous AXNs. I've seen videos of AXNs with chopped tips to 3 rolls in about a second. How much faster of a roll rate are you looking for or did you mean you want to keep the tips on and still have it roll faster? |
I put a tiny camera on the nose plus a video transmitter (also on the nose), and for that had to sacrifice 900 mAh (switching from 2200 mAh to 1300 battery), and it is all about this. Some do indeed fly with 'real' cameras (25x25 or even 32x32 mm) and even pan/tilts but.... a pony probably can drag a 40 ft container, but there are better vehicles to do it. Still, it is an ideal little plane to learn the basics of FPV flying around the airfield and getting used to the different way the world looks on a monitor screen. But mid range... One more thing, both Bixlers have perhaps the same room inside but a lot smaller opening to manage what is inside. My friend who flies a Bix uses a dental mirror to check the inside, and it's no joke. Flying off the same field with that friend I can see that probably thanks to greater wing area a Bix soars longer on zero throttle than the AXN and altogether is probably a better glider. I was busy today extending the ailerons of my AXN with thin but rigid plastic sheet, might be a mod you could consider from the beginning. |
Joined Oct 2012
Charging lipos
Hi Guys
Im about to charge my first ever lipo battery and just wanted some advice the charger im using is an accucel 6 and my battery is a Turnigy 2200mAh 3S 20C. I have a lipo safety bag as well as i have heard some horror stories ![]() I am wondering is it always best to charge using the balance option as opposed to just normal charge? and any other points you think i need to know? Thanks |
Joined Apr 2012
I have never charged a battery in a Lipo bag and have had no issues after charging a thousand or so batteries. Charge at 1C which in this case is 2.2 amps. If at the field you can push the charge rate up to 4.4 amps if needed. (check the battery specs, on the max C charging rate) normally for plane batteries they are minimum if 2C. (I haven't seen any lower anyway). Obviously make sure the charge voltage is for 3S (11.1v) battery otherwise the charger will error out. |
Joined Jun 2012
I use "CHARGE" to charge them. I am getting my new batteries use to being on load so this is what I do. Charge for 2hrs at 0.1a then. Charge for 2hrs at 0.2a Then 2hrs at 3 and so on until the voltage comes up to 4.15. Then using a brushless motor run the motor on idle for 5 min then a rest for the batts then another 5 min and so on until the voltage drops to 4v per cell. Now I charge my batts at 0.4a normaly if I am not in a rush. So now begin pushing your batts more and more use them at higher throttle and charge them at higher a. Bit by bit they will soon be ready to go. Yes I am being very anal about this but this is what I do to make them last longer. What I have seen with the batts that if you just push them hard out of the box the cells will be unbalanced but if you do what I do the cells should be perfect and in the AXN the batts should be cool or tiny bit warm. |
Joined Apr 2012
Also the cells should be balanced during your recharge procedure at some stage.I use 7 batteries in 2 hours flying with 3 different planes. It would take me a week to recharge them for the next days flying. I start recharging them while flying on another battery or plane so I can get more flights out of them during the limited time I have flying. |
