Old Jun 13, 2012, 03:34 PM
hate2crash is online now
Find More Posts by hate2crash
Joined May 2010
Originally Posted by victapilot View Post
Thanks! It previously ran with a 6x6 3blade and bigger ESC. I currently have a blue HK 40a ESC. The motor had more power when brand new too.
The plane is heavier because of this big motor and collet, but still floats. I reinforced aileron and elevator hinge lines with hot glue to avoid flutter, so they are a bit stiffer than stock.
I angled the motor so the shaft points at the top of the rudder. This is to give almost hands off trim at wot. It helps with prop clearance, an 8 inch prop fits with a few mm to spare.
I have several inrunner and a 1500kv outrunner from my boats which i am sure would work well with similiar setup as yours...If you look at bixler the motor is angled up similiar to your setup...i have a micro-jet 2200kv on its way which should give me the performance i am looking for..i have 5x5,6x4 and 6x5.5 props coming also and will see which combo works best for me...thanks for sharing..
hate2crash is online now Find More Posts by hate2crash
Old Jun 13, 2012, 04:55 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
That motor comes highly recommended! Let us know how you like it.
@JLT I have no offset or tilt, seems to track straight.
victapilot is offline Find More Posts by victapilot
Old Jun 13, 2012, 05:46 PM
Joined May 2010
I know it does..i used to have a Hawksky whch on stock setup goes pretty good,but a lot of guys installed a better prop and this micro-jet v3 and it turned their hawk sky into a rocket...Since the axn is 10% smaller then the hawk sky and imo a bit more durable...I feel it will be even a better performer then with stock setup..i can't wait to get my parts and see
Old Jun 14, 2012, 12:46 PM
Jeandredubois is offline
Find More Posts by Jeandredubois
South Africa, FS, Sasolburg
Joined Apr 2011
I want to try a 6x4 3-blade prop.
Will the stock motor handle the prop ie amps/thrust?
Jeandredubois is offline Find More Posts by Jeandredubois
Old Jun 14, 2012, 06:25 PM
James DAgostino is offline
Find More Posts by James DAgostino
Joined Jun 2012
If I use a 2200 battery for better CG should I remove the washer in the nose?
James DAgostino is offline Find More Posts by James DAgostino
Old Jun 14, 2012, 07:31 PM
dcame002 is offline
Find More Posts by dcame002
Lipo Burner
dcame002's Avatar
United States, FL, Sunrise
Joined Mar 2012
have u guys noticed the zephyr v70 from hk looks like a clouds fly with top cut off + belt cp canopy + edf + v tail?
dcame002 is offline Find More Posts by dcame002
Old Jun 14, 2012, 07:32 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
thats +- 33% more thrust. I don't think it will
Old Jun 14, 2012, 08:02 PM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Actually No. I think it looks like a lot of other V tail gliders; but not a CF.
mutha is offline Find More Posts by mutha
Old Jun 14, 2012, 09:43 PM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
are you mistaken bixler with axn? ee dont have washer in the nose only bixler have that
skellator is offline Find More Posts by skellator
Old Jun 14, 2012, 11:10 PM
Joined May 2010
I use sky 1800mah packs with some weights(about same as 4-5 quarters in weight) i taped on outside underside of nose...i would say if i took a 2200 pack and pushed it full forward there would be no need for any extra weights,,,but that's just my opinion ,i could be wrong...
Old Jun 14, 2012, 11:14 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
ya gotta be kiddin me
Not even remotely close.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 15, 2012, 01:07 AM
JLT_GTI is online now
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Originally Posted by JLT_GTI View Post
Sorry to repost by judging from this pic:
Should i tilt the motor to the left or towards the right of the photo?
Also now i found that the motor mount was loose.. maybe it could also move a bit under the torque
Sorry to repost this again but i need to glue this and i want to be sure..
JLT_GTI is online now Find More Posts by JLT_GTI
Old Jun 15, 2012, 03:29 AM
dhonwyn is offline
Find More Posts by dhonwyn
Joined Nov 2011
Originally Posted by hate2crash View Post
Is this M.A. 7x4 a normal prop or reverse rotation?...Also when you are looking at motor from tail side is the rotation clockwise...i want to make sure when i mount a new motor and different prop it is spinning in coorect direction ...thanks
hello,
Sorry i made a wrong description its Master Airscrew propeller 6.5x4
Here is the link http://www.hobbyking.com/hobbyking/s...idProduct=8042. as i said i cut the pro about half an inc
I use TOWER PRO 40amp ESC and it gives me a lot of power to support.
dhonwyn is offline Find More Posts by dhonwyn
Old Jun 15, 2012, 04:37 AM
Hman :) is offline
Find More Posts by Hman :)
Joined Nov 2009
Cloads fly sticker removal Question...Anyone use a hair dryer to remove these stickers or does the foam get messed up? I ask because my next cloads fly i order i want to put a custom paint job on...can anyone recomend good brand or type of spray paint as i never painted a foam plane before...thanks
I just pulled mine off...no heat required.
Hman :) is offline Find More Posts by Hman :)
Old Jun 15, 2012, 05:59 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Towards the word WAY in that photo but only 2 degrees which is just about nothing.
It is this way in the attached photo.
Firepower is offline Find More Posts by Firepower
