Pieces and Parts
[QUOTE=jaccies]AJ,
you glued (with epoxy ?) a piece of normal wood onto the fuselage ? Actually, I used hot glue. Was CG ok now with the wheels? Exactly the same Does it fly different now with wheels? Haven't flown it yet. But, I expect little or not change did you bought thoose wheels (5 cm wheels? ) at HC? Yes. what endstops did you use for the wheels, cant see it on the picture 1/6" wheel collars from Tower Hobbies. AJ |
AJ |
Singapore
Joined Mar 2009
AJ -
Yes, I got the ARF, but not from Philip. I'm located in Singapore - got it from an LHS. Didn't need those electronics so I did not get the RTF from HC. I'll get the Towerpro combo for the motor and ESC though (the one recommended by someone here). That pic's helpful. Now I know what to expect in the fuse. Am using Spectrum's AR6200 - so I've got two RXs to stuff in there! Jaccies - Finally I know what goes where. Thanks to your pic! Looks like I may need a pair of chopstick to retrieve the y-cable from the front fuse opening. OK - its almost 1am (Sat morning) where I am now. Need to be fresh for a couple of flights in the afternoon with my beaten-up trainer Cessna. Then if the wifey 'allows' start assembling the CF in the evening now that you guys have cleared up quite a few questions I had. Thanks again! |
AJ |
Singapore
Joined Mar 2009
Been doing some interior design work in the fuse - how to fit everything in. Cut out a recessed area for the main AR6200 rx and a slot next to the battery for its satellite rx. The satellite rx will sit snugly in there once a 2200mah batt is inserted.
Thinking that the esc will have to pushed into the fuse since there's no space up front. Anyone encountered any problems with this? Will all the cables inside foul up the control rods? The motor's got three black wires. How will I know which is to be connected to the red/black/yellow cables of the esc? Thanks |
West Texas USA
Joined Mar 2008
ESC - Motor wires
Singapore
Joined Mar 2009
Anyone encountered problems with the messy wires inside getting into the way of the control rods, please let me know what you did to overcome it? Thanks |
This mod loks like a nice belly save. I put clear tape under my plane's fuse but after a dozen landings the tape is disintegrating. Thanks Michael |
http://www.hobbycity.com/hobbycity/s...idProduct=3892 I used .0625 music wire and some plastic tubing that I had laying around for stops. Note: Sometimes they come in blue like mine did. So, roll the dice and get what you get. BTW-The painting is done. AJ |
AJ. |
