Old Apr 29, 2012, 03:43 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by dhonwyn View Post
YOOOOHOOOO...
My AXN floater is back in action with fpv setup...
It looked like you have the elevator control backwards??
AJ
ajbaker is offline Find More Posts by ajbaker
Old Apr 29, 2012, 09:12 AM
dhonwyn is offline
Find More Posts by dhonwyn
Joined Nov 2011
AJ
Yes i forgot to reverse it hahaha
dhonwyn is offline Find More Posts by dhonwyn
Old Apr 29, 2012, 10:22 AM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Replacing the Rudder Servo in the AXN
SMEs: what's the best way to replace the rudder servo in the AXN Clouds Fly?
Mine finally went out...
If this question has been already been answered, please kindly provide the link to it.
LittleG is offline Find More Posts by LittleG
Old Apr 29, 2012, 10:27 AM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
If its like mine, its stuck against the side with double sided servo tape. I used a hot knife to get it out, heat the knife in boiling water. The water helped lubricate the blade, the heat softens the tape.
victapilot is offline Find More Posts by victapilot
Old Apr 29, 2012, 01:14 PM
LittleG is offline
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Mine is hot glued in.
Old Apr 29, 2012, 01:48 PM
eaglescry24 is offline
Find More Posts by eaglescry24
Flying the Spyder
eaglescry24's Avatar
United States, PA, Parkesburg
Joined Mar 2008
Use a hobby knife and stay close to the servo gently prying away during incision. Using the servo to scrape against to keep from cutting into the aircraft.
It's ok if u damage the area a little just use hot glue to replace with the new servo. A little surface loss or pits or small craters are insignificant due to plenty of material to attach to. A change of angle or whatever won't cause rigging issues. Have fun
eaglescry24 is offline Find More Posts by eaglescry24
Old Apr 29, 2012, 02:10 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
You already have lots of good suggestions. I will just add one more. I just took a medium size screwdriver (blade type) and pried the servo out (I did both the elevator and rudder servos). No damage was done whatsoever. Mine were double-sided taped, too.
AJ
Old Apr 29, 2012, 06:07 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Hi guys,
I saw someone mention gyros a few pages back...
Below is a video I posted on the OpenAero thread of my AXN Floater with a development build of OpenAero V1.12.
As skellator kindly mentioned, it uses a KK board with 3 MEMS gyros and an accelerometer for autolevel.
Have a look at the OpenAero thread. Quite a few people successfully flying various aircraft with it now. Hopefully it will be my turn soon :P
There are pictures of the setup at the end of the video.
OpenAero in my AXN Floater (1 min 25 sec)
HappySundays is offline Find More Posts by HappySundays
Old Apr 29, 2012, 08:15 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Are you guys using flaperons? I tried using flaps but man.. It just wanted to glide even more. I put the flaps in the "up" position so they are more air brakes than anything and it seems to get me on the ground much faster/smoother. Either way.. This plane is just great
Oh, Happy... Thats awesome! Nice work
3d astronaut is offline Find More Posts by 3d astronaut
Old Apr 29, 2012, 08:54 PM
geewow is offline
Find More Posts by geewow
Joined Jan 2012
Nice work Happy!
Looking forward to hearing how she flies!
geewow is offline Find More Posts by geewow
Old Apr 29, 2012, 11:49 PM
englanito is offline
Find More Posts by englanito
addicted to the sound ehhhhhhh
Joined Dec 2011
Use air duster and turn the can up side down spray the liquid aerosol on the glue. It will shrink the glue and make it bristle. The you should be able to crack the servo and Glue out. Try to not freeze burn your self in the process.
englanito is offline Find More Posts by englanito
Old Apr 29, 2012, 11:59 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Off Topic - last question, I promise
Originally Posted by skellator View Post
no it not a typo i relly mean kk board for those multirotors, a guy named happysunday did a great job developing a firmware named openaero that use kk board
I have one hk kk board on my coroplast biplane, kk board have 3 gyro so instead of 1 axis we get 3 axis and cheaper too, check out his thread here
http://www.rcgroups.com/forums/showthread.php?t=1568554
If I wanted to play with one of those, is this the one I want?:
http://www.hobbyking.com/hobbycity/s...dProduct=19534
TIA
Sorry guys, this is the last post I will make on this OT.
AJ
Old Apr 30, 2012, 12:13 AM
Joined Feb 2011
TIA
AJ
Yes that one will work fine for basic stability. Not really off topic anymore as the OpenAero test plane is an AXN Floater Oops, I should point out that OpenAero is free and open source
Old Apr 30, 2012, 12:16 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
TIA
AJ
exactly there a few more option, but I think you can ask this on openaero thread , I'm getting my servo connector, converting those Y servo lead to a full aileron, wanted to test flaps on the AXN , hopefully I can get it flying tomorrow with the gyro, I wish i have extra mems modules for my AXN now my mems is occupied by my tricopter
skellator is offline Find More Posts by skellator
Old Apr 30, 2012, 02:45 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I see where it has been recommended that aileron Rudder mixing is recommended but I have not seen much on which way the rudder should turn when the ailerons turn. I guess it is obvious to most but even goggling provided a lot on mixing but not on which direction the surfaces should go.
My AXN has been doing the spiral of death lately and have only recently put in rudder mixing with the aileron. I have right aileron and right rudder mixed in together.
I just read where this is correct but it seems wrong to me.
I guess someone can clarify this?
Firepower is offline Find More Posts by Firepower
