The Netherlands, LI, Venray
Joined Dec 2008
but he asked for dimensions , to get complete info check this one : tower pro motors |
Joined Dec 2008
You need a more powerfull motor for this airplane??....no need for at all you want a rocket lol?? HC tells this is the equivalent with 1070kv: motor original propsaver is OK to use , i use 2 O-rings to fit the prop |
AJ |
Joined Dec 2008
http://www.hobbycity.com/hobbycity/s...idProduct=4710 I corrected the other post. AJ |
Singapore, Singapore
Joined Jan 2009
On the Clouds Fly page it shows "Motor: Out runner brushless motor: 2208N 2200 KV" but in the manual it shows Model no. AX-2208N which, from the Motor Page shows 1130kv. Go figure!! |
AJ |
AJ: What size prop are you spinning with this motor? I had also replaced the motor on mine with this one, using a 6x4 prop; but IMO, it doesn't give it enough oomph. I was contemplating to use an 8x4 prop, which is the recommended prop for the motor, but it requires cutting the fuselage to make a channel for the prop. I don't really want to do this because it might weaken the fuselage and it will not look good aesthetically.
LG Quote:
Melbourne, Australia
Joined Mar 2009
I love hobbycity as much as the next guy getting yelled at by the mrs for having RC parts in every room of his house, but sometimes it pays to shop elsewhere
WH radio
AJ |
AJ |
Actually you did say that you use an 8 x 4 prop. Quote:
