Old Aug 12, 2009, 11:35 AM
Mark Perry is offline
Find More Posts by Mark Perry
Eazy does it !!!
Mark Perry's Avatar
Braintree, Essex, UK
Joined Mar 2005
AJ - Thanks for the concern about my cell phone and for the links to a more suitable one.
Theres no need to worry as the cell is my spare one that I use for "impulse" photography (carry it everywhere with me) and its not a problem if it gets damaged (only weighs 102 grams too).
I think I will order one of those that you linked to and just use my cell until it gets here. I have made a very secure and lightweight mounting for it and I dont think the AXN will have any trouble carrying it.
I will let you know how I get on (if the rain ever stops )
Mark.
Mark Perry is offline Find More Posts by Mark Perry
Old Aug 12, 2009, 04:30 PM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by RCengineer
You could remove the extensions and lay the connections in the wings (I didn't glue the under side of the wing covers) and let the fuselage hold the cover on. As the wings get installed, I pull the wire down for a clean install.
Hi , not 100% clear to me what you mean, do you have any pictures to clarify??
jaccies is offline Find More Posts by jaccies
Old Aug 12, 2009, 08:34 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by jaccies
AJ why does the pen cam not work for you ?
Resolution not good enough.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Aug 13, 2009, 12:02 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Night flying
Some videos from today. Enjoy....
AJ
The CF with night Lights:
Clouds Fly with night lights (8 min 58 sec)
The CF with night lights removed:
CF with lights removed (4 min 31 sec)
Old Aug 15, 2009, 08:57 AM
sandoz is offline
Find More Posts by sandoz
Joined Aug 2009
what are the best choices to buy at hobbycity for the cloud fly?
i mean transmitter/receiver/batteries/chargers in order to start flying after rceiving the package
sandoz is offline Find More Posts by sandoz
Old Aug 15, 2009, 11:20 AM
john339 is offline
Find More Posts by john339
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
Hobby King 2.4Ghz 4Ch Tx & Rx $29.99
ZIPPY Flightmax 2200mAh 3S1P 20C $16.99
IMAX B6 Charger/Discharger 1-6 Cells $38.79
12V 5A Power Supply $8.95
This is what my son ordered for his floater jet.
There are many ways to go but since you asked, this is what he flies with and seems to do very well.
john339 is offline Find More Posts by john339
Old Aug 16, 2009, 07:50 AM
sandoz is offline
Joined Aug 2009
whats the average range of the HK transmitter?
Old Aug 16, 2009, 08:34 AM
jsec1992 is offline
Find More Posts by jsec1992
Singapore
Joined Mar 2009
A guy at my regular flying field uses the 6ch version with his scale Cessna. I don't think range is a problem - making sure the plane is within sight and its orientation is clear should be more a concern.
jsec1992 is offline Find More Posts by jsec1992
Old Aug 16, 2009, 12:59 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Range of HK
As far as you can see and then some. I have 2-4ch and 1-6ch. I have walked a long ways (3/4 mi) on a couple range checks and I never got out of range. I figured that at that distance, I would not be able to see the orientation anyhow. So, any more distance would not mean anything to me.
AJ
Old Aug 16, 2009, 11:32 PM
john339 is offline
Clyde, Ca. USA
Clyde, Ca. USA
Joined May 2007
sandoz As has been mentioned, you will loose track of where the airplane is going before you get out of range. Good inexpensive 2.4gHz set.
Old Aug 17, 2009, 08:33 PM
calofr is offline
Find More Posts by calofr
Frank
calofr's Avatar
Saint-Jerome, Quebec, Canada
Joined Aug 2009
would the stock ESC be able to handle this http://hobbyking.com/hobbycity/store...idProduct=6504 bat?
wait, first off, it fits right?
calofr is offline Find More Posts by calofr
Old Aug 17, 2009, 08:42 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
If you can get it to fit and get the CG correct, it will work with the present ESC. Actually, the size of the 3S1P has no effect on the ESC. The ESC just sees 11.1v and assumes it is big enough to handle the load of the motor.
AJ
Old Aug 17, 2009, 09:30 PM
calofr is offline
Frank
calofr's Avatar
Joined Aug 2009
how long do you think the flight time is going to be (an estimate) with the battery stated above?(moderate to low throttle, stock model)
Frank
Old Aug 17, 2009, 10:24 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Frank
That is a tough one. I can only venture a wild guess. That said, :50 to 1:20 (maybe longer) with proper throttle management
AJ
Old Aug 18, 2009, 02:49 AM
Medvidek is offline
Find More Posts by Medvidek
Medvidek's Avatar
Prague, Czech Republic
Joined Mar 2009
Hi,
I am affraid there is not enough space to accomodate above batts. I use 3S 2300 mAh about 110 mm long and they sit as far aft as possible to get CG within recommended limits. Check me previous posts for photos.
Medvidek
Medvidek is offline Find More Posts by Medvidek
