Hmmm funny you should mentoin that - esport Phoenix similar to CF ....
Yeah... At least as you said you didnt need to climb the tree.. it took us 20m to recover cause it felt down in quite high density bushes to the point that it wasnt visible until practically steping on it and thankfully the beeping of the ESC when Tx is off helped finding it
Crash at 9:40 so you can skeep and not loose time |
EDIT: lol please ignore post. Found it thank you.
For anyone else looking: How to glue axn floater magnets: http://www.rcgroups.com/forums/showp...&postcount=487 |
Google Dimension Engineering and look up their FAQs and they will explain UBECs. Universal Battery Eliminator Circuits pick up power from the battery and directly power the receiver and servos. You disconnect the internal BEC in the ESC. If the ESC fails you still have flight control. Plus, the heat of stepping down the voltage from the lipo (11.1 volts) to the Receiver (5 volts) is NOT in the ESC. Plus, the UBEC uses a more efficient way of stepping down the voltage (switchmode).
I did.. thanks!
On the Dimension Engineering products i see their SBEC is 1-1.5A and says "6 4-9g servos or 4 standard ones) is that correct? Because i think i readed here somewhere than the 2A BEC of the ESC was just enough to power the 4 9g servos but no more... Or its because the ESC BEC is linear and the other is switching? |
This speed control that I currently use, has a built in 4A switching BEC, avoids having extra cables and weight. |
