Old May 24, 2012, 06:32 PM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Originally Posted by coaldust View Post
yeah its more responsive, but its lost its relaxing flight style, wish i did not bother now
Grab an airframe only from HK and you'll have a second set of wings.
mutha is offline Find More Posts by mutha
Old May 24, 2012, 09:00 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Servos Plastic vs metal
Originally Posted by phlyers View Post
Are any of you guys using metal gear servos? If so which ones?
Yes. I use THESE. I just got tired of replacing the gears in the HXT900's (even though a whole set of gears is <$1). It is worthy of note too that I agree with Mutha even with the few negatives about them. I have used over 100 of them in the last 2 years or so.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 25, 2012, 01:47 AM
wizzard363 is offline
Find More Posts by wizzard363
flying or crashing into air?
wizzard363's Avatar
Australia, VIC, Langwarrin
Joined Feb 2011
I am using MG90 servos for the ailerons . I stipped the original HXT900's and had the MG 90's in my heli spares box. I know from using them in my heli that they can survive a good crash.
When the elevator and rudder servos die I will use the same servos that AJ recomended (got 4 in my spares box)
I have them fitted to a Zagnutz wing I built and they work well.
When they are back in stock be quick to grab some as they sell out fast
wizzard363 is offline Find More Posts by wizzard363
Old May 25, 2012, 01:54 PM
noise is offline
Find More Posts by noise
Joined Jun 2011
I replaced the stock prop-saver attachment with a collet which of course moves the prop back a bit more than 1/2" and adds some weight behind the cg.
The collet is certainly quieter but I'm fighting a bit getting it re-trimmed. I had it where I was pretty happy with the balance and trim using an 1800 lipo.
Even though it seems logically I should have shifted the the cg back it's acting more nose heavy than anything, always pitching up after a dive. It also doesn't seem to climb as well.
Any suggestions?
noise is offline Find More Posts by noise
Old May 25, 2012, 09:36 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Any suggestions?
Add some down trim.
AJ
Old May 25, 2012, 09:49 PM
noise is offline
Joined Jun 2011
Originally Posted by ajbaker View Post
Add some down trim.
AJ
Well it was freaking me out a bit that it didn't seem to climb as well under WOT, so down trim seemed like the wrong thing to do. But I burned three packs today and got used to it, also took a bit of weight off the tail.
I fly over a small valley next to 10 acres of woods so I get some funky wind shadows and turbulence sometimes which I think was confusing me a bit as well.
Old May 25, 2012, 10:02 PM
JLT_GTI is online now
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
moving the propeller back half inch and adding a few grams collet adapter shouldnt affect noticibly the CG .... i added a heavier motor with collet adaptor and i barelly notice it (my batt its still in the same place and seems to ballance nice)
JLT_GTI is online now Find More Posts by JLT_GTI
Old May 25, 2012, 11:36 PM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
I did my first Loop today lol, on WOT the 2200kv turnigy motor like going to rip the wing off the plane when doing loop , will post the video later need some converting and editing
AXN Cloud Fly Puncak Jalil 26/05/2012 (6 min 46 sec)
skellator is offline Find More Posts by skellator
Old May 27, 2012, 01:01 PM
BrightCap232 is offline
Find More Posts by BrightCap232
I've got gas
BrightCap232's Avatar
United States, PA, Quakertown
Joined Aug 2011
Flaps
Do you guys add flaps to help your launches? Would you want them on the ailerons or on the elevator?
BrightCap232 is offline Find More Posts by BrightCap232
Old May 27, 2012, 02:25 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
OOOOKKKKKK. Flaps are inboard on the wings. Ailerons are outboard. There is no such thing as a flaps on the elevator. This plane has no flaps.
The plane will launch just fine if control surfaces are set level.
Prof100 is offline Find More Posts by Prof100
Old May 27, 2012, 02:31 PM
JLT_GTI's Avatar
Joined Jun 2010
Old May 27, 2012, 02:36 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Don't confuse the new guy with flaperons.
Old May 27, 2012, 04:14 PM
coaldust is offline
Find More Posts by coaldust
Joined Apr 2012
managed to get my wing tips back on with rods and fibre tape, back to gliding great , if your thinking about removing the tips dont, rolls better thats about it, you gotta be on the power all the time and wind blows it about more.
just trashes the axn, leave it stock
coaldust is offline Find More Posts by coaldust
Old May 27, 2012, 04:32 PM
JLT_GTI's Avatar
Joined Jun 2010
Well the function is the same and the only way to get flaps in the CF (unless you make longer ailerons and split them in 2 using 4 servos)
Old May 27, 2012, 04:36 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
No, flaps are flaps and ailerons are ailerons. Flaperons is a crude way of increasing lift, but also promotes tipstalling. Spoilerons would be a safer way to decrease lift. Gliders use them all the time. Even laser hot landing EDF jets will program in some spoilerons (up ailerons) to decrease lift.
