I agree that covering with low temp Econokote works well, looks good forever. I've done it on another plane. Only concern is keep temperature at just enough to get good adhesion. Too much heat raises the surface "corn effect" |
I just had a quick look at my clouds fly (which hasn't been crashed/repaired...yet...) and there is a very slight offset to the right as you have previously been advised. I would simply put a thin washer under each of the two left screws and give it a test. Good luck and keep us all informed. |
AJ |
It might not be only torque. The propwash goes back like a corkscrew, and the rudder is close to the prop. I like suggestion from AUS, put it straight, fine tune if needed with washers. I would check rudder also. Another thought: I use standard props, if I had that problem, I would try a pusher prop and reverse the rotation. Might learn something.. |
Easy to make from a water bottle
http://static.rcgroups.net/forums/at...g?d=1286846530 Go to thread tools and view attachments there are few examples. here is mine, |
I know you are probably after one in a hurry, but our friends at HobbyKing sell them for $1.71.
http://www.hobbyking.com/hobbyking/s...dProduct=18197 Or you could use a buddy code and pick one up for $1.09. http://rcsearch.info/hobbyking/buddy...=0&y=0#catalog At that price order a couple. |
This is the photo I have used as an example for years and no one has said it is wrong. If it is I would like to know. It is for a normal prop and not a pusher prop.
But on a Floater putting it centre works fine and if you are flying to the side you have the airframe bent some way etc. I am just going by experiments I did with a small Fox but on the Floater you may have to turn the motor a fair bit to get a reaction. I thought it was right after post 10554. Checking google on this matter is a bit hard but this one is interesting for checking the up/down angle of the motor.
Not sure why everyone is going to such efforts to alter the existing model. Just fly it as it is and have fun. Once you have fine tuned the control surfaces the plane flies like a dream and that is despite all efforts to the contrary
Just crashed mine into some power lines but no real damage and back up in the air again. |
