As mentioned by JLT_GTI the rear stabilizer/tailplane, have you looked from underneath and checked if the rear of the tailplane where it meets the body is sitting down fully or sticking up a bit.
It is a bit hard to check if there is a lot of glue in that area. Do not ask me how I know about this. No more CA for me gluing things like this on. |
San Diego
Joined Dec 2003
Got it. I have plenty of tape.
. Quote:
Barry |
Good stuff eleven flights and no crashes.
From memory your trouble is it turns right on launch. If your motor looks straight I would not change it. These planes are flying perfectly with no angle on the motor but for those who do change it, the MOTOR ANGLE IS 2 DEGREES which is not much. So have you trimmed it (when flying high so as you do not crash it) so it flies perfectly straight with the motor on. We if it does that it should fly straight when you throw it. I guess you have about half throttle before you throw it. All throws MUST be straight into the wind. Do not smash it but I can throw mine all day without turning the motor on and land it perfectly. Have you even tried throwing it without the motor on and it flies PERFECTLY straight. When throwing hard MAKE SURE you throw at the horizon NOT ABOVE and if enough air speed, depending on the wind, you can get it to go quite high. WHEN DOING THIS: 1. Do not get the nose too high and stall it. 2. I keep a finger on the elevator with a very small amount of up and adjust it after the throw. This is to make sure you do not nose dive. Remember if you trimmed it for the motor on it will need a bit of up to keep it level with the motor off. If not confident with this do not do it. Instead of changing the motor you may have a wing warp and you may have to have quite a bit of up on one aileron to fly straight. Do not ask me how I know. Doing the above throw test and adjusting the aileron until it flies straight will check this. But as I said I guess you have trimmed the elevator and ailerons with the motor on so as to fly straight. This is usually done in the first flight of a plane. Quote:
| hate2crash | |
A moderator felt this post violated the following rule: Offensive content (Profanity).
It is temporarily hidden while hate2crash
edits it.
Joined Oct 2010
My thoughts:
1.The motor is crap.... 2.Wrong timing(low possibilities because it was working at first) 3.you putted the prop in wrong direction and that caused vibrations and pushed motors to the limit and it got burned.. Can you plz post specs of the motor? (kv, watts,etc) Good luck mate but i think that this motor has already gone to waste:/ P.S.If i where you i would buy the original motor of the axn as it is epic and a turnigy plush 25-30 amps to keep my head out of trouble! |
Well .. mystery solved
Today there was no wind at all in the slope.. so time to test the repaired CloudsFly and again it veers off to the right ... but then after trimming... i turned off the motor and.. it began veering off to the left It veers off to the right quite a lot under power only.. Seems like Firepower was right.. the motor is causing the roll... it clearly happent because the incident of the long range loss but its odd since i cant see the motor pod any warped or changed.. now... wich way i must tilt the motor to correct this? orient the propeller to the left ? (if lookin from behind) |
Shoot the Trouble OR is that trouble shoot?
1. The new motor that you put on the plane had the center of the output shaft set too long meaning - when you mounted the motor, the center shaft was rubbing up against the plastic mount on the plane (you will see the mark on the plastic mount) 2. Prop is on backwards. 3. You prop is terribly out of balance. (unlikely, but still a possibility). What is good and what is bad - Your original ESC and Datrum ESC are probably shot (more testing needed after sequence below). Your original motor and the second motor you used are probably trash (more testing needed after sequence below). Your 50A ESC is just fine. Suggestion: You can do all of the above logic in reverse by doing the following. Mount the whichever motor it was that was the coolest during testing. (I lost track). Make certain that it rotates VERY freely and is not rubbing the plastic. Use you 50A ESC. Now, go have a nice time flying and when you get back you will be very happy and your head will be a lot clearer and you can work all the logic above to figure out for sure what is good and what is bad from above. Keep us posted. Your situation is interesting. AJ |
AJ |
![]() I have to tilt it to the right? |
