Shuttle cockpit
this is a bit off topic but have a look
........te http://360vr.com/2011/06/22-discover...236/index.html |
2. Not True. See #1. 3. It would have to be terribly out of balance to cause a heat problem. It would have to be so bad that a person would have to be nuts to fly it. 4. It probably was not the problem. 5. Unable to determine with the small amount of information provided. More information is needed to uncover the answer. Since the latest motors are known to be crap, it could be something wrong with the motor - like loose magnets rubbing the rotor, etc..... AJ |
Bill |
I didn't know that AJ - I must have missed this in the thread.
Are all of our new AXN purchasers experiencing issues with the motor?? feedback appreciated because I have been recommending them to many ... (I have 2 spares sitting in the drawer - purchased some 4-6 months back )
AJ |
AJ |
Temple, GA, USA
Joined Jun 2009
I believe that a prop running backwards is not as slippery as one running forwards and makes the motor run slower, but admit that there may be an effect as strange as "windmilling prop causes more drag than stopped prop". Do you have a tachometer? I know you have a watt meter to measure amps. I did say "badly out of balance", so why are you picking at this statement? Yes, a badly out of balance prop can reduce and in worst cases drastically reduce the RPM and thus increase the amps. I have seen the prop spacer come off in flight and the prop become badly out of balance. I have seen people use a prop spacer that was loose enough for noticeable shaft slop although that would not be enough to reduce the RPM by much. Please test this (change in RPM of a forwards vs. backwards prop, with both at full throttle and change in amps with any propping that causes lower RPM at full throttle) and be prepared to post a video as I will be if you still think I am wrong and you are right. Cliff |
http://www.lowpricerc.com/product_in...oducts_id=1052 ![]() But HK is cheaper than LPRC for a change!! LPRC have had them for ages though. |
