AJ |
I knew you would come back with a response on that one.
Oh, after changing motors, props, batteries, ESC, etc on the AXN, I finally arrived right back at where I started - the stock setup with the necessary mods to the motor for reliability. For my flying, the stock setup is a perfect balance for both gliding about and limited aerobatics. At this moment, it is totally stock. AJ |
Singapore
Joined Mar 2009
Hi guys,
Just got the CF ARF. Am using HXT 900s. Just wondering how you guys mount the 2 servos in the fuse? Do you use the supplied glue and mount them directly onto the foam cutouts? If you do that, won't he foam be ripped off if the servos need to be replaced later? Thanks for helping. Want to be sure I get evrything done correctly before the maiden. Cheers JS |
What I did
AJ |
Joined Feb 2009
I too use the packing tape method with a drop of hot glue.
Has anybody had any problems with hot esc i changed out my spektrrum 6100 rx because of a broken dx6i. I cant wait to fly so i put an old esky rx and tx so i could fly while i wait for it to come back but i noticed that while testing i ran the throttle up for less than 30 seconds in two bursts and the esc is hot. Could the different rx do this or could it be the esc itself. Im using 20c 2200 zippys with the stock motor and esc. No loose magnets in the motor and nothing binding that i see any ideas??? |
AJ |
Singapore
Joined Mar 2009
Thanks Saucisse, AJ and Edgee400. I'll use the double-sided tape, packing tape and glue combo.
I'm still trying to figure out how the aileron servo cables run. I know how they go in the spar channel, connect to the Y-harness.... then what? there appears to be some kind of hole in the fuse where the two wing halves meet but that hole does not lead to the fuse where the RX will be. I know there's something about this somewhere in this thread (read through close to every posts here). Do I need to dig out a hole? Grateful for some help or pix here. The instruction leaflet is of little help, unfortunately. Thanks! |
AJ |
AJ P.S. The gold box in the lower right is a pitch gyro. It is wonderful. We can discuss gyros another time. |
